Looking at a used Harman Accentra 2
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by ChandlerR, Jan 16, 2019.
  1. ChandlerR
    ChandlerR
    Seacoast NH
    LW, so how would this connect to my venting? Looks like the adapter slips inside? Man I wish I could talk to y'all in person. Looking at the pictures makes it tough to envision.
    bogieb, ivanhoe and slvrblkk like this.
  2. ChandlerR
    ChandlerR
    Seacoast NH
    So, as I see it, this adapter is for 4 inch DuraVent. It has a 4 inch pipe coming out. You took a 4 inch muffler pipe and welded it on. The tapered fitting on the Harman is 3 3/8 at it's narrowest....probably 3 1/2 at it's widest. How did you neck down the 4 inch pipe to fit?
  3. ChandlerR
    ChandlerR
    Seacoast NH
    The 3 to 4 T adapter will still not slip over my 3 3/8 tapered exhaust outlet. My Baby has a 3 inch outlet. I wonder if it would expand with my muffler pipe expander?
  4. slvrblkk
    slvrblkk
    Northampton, PA
    Video conference? :D
  5. badbob
    badbob
    The Harman adapter is tapered,stupid,in my opinion,after using an Integra for years,that came with a clamp on adapter.I had to use 4" because high altitude.3" or 4" exhaust tubing is a fairly tight fit on the Harman adapter.Remember,exhaust tubing/flue tubing adapters are measured on the outside.
  6. badbob
    badbob
    Oh,sent an offer to the Accentra that is some hours from me,got a reply,"no".Not a big deal,i am trying to find a bigger stove for my sister and her family.
    ivanhoe, bogieb, imacman and 2 others like this.
  7. ChandlerR
    ChandlerR
    Seacoast NH
    How far off was your offer? Think he may change his mind if it doesn't sell?
  8. badbob
    badbob
    He wanted 1500,I offered 1k.Am working on a deal now for a p61,gonna post a thread for opinion
    ivanhoe, bogieb, ChandlerR and 2 others like this.
  9. CleanFire
    CleanFire
    ChandlerR , if you want to adapt to 4" pipe directly off the appliance adapter, for the Harman stove it looks like the part # is: 3PVP-X4ADHB
    http://www.duravent.com/docs/product/pvp_harman_adapter_web.pdf
    Or use a 3"->4" adapter, use a 3" -> 4" Tee, or "roll your own" like BadBob did.
    *I'm still happy to do those measurements: but you are using 4" pipe - the 45 elbows I have here are for 3" pipe, measurements will be different / will not apply to your setup, unfortunately.
  10. ChandlerR
    ChandlerR
    Seacoast NH
    Thanks CF. That looks to be exactly what I need. I'm all set with the measurements, thank you. I am going to angle my T and use just one 45 elbow. If it's available, I'll order one tonight and when it comes in, I'll get to work. I can't wait to have this thing cranking in here!
    ivanhoe, bogieb and CleanFire like this.
  11. ChandlerR
    ChandlerR
    Seacoast NH
    Just ordered it. Thanks for the link again. it should be here next friday. Not cheap though. I had to shop around until I found one $30 cheaper
  12. CleanFire
    CleanFire
    Sure is nice looking, good luck cleaning and hope your wife enjoys her new Harman stove. :D
  13. ChandlerR
    ChandlerR
    Seacoast NH
    It's funny, I ran it in my shop with the door open and it still heated it enough that I was able to spend some time cleaning it. Once i get it in here, then I'll get serious. my wife will be so happy but no way will she touch it until i give her lessons. my baby has one button she pushes. this thing has three knobs!!!! :bug:
    ivanhoe, bogieb, jtakeman and 2 others like this.
  14. golf66
    golf66
    Going with the P61 is a smart choice. It puts out more BTU's than the Accentra and you can purchase a hopper extension that will allow you to go longer between reloads.
    ivanhoe, CleanFire, gbreda and 2 others like this.
  15. bogieb
    Okay, I didn't explain that well. Put on the Harman adapter (which 3 people have given different links for), then hook up the T to that - then hook up the 4" exhaust to the 4" part of the T.
    Rich250, jtakeman, ivanhoe and 3 others like this.
  16. Lousyweather
    Lousyweather
    Personally, I guess I would nix the Duravent and get ICC Excel...….you remove the cast iron stove nipple on the stove and bolt on the new one....even comes with the gasket.....much more secure than RTV'ing the Simpson back on...and it doesn't leak. Youll have to tape and RTV to ATTEMPT not to get your Duravent to leak....its why we don't use it anymore. I do understand you already have pipe ordered, etc, so this will likely not be an option you choose.....basically, new (to you) stove = new pipe.
    bogieb, ivanhoe, ChandlerR and 2 others like this.
  17. ChandlerR
    ChandlerR
    Seacoast NH
    When I was at Home and Hearth, they looked up what I would need to use the exhaust they use. I forgot the name but it's all stainless, laser cut and seamless. To do my piping would be $700 in parts. :bug: They said they use it because it works so well and they never have to deal with issues.:bug: It's also larger than my DuraVent so I would need to replace my thimble.
    I may reconsider if I have issues. Knock on wood, I have never had a whiff of smoke smell in 12 years.
    CleanFire, jtakeman, bogieb and 4 others like this.
  18. ChandlerR
    ChandlerR
    Seacoast NH
    Hey, I have a question...What the heck is this switch for? Nothing in the manual. Under the switch it's stamped LOW
    CleanFire, ivanhoe, slvrblkk and 2 others like this.
  19. bogieb
    My guess would be the blower fan switch (which I don't see on your panel). But knowing absolutely zero about that particular model, don't actually know the answer.
    If it is for the blower fan, one is low and the other is high. I keep mine on high, others keep theirs on low. It is more a function of what you are trying to accomplish in your circumstances.
    CleanFire, ChandlerR, ivanhoe and 2 others like this.
  20. gbreda
    gbreda
    NH
    Hi/Low fan switch? I have a variable pot on the P68 and only switch is for igniter Auto/Manual. Maybe the smaller stoves have the switch, but my honey's XXV is the same as mine-no hi/low switch.
    CleanFire, subsailor, bogieb and 3 others like this.
