Looking at a used Harman Accentra 2
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by ChandlerR, Jan 16, 2019.
  1. slvrblkk
    slvrblkk
    Northampton, PA
    Bearings can be replaced but sometimes a pain in the azz and at least to me. not worth it. You can get a good, quiet Fasco replacement for $55 ish shipped.
  2. ChandlerR
    ChandlerR
    Seacoast NH
    Ok, I do have a needle oiler but not sure if the needle is small enough. What I may do is use a jewlers screwdriver to make a gap in the seal and dribble some oil down the shaft. I was told that the blower was replaced. Maybe it was....hmmmmm
    ivanhoe, bogieb and slvrblkk like this.
  3. ChandlerR
    ChandlerR
    Seacoast NH
    Yeah, that may be a job in the Fall. Unless never seize was used on the impeller, I be cuttin' the shaft mon.
  4. badbob
    badbob
    You have nothing to loose doing it that way.Ya,I believe your old motor would have been a Jakel
  5. badbob
    badbob
    Next time you are in a store with a pharmacy,ask for a few needles,they generally give me a few at a time free,I also use the small needles to glue plastics together.With a needle you could squirt some oil in it without removing it.
  6. badbob
    badbob
    The Jakel motors were worth replacing bearings,not the newer motors like yours,prob. would never find brgs anyway.
  7. ChandlerR
    ChandlerR
    Seacoast NH
    Good to know however I wonder if it was really only used with the new motor for one season. That bearing shouldn't be rattling like that. (Unless it was installed with a dry bearing)
  8. ivanhoe
    ivanhoe
    Northern Ontario
    I'm pretty sure you have the original motor in there, Gleason/Avery! My stove is older than yours and it didn't have a Jakel. I posted the bearing in that motor many moons ago. Skateboard bearing 608RS
  9. ChandlerR
    ChandlerR
    Seacoast NH
    Well, that would explain the dry bearing. Thanks ivanhoe!
    jtakeman, bogieb and ivanhoe like this.
