Looked a few Sthil Saws today.
Discussion in 'The Wood Pile' started by happysawer4741, Dec 15, 2020.
  1. Cash Larue
    Cash Larue
    Pine, CO
    I’ve always had Stihl saws. But I did have a Husky dirt bike for YEARS growing up. I beat the living crap out of that thing. Raced it all over the state. It always ran like a top. Never broke down. Wish now that I hadn’t sold it.
    farmer steve and Husky Man like this.
  2. happysawer4741
    happysawer4741 Banned
    Houston Texas
    Could you explain how to get to the solenoid like how much has to be taken apart.
    Cash Larue and farmer steve like this.
  3. Mag Craft
    Mag Craft
    South East Wyoming
    It is located on the carb itself. So you have to take the carb off to get to the solenoid.
    farmer steve and Cash Larue like this.
  4. huskihl
    huskihl
    Nixon ’s saw. MS462CR
    Remove top cover
    The yellow and red wires come from the coil and go to the ignition switch and solenoid. That’s all there is that runs it. It’s not complex
    Remove air filter
    The white plastic at the end of the screwdriver is the solenoid. On some saws you’ll need to pull the carburetor, which involves two nuts in the air filter baffle that hold it on, the throttle lever assembly, fuel line, and impulse line. The solenoid is held on by a couple small torx drive screws. Wiggle it back-and-forth and pull it out, remove the solenoid from the plastic clip, insert the clip on the new solenoid, twist it back in place and put the screws back in
  5. buZZsaw BRAD
    i would cut the red wire...they always do in the movies! :rofl: :lol:
    eatonpcat, basod, Mag Craft and 12 others like this.
  6. grandgourmand
    grandgourmand
    Ontario
    Thanks for showing the US prices. Helps me get an idea of the 500i price when it’s available here
    should be about 1700-1800 Canadian. Definitely not cheap, but could put aside some play money over the next couple years and end up with that one as my second saw
    M2theB, Husky Man, Cash Larue and 2 others like this.
  7. huskihl
    huskihl
    Never
    EVER........
    cut the red wire. Or the yellow lol
    basod, M2theB, Midwinter and 3 others like this.
  8. buZZsaw BRAD
    :faint:
    M2theB and Sandhillbilly like this.
  9. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    Yeah that’s what I was thinking! .....slacker
    M2theB and Canadian border VT like this.
  10. buZZsaw BRAD
    i was more shocked that a 500i would be his back up saw!
  11. EODMSgt
    EODMSgt
    White Mountain Region, NH
    As a retired bomb tech I'm just going to leave this one alone....
  12. huskihl
    huskihl
    It’s part of the ignition coil
  13. happysawer4741
    Houston Texas
    It plugs into the ignition coil?
    To control the fuel flow the microprocessor has to be getting input from the Temp. and Baro. Pressor where are these items?
  14. huskihl
    huskihl
    I believe there’s only a temperature sensor inside the coil. Like I said, it’s not all that complicated. The coil adjusts voltage to the solenoid while searching for maximum RPM. That’s about the extent of it
    Chud likes this.
  15. huskihl
    huskihl
    There is no external micro processor. It is part of the coil. It looks like any other coil.
    Cash Larue likes this.
  16. happysawer4741
    Houston Texas
    Thank you for the information, i just thought there was more involved in controling the operation of the saw.
  17. huskihl
    huskihl
    No. Like mentioned a couple times, it’s not a complicated system. It has the same number of wires coming from the coil as a carbureted saw does
    M2theB and Cash Larue like this.
  18. Mark J
    Mark J
    Tasmania
    Down under the 500i with a 20" bar is AUD 2099 USD 1600 with a 25" bar AUD 2149 USD 1638.
    Buzz Benton and M2theB like this.
  19. Woodwhore
    Woodwhore
    Mason NH
    Thats why i went to echo!!!! All carb and no plans for all that electronic crap.
  20. happysawer4741
    Houston Texas
    Echo is a good brand chainsaw for it's prices, my dealer carries them also.
    NH mountain man and Chud like this.
