Logging trail crossover..
Discussion in 'The DIY Room' started by Chaz, Sep 26, 2018.
  1. huskihl
    huskihl
    For what he's doing, 2 6' pieces butted together with a piece of aluminum flashing over the seam on top would suffice
    brenndatomu likes this.
  2. brenndatomu
    Yup, I've used plastic 5 gallon buckets for splices/repairs in tile/culverts many times...works gooder!
    huskihl likes this.
  3. huskihl
    huskihl
    Not to mention, a 6' scrap of 12" culvert is scrap to most excavators. Might get them cheap
  4. Bgoathill
    Bgoathill
    Dumont, Ia
    If you're going to do that, wrap a piece of erosion fabric, or roofing or landscaping fabric if you can't get any, tightly around the pipe under the flashing. If you have a little gap between the pipes and high water velocity you could have a blowout and eventually your pipe will washout. Or form a suckhole around the pipe, then when you drive over it will collapse and whatever you're driving is in the hole.
  5. brenndatomu
    :yes: Gooder advice!
    shack likes this.
