Log Totes
Discussion in 'The Wood Pile' started by Mwalsh9152, Nov 21, 2018.
  1. Easy Livin' 3000
    Easy Livin' 3000
    North side of the ridge
    Yep. Contains the mess, and you can even stack them if you want.
    These are some heavy duty boxes. Last for many seasons.
    It's almost as if they were made for the job.
    Screwloose, Maina, Chaz and 5 others like this.
  2. T.Jeff Veal
    Screwloose, Marvin, dingbat and 6 others like this.
  3. ChadSmith
    ChadSmith
    Wisconsin
    I just saw this bad boy the other day. Might be worth a look.
  4. NYCountry
    NYCountry
    Mohegan Lake NY
    Screwloose, dingbat, HDRock and 4 others like this.
  5. bert the turtle
    bert the turtle
    Mostly, I use a big tough plastic storage bin that I put on a furniture dolly and bring it it. Holds a day or two's worth. Sometimes I just fill my 1000lb capacity wagon and bring that in. Having concrete floors has its advantages. The only problem is the rubber tires have a bit of scent to them.
    Screwloose, dingbat, HDRock and 5 others like this.
  6. M2theB
    M2theB
    Central Massachusetts
    image.jpg Been using this canvas hauler for years. It used to have steel bars around the hemmed edges, but those are long gone. Still structurally sound.
    The suade tote and frame are a convenient place to set it in.
    Screwloose, Marvin, dingbat and 7 others like this.
  7. brenndatomu
    Screwloose, HDRock, M2theB and 3 others like this.
  8. bear 1998
    bear 1998
    S.C.Pa
    Couldnt find the Log Ox firewood tote bag neither....
  9. ChadSmith
    ChadSmith
    Wisconsin
  10. Mwalsh9152
    Mwalsh9152
    Pelham NH
    I found that a big rubbermaid tote worked great too, but it was too obtrusive. My stove is right in the middle of the main living area of the house, so I would always have to bring it back out on the porch after I used it. Canvas tote could go right with my welding gloves and be out of the way. Saves me having to go back outside when it's really cold.
  11. Maina
    Maina
    Maine
    We had one just like that for years and I don’t know what happened to it. I went looking for a replacement and it was way too much money. I like the nice heavy frame and the tote would be awful hard to wear out.
    Screwloose, Chaz, HDRock and 4 others like this.
  12. M2theB
    M2theB
    It was a gift from my mother in law one year. So I'm not sure where it was bought. Could've been LL Beane, which would not be inexpensive.
    But it's been a good one.
  13. Suburban wood snob
    Suburban wood snob
    Milwaukee
    Wheel barrow. Two loads to fill out the hoop outside the back door , and three to fill up the garage vertical rack.
    It's enough for two weeks of heavy burning
    Screwloose, M2theB, Chaz and 4 others like this.
  14. Mwalsh9152
    Mwalsh9152
    Pelham NH
    I do the same. I load half a cord onto the enclosed porch, but getting it from the back of the porch to the front, through the door over to the stove is a PITA with an armload of wood.
    Screwloose, Chaz, HDRock and 3 others like this.
  15. Suburban wood snob
    Suburban wood snob
    Milwaukee
    We use the indoor rack for starting...a couple of trips to the stove from the garage is like 16 feet ... Not a big deal. Reloads are off the outside, which is well protected because we have huge overhangs.
    Screwloose, Chaz, brenndatomu and 3 others like this.
  16. HDRock
    MSRP $69.95 :smoke:
  17. Easy Livin' 3000
    Easy Livin' 3000
    MSRP $0.00
    Screwloose, dingbat, MikeyB and 3 others like this.
  18. dylantdyck
    dylantdyck
    CA
    I put about 3 cords in my wood room in my basement through the window and the rest i've been using a horse lead rope everything that will fall off comes off right away.
    Sent from my SM-G950W using Tapatalk
    Screwloose, dingbat, M2theB and 3 others like this.
  19. HDRock
    I like to keep as much dirt and crap contained as I can , The bags I use do a good job of that , the wood goes from the bags To this bin in the pic, Then the bags go outside and get shook out .
    My little buddy doing an Inspection when I first got it
  20. amateur cutter
    I use these. I know I know, my "stove" isn't inside.
    Maina, Chvymn99, Marvin and 3 others like this.
