Log splitters
Discussion in 'Chainsaws and Power Equipment' started by Backwoods Savage, Aug 25, 2018.
  1. BDF
    BDF
    That looks almost identical to mine. What I like about them is that the engine, hydraulics and everything else is well forward of the work area, making it much easier to use than some other brands or types IMO. Plus as I said, the Ariens sit taller than (some? most?) other types making it much easier on the back.
    The buck- block or backing block on mine has a diamond- waffle pattern with sharp points..... excellent at grabbing the end of a log, even at an angle. But also hard on the fingers when a foolish operator allows them to get between the round and that plate. :whistle::picard::emb:
    Brian
  2. bear 1998
    bear 1998
    S.C.Pa
    Is that photo shopped??
  3. Paul bunion
    Paul bunion
    Nope, that's for real.
    Beside the car.
  4. SkidderDone
    SkidderDone
    Pollock Pines
    :drool:
    Stlshrk, Barcroftb, WeldrDave and 7 others like this.
  5. saewoody
    saewoody
    Central CT
    I have a one of the original 2011 (think that was the year) Speeco SpeedPro kinetic splitters that were recalled. Mine apparently had the warranty/replacement parts taken care of and continued being used. I bought it second hand about a year and a half ago. I only have probably 8 or so cords on it.
    I tried the milk crate like Backwoods talks about, but I found it too hard to reach the engagement lever!
    Some of you may notice the pull cord missing; it broke this spring, so I’ve been starting it with the drill for now.
  6. Marshel54
    Marshel54
    25 ton MTD bought well used 5 years ago. Put a Predator engine on it 3 years ago and runs like a champ.
  7. billb3
    That was a BIG pile of splits.
    Stlshrk, Barcroftb, Chaz and 6 others like this.
  8. Midwinter
    Ha! They were probably the ones I brought my cast iron pans in, I'm glad you got them!
    Stlshrk, Barcroftb, Chaz and 8 others like this.
  9. bear 1998
    bear 1998
    S.C.Pa
    That splitter just looked so small...lol
  10. Screwloose
    Screwloose
    IMG_20180827_181048830.jpg This speeco was purchased when I was a kid, close to 40 years ago I guess. It came as a total kit had to even install the wheel bearings. 2nd engine bunch of oil changes NEVER been inside. IMG_20180827_181717208.jpg This one I've had 7 or 8 years.
    Stlshrk, Rope, Barcroftb and 17 others like this.
  11. campinspecter
    campinspecter
    How long of rounds does it split ?
    Stlshrk, Barcroftb, Hammy and 8 others like this.
  12. T.Jeff Veal
    I found a 2009 TW-5. Guy wants $4K for it. What do y'all think? Haven't looked at it personally yet...
    Stlshrk, Rope, Barcroftb and 7 others like this.
  13. Marvin
    Marvin
    Huntingdon, Pa
    What the hairy is that thing? :startled:
    Dont think I'd be bending over to tie my shoelaces in front of that :bug:
    Stlshrk, Barcroftb, Hammy and 9 others like this.
  14. huskihl
    huskihl
    It's called a Barkbuster. Fast as all get-out but dangerous as he!!
    Stephiedoll, Stlshrk, Rope and 13 others like this.
  15. Screwloose
    Screwloose
    It's not as dangerous as it seems. That's the second one I've made, been unscrewing logs for a long time and no injury's yet.
    Stlshrk, Barcroftb, Hammy and 10 others like this.
  16. T.Jeff Veal
    Is it worth that much? Guy runs a tree service, he just bout a TW-6..
    Stlshrk, Barcroftb, Hammy and 7 others like this.
  17. Canadian border VT
    It's really hard to say how much a used piece of equipment is worth. A new tw5 with the log lift and the splitting table, why would you buy it without that, is around $9,000. So this price is about 40% of new. really depends on the condition of the machine and if you would use that type of machine to make it worth that much more money. Compared to let's say a $800 Big Box store standard splitter..
  18. Screwloose
    Screwloose
    Have you seen it yet ? I'd have them show me it splitting, working hard even if you have to cut a log with it. At 40% of new if it passes the test and it's priced within the local range for splitters of that caliber I'd say it's not bad. Unless you abuse it your grandkids will be splitting with it or at least it's going to keep it's value. Except for homemade stuff i've never seen a junked splitter.
    Stlshrk, Barcroftb, Hammy and 6 others like this.
  19. chris
    chris
    SE WI
    that's cause the guy's at the junk yard grab them and stick them on CL
  20. Backwoods Savage
    This has been a good thread and I thank all of you for making it good.
