Log splitters
Discussion in 'Chainsaws and Power Equipment' started by Backwoods Savage, Aug 25, 2018.
  1. MikeyB
    MikeyB
    Long Island NY
    That is very impressive, nice work.
    Stlshrk, Barcroftb, leoht and 13 others like this.
  2. billb3
    Nice work table !
  3. Tiewire
    Tiewire
    Missouri
    Vertical splitting while standing..............I like!!!
    Stlshrk, Barcroftb, leoht and 14 others like this.
  4. 03fatboy
    03fatboy
    Grand Island Nebraska
    The work table is awesome.
    The only time I bend down is to pick up something that fell off.
    I use a pickaroon to move the rounds to my lift and up they go,then its belly/chest height and it's easier to move to the splitting wedge, then the split's move to the left get stacked up,from their into the shed.
    Controls are at waist height for the lift on the left side and splitter control is on the right.
  5. 03fatboy
    03fatboy
    Thanks, it took me about 3 months to build it, just kinda figured stuff out as I went along.
  6. Chris F
    Chris F
    Micksburg, Ontario
    China made from TSC. Used it the last two years and about to use it again, no problems at all.
    Kohler engine fires first pull, even after sitting all winter.
    Taught my son the right way to use it :D
  7. Paul bunion
    Paul bunion
    I have a Ram Splitter 16 ton electric. It was a bit on the expensive side. I went electric so that I wouldn't have to deal with bad fuel/carb issues on a machine that might go over a year without getting used. My yard is small enough so electricity isn't a problem. It also is a bit more compact without the gas motor. Its seen 15 or so cords in the past 5 years. I've put 2 log loads plus other tree service goodies through it. That's it in front of a log load that I processed this past spring.
    Stlshrk, Rope, Barcroftb and 23 others like this.
  8. Mag Craft
    Mag Craft
    South East Wyoming
    22 ton husky. Briggs engine. Had it about 5 years. Used a 5 ton electric splitter before that. I would not be ahead on the 3 year plan without the hydraulics.
    Stlshrk, Barcroftb, Dancan and 14 others like this.
  9. campinspecter
    campinspecter
    The Beaver is 34 years old. It is now on its third engine - all Hondas , its third winch and its second ram. A guess says it has split over 600 cords.
    The frame has never required any welding. I can't remember if there was 12 or 24 of them built.
    This is going to be a good thread for Backwoods Savage
    Below are some videos of it at work.
    Cutting firewood with the help of a Log dog
  10. NH mountain man
    NH mountain man
    WMNF N.H.
    Now you can have two other people sit around the splitter with you. :rofl: :lol:
    Stlshrk, Barcroftb, leoht and 11 others like this.
  11. bushpilot
    bushpilot
    Eastern Washington
    Yep, that is what I have as well, and it works remarkably well. But I still do most by hand. This year i never rolled it out of the garage.
    Have you made a stand or anything to help with the lowness of the splitter? I have put it on my truck bed before, and that helps, but I think I would like to make a proper stand.
    Stlshrk, Barcroftb, Chaz and 8 others like this.
  12. huskihl
    huskihl
    Nothing wrong with that!
  13. Marvin
    Marvin
    Huntingdon, Pa
    Nice to see a post from campinspecter! Not sure if I missed you posting in other threads or not, but either way it's good to see you around again. I hope your feeling better :yes:
  14. T.Jeff Veal
    Very nice design. Great job.
    Stlshrk, Barcroftb, leoht and 10 others like this.
  15. blacksmithden
    blacksmithden
    Alberta Canada
    Ive got my 15 ton Speeco head and valve mounted on the side of my trailer. Custom made hoses with quick connects running up to the original 6.5hp engine and pump on the front. 10 gallon oil reservoir mounted beside the engine. It's also sporting the home brewed 4 way wedge that I built (now cleaned up and painted). This setup serves my purposes perfectly and it's easily handled everything I've thrown at it so far.
    WinonaRail, Stlshrk, Rope and 21 others like this.
  16. blacksmithden
    blacksmithden
    Alberta Canada
    I made this kind of discovery early on. Here, the VAST majority of firewood is softwood with the odd birch mixed in. There are places selling up to 50 ton units and there's no hope of them ever being used to their full potential.
    I went with a used 15 ton Speeco that I got off the local buy and sell for $350 Cdn pesos (not running). The owner had towed it all over the place with the fuel valve turned on. In typical Honda fashion, it filled the crank case with fuel and flooded. A 5 minute oil change and she was back in business. So far, it's easily cracked every single thing I've put through it even with a 4 way wedge on it.
    If your equipment handles the job you need it to do, then there's nothing wrong with it.
    Stlshrk, Barcroftb, Chaz and 11 others like this.
  17. BDF
    BDF
    Yeah, I did try that (and variations on the idea) but found the piece of material used to level the rounds kept getting pushed out of position while 'arguing' new rounds into place. In the end, I found it was just easier to noodle the really huge rounds in half and then get a helper to deal with the round halves, again with the splitter horizontal. I am sure there is a learning curve and I would get better at it but I just have not had enough really big rounds (read: non- lift-able for two people) that I have had to develop that method very much.
    Depending on what happens going forward and whether or not I get any more really large firewood, I will probably go for the electric hoist / drag attachment for the splitter. That way I can not only lift anything that will fit into the splitter, I can also drag the huge stuff to the splitter also. I always try to trade electrons or petroleum for sweat and grunting..... :)
    Brian
  18. ReelFaster
    ReelFaster
    S.Jersey
    Splitting by hand for now with the occasional borrow from my brother in law. But when I get the funds eventually looking at Electric, specially the Boss line, they make a 10 TON dual action splitter that I have my eye on. Quiet, low maintenance, smaller footprint, easy to move around, etc....
  19. Chaz
    Chaz
    Southwestern NY
    Went halves with best friend on a 25 Ton Cub Cadet some years ago, it works great.
    No pic currently, looks exactly like stuckinthemuck posted on pg 1.
  20. Woodwhore
    Woodwhore
    Mason NH
    I highly recommend this one, iv had it 4 or 5 years now and love it. 35DB00C6-B8CE-4BAD-816C-0E6475374663.jpeg
    Stlshrk, Rope, Barcroftb and 18 others like this.
