Log splitters
Discussion in 'Chainsaws and Power Equipment' started by Backwoods Savage, Aug 25, 2018.
  1. Rope
    Rope
    Alaska
    Has any used and oil products from Warren Oil, have any quality issues? Specifically the "Hydraulic Fluid 5 GAL Coastal J20D Synthetic - Tractor". I just tried getting the Chevron Aircraft Hydraulic fluid, its not currently in stock with in 300 miles. NAPA has this synthetic hydraulic fluid, that will be here on Thursday. If no one says don't, then looks like I will T&E.
    metalcuttr, Maina, Screwloose and 5 others like this.
  2. WeldrDave
    Rope, Warren oils are a small company from PA. I've never heard anything "bad" about them and it's sold here alot in the "dollar stores" and discount places. I can't see any issue with it but I will say, "don't be in a hurry if you don't need to be"... If you want something specific, Wait! :yes: There is absolutely nothing wrong with Coastal products!
    Stlshrk, metalcuttr, Maina and 5 others like this.
  3. HDRock
    Would transmission fluid be any better in cold weather ?
    Stlshrk, Maina, Screwloose and 5 others like this.
  4. HDRock
    Well this is what my manual says
    Automatic transmisssion fluid can be substituted and should be used instead of hydraulic oil when temperatures are below 32 degrees
    Stlshrk, metalcuttr, Maina and 6 others like this.
  5. Rope
    Rope
    Alaska
    No ETA on the Chevron. If it was going in something other than a splitter I would wait. It has a cold pour of -55 I think it will be fine in this application.
    Stlshrk, metalcuttr, Maina and 7 others like this.
  6. Rope
    Rope
    Alaska
    ATF is more expensive than the synthetic hydraulic fluid. The synthetic fluid has a -55 pour temp.
  7. Rope
    Rope
    Alaska
    The splitter will spend its spare time in a heated shop. I don’t want the fluid to get thick when it’s cold out and slow the ram speed down.
  8. WeldrDave
    Rope, "I'm sure" you thought of this but when we lived in Wisconsin briefly, I had one of these on each of our cars, It was a life saver.
    Stlshrk, metalcuttr, Maina and 8 others like this.
  9. Rope
    Rope
    Alaska
    I have almost that exact one in 300 watt but don’t use it much. Up here we normally use the heating pads that attach. The heat transfer is way better than the magnetic. I am hoping that starting out warm that when it got outside and starts cooling down the synthetic fluid stays warm enough from the pump. If not I may have to look into putting on a heat pad. Will come down to how much heat does the pump generate.
  10. WeldrDave
    I figured as much! Living up there, you have to be very resourceful and make things work! I have great admiration for people choosing that area to live. I have folks/friends I was in the Coast Guard with, when he retired they moved "back" to Fairbanks. He was stationed there years back and they loved it!
  11. brenndatomu
    It will make plenty of heat while you are using it...that's one of the things some people that use them heavily complain about on these "mass produced" splitters, lack of extra oil capacity, which makes 'em tend to run high hydraulic oil temps when run hard in hot weather...so it should work just fine for you in cold weather, especially since you are starting out in a heated garage.
  12. Rope
    Rope
    Alaska
    Some time over my days off, and I get the synthetic fluid in, I will be giving her a go. Fridays high is 8* and Saturday 11* it will be a good lookie see. I am figuring that big hunk of steel will cool quickly, but hoping enough heat is generated to keep the cycle times good. Summer time heat that we will run the splitter in will be no more than 80* but most likely between 60-70*. Evan at that temp I think the synthetic fluid will be helpful.
  13. imwiley1
    imwiley1
    Wisconsin
    thumbnail_20181113_105421.jpg thumbnail_20181113_105514.jpg Here is my Speeco 22 ton. It has worked flawlessly since I bought it. This day was in the teens and I put my gloves on the ram to dry when I take a break because the ram gets warm. Run regular hydro fluid. The table is just some scrap black pipe I had around. It was meant to be able to remove it but my fab/welding skills are far from perfect. I have 3/4" couplings w/nips welded to the side rail that slide inside of the 1" pipe of the table. During weld up it moved enough to make it very difficult to slide on/off so now I just leave it on as it doesn't get in the way of anything I would do with the splitter.
  14. Rope
    Rope
    Alaska
    The champion did not start up at 10*. I gave a few pulls, she wanted to. So I put her in the garage ran to Napa to get the synthetic hydraulic fluid. Have decided to run the splitter with the fluids it can with. And at the end of day change all fluids to synthetic.
  15. Rope
    Rope
    Alaska
    The warm splitter cranked on the first pull. It was 10* and the pump kept the hrydralic fluid warm. The cylinder was warm enough to most likely dry a glove in about a half hour. So glad I got the splitter, the boys and I got a few cords cut and split. Some stacked the rest in a pile in the pole barn.
    Be work I went OSHA on the boys, we had a safety brief, question and answer session then a walkthrough with demonstration. I put a glove with ketchup packs inside, and used a 4 inch round. I demonstrated how easy the wedge would cut an arm off. The squirting ketchup really drove the reality home. Along with some pics from the Internet and the story of Mrs Witmer.
    We ran the splitter about 5-6 hours all was well. 401D9B1F-921B-4CE4-87A6-A23C2FCAFBDB.jpeg EB6DB368-8B6A-4BCD-9EF9-25B461FBE945.jpeg 3F7E4880-9C0F-423A-BA60-666ACD818A11.jpeg A044E10D-E454-4762-A5E3-3A00A2A9DCD1.jpeg 0EF79781-FD82-4080-AE6D-9D65F5E074C2.jpeg 0C2C8FFD-E982-4AD5-BFE0-FFF004416F21.jpeg
    Stlshrk, metalcuttr, Hammy and 12 others like this.
  16. HDRock
    That's the way to get at it man ,You can get a lot done with hydraulics :axe::axe::woodsign::stacker::stacker:
    I love the demonstration idea you came off with ,But where is the pics from that ? :ithappened::D
    Stlshrk, metalcuttr, Hammy and 5 others like this.
  17. HDRock
    You got some good helpers there too Rope And I bet you're glad to have them
  18. Rope
    Rope
    Alaska
    I did not take pics of the demonstration and Jake (lab) had taken the ketchup glove.
    Stlshrk, billb3, metalcuttr and 7 others like this.
  19. HDRock
    Stlshrk, metalcuttr, Hammy and 6 others like this.
  20. Backwoods Savage
    Way to go Rope! A nice demonstration and a good start for the young ones. Just one thing you missed. How about standing that splitter up and splitting vertically, the same way the trees grow?!!!! Saves a lot of work and for sure a lot of bending.
