Log splitters
Discussion in 'Chainsaws and Power Equipment' started by Backwoods Savage, Aug 25, 2018.
  1. Brandon Scott
    Brandon Scott
    Formerly Rabbit Hash
    I think you have to paint ur splitters rainbow colors to live there...
    Stlshrk, Hammy, Screwloose and 4 others like this.
  2. WeldrDave
    NOT IN THIS HOUSE!!!!!!!!!!!!!!!!!!!!!!!!!!!!........:zip:
    Stlshrk, Hammy, metalcuttr and 7 others like this.
  3. Backwoods Savage
    Dave I agree that thing should last the rest of your life. Treat it well and it will treat you well.
  4. WeldrDave
    I was so close to getting a 22 ton at TSC that you and I discussed and was going to stay in the 20+ ton range. If TSC would have given me the 10% military discount I may have bought it, they only give a military discount on Veterans day! :zip:o_O It was $1199.00 Then I found this thing! o_O:eek:, I had too... :tears::cool::whistle:
  5. In the Pines
    In the Pines
    That is some BS. It's a nice splitter, my 25 ton has been given some serious forked,gnarly knotted oak and dealt with it accordingly.
    I'm sure that 35 ton will take on anything you come across.
    Stlshrk, Hammy, metalcuttr and 6 others like this.
  6. Brandon Scott
    Brandon Scott
    IMG_0312.JPG Took me and a buddy 40 minutes. His truck broke down so have to get it hauled to his house so we can refill it.
    Stlshrk, Hammy, Chvymn99 and 10 others like this.
  7. Erik B
    Erik B
    Western Wisconsin
    Dumb question time. I bought my Speeco close to 20 years ago and the engine is on the operator side. I have never had any issues with wood falling off and damaging the engine. Why do splitters today have their engines located where they can be damaged from falling wood?
    Stlshrk, Rope, Hammy and 11 others like this.
  8. The Wood Wolverine
    TurboDiesel Tim, the splitter above has that addition you mentioned. Looks like a slip-on.
  9. Brandon Scott
    Brandon Scott
    Just my opinion. Mostly I see this on combo horizontal/vertical splitters. This is to preserve the center of gravity of the beast and keeps the machine compact. If they made them extremely long they could put the engine away from harm. I really like how compact they are even though I designed mine differently.
  10. Erik B
    Erik B
    Western Wisconsin
    Not sure what you are saying Brandon Scott My speeco is both H and V.
  11. WeldrDave
    Engineers also didn't want people to get burned or suck up exhaust, because some were to "stupid" to stay away from it! The splitter I just got, I'm "NOT" a big fan of where the engine is in relation to the splitting table and such. Brandon is right with balance and the towing factor is involved! I just looked at the factory table you can buy for mine, only one problem....... :whistle:, You can't put gas in the dam machine after it's installed!!! o_O I'm gonna come up with my own solution to protect the engine. I was out there running it in at different speeds with the break in procedures.
    Stlshrk, Hammy, Chvymn99 and 7 others like this.
  12. HDRock
    I don't know why they're doing that now maybe to get the noise farther from the operator .
    Mine is on the operators side also And I like it like that ,,I can Adjust the throttle , start it up and Shut it off without walking around the other side
    Stlshrk, Hammy, Screwloose and 6 others like this.
  13. Chaz
    Chaz
    Southwestern NY
    Not sure of his thought process, but it makes sense in my mind to have most of the weight above the tires.
    Easier to manually move around, and should reduce bouncing around when towed.
  14. Brandon Scott
    Brandon Scott
    With your talent I'm surprised it's not done already.
  15. WeldrDave
    Measurements already have been taken for something up my sleeve... ;)
    Stlshrk, Hammy, Screwloose and 5 others like this.
  16. Brandon Scott
    Brandon Scott
    Not sure what your splitter looks like but a trap door of some sort for the fuel fill maybe.
    Stlshrk, Hammy, Screwloose and 2 others like this.
  17. WeldrDave
    Page 14.. Back one. You can see the Arm/tables where they bolt on. Check this out...
    Stlshrk, Hammy, Screwloose and 3 others like this.
  18. Brandon Scott
    Brandon Scott
    Does it by chance pivot up? If not you can fix that...
  19. Brandon Scott
    Brandon Scott
    That is very well made!
  20. Tiewire
    Tiewire
    Missouri
    Thanks Brandon, about the only thing I’ve ever made that works flawlessly. Welds aren’t the prettiest but have held up
