Log splitter build
Discussion in 'Chainsaws and Power Equipment' started by the GOAT, Sep 11, 2014.
  1. Hedgerow
    Hedgerow
    SW Missouri
    Just an FYI... I put one of those 13hp clones on my splitter, and it will split wood at idle with a 22gpm pump...
    Oliver1655 and the GOAT like this.
  2. Stinny
    Be careful with the idea of stacking splits. They might have a way of shootin sideways under tons of pressure... in your direction... :hair:
    Your frame looks good so far... :yes: Rugged.
    DexterDay and the GOAT like this.
  3. the GOAT
    the GOAT Banned
    Maine
    Will it go to 3000psi at idle??
    I'm torn on which engine to go with -- lifan makes a 13hp and 15hp Chonda. I'm tempted to try the 15hp with 28gpm but don't want to find that it stalls the engine at 2500psi.
  4. Hedgerow
    Hedgerow
    SW Missouri
    Yes.. And it don't use near the fuel running just off idle...
    I hate chinese junk, but this one was available, and I have yet to kill it even after 3 years use...
    So it'll be a crap shoot... Save your receipt... :confused:
    Will have a big Kohler on it upon chonda's death...
    Also.. It must be elec. start... Cause when it's 10 degrees out you'll just trash recoils left and right.. They are junky and not heavy built enough to pull over with a pump attached...
    Oliver1655, DexterDay and the GOAT like this.
  5. the GOAT
    the GOAT Banned
    Maine
    Wedge/4 way design?? I can't decide which would be better.
    Fat single post -- or --
    Or skinny double post
    Well Seasoned and Stinny like this.
  6. Hedgerow
    Hedgerow
    SW Missouri
    Either will work good.. Just make sure you can hit a lever and get it out of the way... I gotta drop mine in and pull it out... A real PIA when you got a mix of nice stuff and junk...
    Also you can set it to the proper height to quarter any size piece.
    MasterMech and the GOAT like this.
  7. Stinny
    If your machine is going to have the muscle, why not set it up to go 4 way? Especially if you could easily pull a pin and slip the extra wedge up and off for big hard stringy stuff.
    the GOAT likes this.
  8. the GOAT
    the GOAT Banned
    Maine
    It's going to have a removable and hydraulic height adjustable 4 way. I'm going to make it so the wings drop down below the top of the beam like the 2nd pic.
    I'm just not sure if a wide or skinny main wedge would work better for the wood I split. I get a lot of knot filled yard trees from an arborist.
    The skinny wedge would probably slice through better but might be more likely to twist?
    Stinny and HDRock like this.
  9. Hedgerow
    Hedgerow
    SW Missouri
    I'd go thin if you want to use a 4 way behind it..
  10. jetjr
    jetjr
    Pa/Md line
    I agree with hedgerow I would go skinny. Mine has a skinny wedge and occasionally almost misses the short wings. I want to redo it just have not had the time. Also whoever made mine used beat up wedges for wings and on some occurrences the mushroom will cause problems. Gotta get around to cutting at least the mushrooms off.
  11. Gasifier
    :thumbs:Lookin good Mike!
    No. Not you. Your build man, your build! :D
  12. MasterMech
    Having a double post wedge like that second piicture, seems like an awful long disance back to the 4-way. Could be a pain if the wood is really nasty. I've used and liked the Timberwolf design but I don't remember having to remove the wedge to bypass the wings? You don't have to drop the wings below the beam to disable them, just lay them on top of it so the log rides over them.
  13. Oliver1655
    Oliver1655
    Central Missouri
    I used 1/2" thick, 8" x 8" flat mild plate for the 2 horizontal wings & an 8" x 12" piece for the upper wedge on my 4 way. I haven't had any problems with twisting.
  14. the GOAT
    the GOAT Banned
    Maine
    I spent a little quality time with my angle grinder last night
    I'm leaning towards a skinny wedge with a second post for the four way. The timberwolf one seems stronger and would probably work good on hardwoods that pop apart like oak... Just not sure how it would work on gnarly knot filled stringy rounds.
    If I'm wrong it easier to make it wider later.
  15. nate
    nate Banned
    Palmer, AK
    AR500 steel works great for a knife. I have easily 400+ cords on my processor and the knife is still brand new looking.
    jackel440, HDRock and the GOAT like this.
  16. the GOAT
    the GOAT Banned
    Maine
    I used a2 3/4 x 6" flat bar. If it wears too much I'll run some 7018 up it and grind it down again.
    basod and Stinny like this.
  17. the GOAT
    the GOAT Banned
    Maine
    Found my engine... Liquid cooled kawasaki v-twin, 16hp. NOS from ebay. image.jpg
    splitoak, MasterMech, basod and 6 others like this.
  18. Kevin in Ohio
    Kevin in Ohio
    Keep in mind the amount of side lean you may have with a hoist. I got around this by putting outriggers on mine as I built my splitter to handle the big ones. These also allow you to level it up so the boom/gravity doesn't fight you.
    Mine is not hydraulic. I use a cordless winch with a swing boom. This way I can drag and lift them into the splitter with a touch of a button. 30 ft of cable allows some pretty good reach. We normally just back down the length of the tree swinging the too large to hand lift round 180 degrees into the splitter. Wedge on the ram takes all the "swing" aspect out of it as it splits so think about that as well.
    Swing away tables are nice too as you have more options to never let a chunk hit the ground till it's split up completely. I split the table chunks, then swing the hanger back in to get it smaller. You might get some more ideas in my splitter build link below. Feel free to ask any questions as it may save you some redo's in the future. This one has worked out great for me and has done everything I'd hoped for.
    basod, HDRock, concretegrazer and 7 others like this.
  19. the GOAT
    the GOAT Banned
    Maine
    Got my engine delivered :). It didn't have a muffler and the dealer wants over $250 for one :(. So I had ordered a muffler for different kawaski engine on ebay for $30, the first half the part number was same so I was hoping the support bracket was all that would need to be changed.
    Close but not quite
    So time for a muffler mod. Figure I could Cut it out and slide the pipe over. image.jpg
    Plan b didn't work either
  20. the GOAT
    the GOAT Banned
    Maine
    A mig or tig welder would have come in handy ;)
