Log mule
Discussion in 'The Wood Pile' started by PullinMyPoulan, Jul 26, 2015.
  1. Canadian border VT
    used my heavy duty dolly for years now rounds go in bucket of kubota.. I love hydraulics! I can see a use for one if your situation warrants it. As for I have moved rounds thru sand because a small sand pit out back..... most time thru 4 to 6 inches of chips and and bark. that only get raked into bucket and burned when get to deep and I start tripping in them.... but hey I burned over 12 cord last year
    haveissues, Shawn Curry and Eric VW like this.
  2. HDRock
    One thing I see wrong with that one is,no wheel guards .
  3. Oliver1655
    Oliver1655
    Central Missouri
    This is the one from Harbor Freight I was referring to:
    Large rounds on edge will center on the center tubes. If you flip the round flat, going 3 high is only as much of a problem as you lifting the rounds up.
    Fill plastic totes with firewod level, you can stack them 3 high. Makes it easy to bring wood inside without leaving a trail of debris.
    I believe Hinerman's son has used it along with a couple of other 8-9 year old boys at charity cuts.
    • Heavy duty welded steel frame and 13 in. pneumatic tires can support a 600 lb. capacity load
    • Folding platform for easy storage
    • 51-3/4 in. height for tall load capacity and extra leverage
    • Extra wide toe plate measures 26 in. wide and 18 in. long
    While it lists for $150, it is almost always on sale for $99.99
  4. HDRock
    There ya go :thumbs:
    Eric VW likes this.
  5. haveissues
    haveissues
    Hudson Valley
    I'm with you. Someone would have to pry my diesel powered orange log dolly out of my cold dead hands.
    Eric VW and Stinny like this.
