log-lift firewood bags
Discussion in 'The Wood Pile' started by Nord, Apr 9, 2025.
  1. Wouldsplitter
    Wouldsplitter
    Illinois
    A good price would be free. LOL.. But near me $15 $20 per tote is the cheapest I've found.
  2. Elm-er Fudd
    Elm-er Fudd
    Kansas
    I don’t think you can get a face cord in them just tossed in or off of a conveyor I have to put a bit of a crest on the large ones to get a face cord stacked in them, but that is with nasty crap twisted elm that doesn’t stack well no matter what….but that is the main reason I use them…to keep my nasty elm stacks from falling over. Eventually I am going to start building 4-5 cord cages out of them and quit stacking all together.
  3. T.Jeff Veal
    The 330-gallon tote measures out to be .33 cord stacked tight, level with top.
    275-gallon tote measures out to be .30 cord stacked the same way. If tossed in, probably get quarter cord in it,
  4. Nord
    Nord
    Cote Nord, QC
    Great info, thanks!
    T.Jeff Veal and Screwloose like this.
  5. jrider
    jrider
    Is that a typo? 55 gallons larger and it only holds .03 of a cord more?
  6. T.Jeff Veal
    No sir, not according to measurements of basket.
  7. Jeffrey Svoboda
    Jeffrey Svoboda
    If my math and internet dimensions are correct.... a 330 holds 60 cuft and 275 holds 53.33 cuft. Hard to believe 55 gallons only equals 6.7 cuft.
    The dimensions i used: 330= 40 x 48 x 54.
    275= 40 x 48 x 48
    Or a 275 holds 51.11 cuft if it's only 46" tall.
    And a 330 holds 58.88 cuft if it's only 53" tall.
    If those are correct then 55 gal =7.77cuft
    Or 55 gal = 8.9 cuft if 54" and 46" are the correct heights.
  8. Jeffrey Svoboda
    Jeffrey Svoboda
    1.28 cuft would be 1% of 128 cuft.
    6.7 cuft = 5.23%
    7.77 cuft = 6.07%
    8.9 cuft = 6.9%
    Again, if my math is right that should be % of a cord.
    Obviously these are all outside dimensions. If T.Jeff Veal is using inside dimensions it'll be different.
    So maybe a 3% difference is possible.
    T.Jeff Veal and buZZsaw BRAD like this.
  9. Canadian border VT
    Ok but The gallon size comes from plastic tub inside of cage so actually smaller than inside measurement
  10. Jeffrey Svoboda
    Jeffrey Svoboda
    275 - 46" tall = 392.32 gal
    48" tall = 398.93 gal
    300 - 53" tall = 440.45 gal
    54" tall = 448.83 gal
    There're definitely some discrepancies when it comes to numbers. I worked with the ones i could easily attain. Obviously different if the totes where square in the corners.
    I suppose i could work it all out with these new gal numbers but.... I'm going dirt biking for the day. :tip:
  11. Stephiedoll
    Stephiedoll
    Omaha, NE.
    20241207_122825.jpg Just got to know how to load them.
  12. T.Jeff Veal
    Here is a 330 gal and 275 gal tote next to each other. Only difference is height. 330 is about 8" taller, length and width are the same. 1000018761.jpg
