LOCUST Quest!
Discussion in 'The Wood Pile' started by buZZsaw BRAD, Jan 13, 2020.
  1. buZZsaw BRAD
    I had thought of starting a fire to see how good the locust burns and rotisserie the deer leg. I hadnt had lunch and was hungry.
    No BBQ sauce with me either and i was on a mission to score wood!
    You might be a wood hoarder if you skip lunch to score wood!
  2. T.Jeff Veal
    I hear ya. That's the way I look at getting into the thick stuff with the ...:tractor:...
  3. farmer steve
    farmer steve
    top of the hill york co. PA.
    The boss asks me why didn't I come in for lunch? "I was busy cuttin(splittin) wood":dex:
    Felter, Slocum, T.Jeff Veal and 3 others like this.
  4. buZZsaw BRAD
    The quest was on for an hour this afternoon. Hit the score. Forgot my toolbox and had to run home as i needed the file to sharpen. Finished cutting the one tree and was able to get down to the rootball. Next tree a few feet away to the right. IMG_1759.JPG
    Was able to buck another "round" off the trunk i cut Tuesday. Maybe able to get another two but way too tangled to get at. Ive seen how strange BL is at ground level, but first time experience for me. Are these ever round at ground level? Ive seen some bizarre ones on FHC threads. IMG_1761.JPG
    Started working my way in on the second tree and it is still partly alive. The sucker limb is over an inch from 20 months of growth. Bark was tight on half of the rounds bucked on this one. IMG_1760.JPG
    About half a PU load...1/4 cord in an hour of cutting and loading. IMG_1764.JPG IMG_1763.JPG
    The stack prior to todays load. (Back row of the three is poplar) IMG_1757.JPG
    and after todays load. 45 minutes to split todays load. Not quite a cord yet. IMG_1766.JPG
    A few splits with bark still firm. Probably stack these separate. IMG_1767.JPG
    Quest load number five should happen tomorrow. Temps in upper 20's. Perfect in my book for hoarding! Im liking these smaller loads as im able to process right away and not roadside for another scrounger to take.
  5. MikeInMa
    Way to get after it, Brad!
  6. T.Jeff Veal
    Great job, as usual buddy...nice BTU's ..keep it going
  7. Oakman69
    Oakman69
    Mechanicsville
    Black locust is tops. Doenst smell the best but hey it heats the best and that's the best thing about it.. lol nice score
  8. farmer steve
    farmer steve
    All this talk of locust I had to go get some. A couple of dead off the ground tops and a couple dead standing trees. Thanks Brad
  9. buZZsaw BRAD
    Im so jealous...you can just drive into a field and cut the stuff up. I literally have to hack through a jungle and carry rounds out.
    All kidding aside, glad that im an inspiration. :salute:
  10. buZZsaw BRAD
    Didnt have much time today but did hit the quest for a half hour. Cold and windy with frozen ground finally.
    One tree top that was cut off (looks like it was the top that had hit the fence and back of the building) and pushed into the weeds. Bucked a few rounds off and sectioned remainder to carry to road. Started to buck by the front and saw a DPW truck drive by. Threw the lengths in the PU and beat feet.
    Put the 16" bar from the 290 on the 261 figuring less sharpening to do. Looked wierd on it as ive only used the 20" bar. Hard to believe a 16" bar is all i ever used on a saw up until two years ago. Seemed so small.
    The 16" cut a lot better and i think it was a semi chisel chain. The 20" was full chisel.
    Doubt ill have time to hit score tomorrow. Stuff to do before snow arrives late afternoon.
  11. T.Jeff Veal
    Why not use the 290? The semi chisel chain won't dull as fast, does cut slower in regular wood though.
  12. buZZsaw BRAD
    Good question about the 290. Guess ive really fallen in love with the 261. Much lighter and i guess you could call it my go to saw now.
  13. farmer steve
    farmer steve
    The tractor does help but I stihl had to hack through briars and vines to get to the stuff to get a chain hooked up to drag it out.. Plus some is down over a bank and in a little creek with rootballs attached.
  14. T.Jeff Veal
    I understand. Get that 290 to huskihl and get big bore XS done. It will change your mind...
  15. farmer steve
    farmer steve
    Faster chain speed with the 16" bar vs the 20. I only ran .325 chain on my 290.
  16. farmer steve
    farmer steve
    Got the last bucket out before the heavy snow later. Here's where I'm dragging stuff out of.
    Slocum, Woodwidow, Midwinter and 2 others like this.
  17. buZZsaw BRAD
    261 came with .325. What are the pros and cons of .325 vs. .375?
  18. buZZsaw BRAD
    chain on the base and pull away? The spot im working it'd be impossible. Brick pumping station building surrounded by a chain link fence with a 3' strip of grass on the perimeter then all weeds, wood, prickers, vines etc. The last tree closest to the road will be easiest, but dont quote me on that.
  19. buZZsaw BRAD
    Nice work BTW...go get that locust. Snow and starting a big job Monday will put my hoarding on hold.
  20. buZZsaw BRAD
    Do like i do...hum the "Mission Impossible" theme when hacking your way in to get to the rootball and/or hook up the chain! Any other wood any id be leaving it. Still cant believe what im going through to get this!
    Slocum, Aje1967, MAF143 and 4 others like this.
