Loaded truck pics.
Discussion in 'Chainsaws and Power Equipment' started by clemsonfor, Oct 7, 2013.
  1. clemsonfor
    Horkn likes this.
  2. lknchoppers
    lknchoppers
    Lincolnton, North Carolina
    2015-03-28 17.34.07.jpg The 1991 F250 I got about a month ago finally outfitted with side boards installed and it's first really heavy load of green Oak, Cheery and Elm. It squatted a bid but rode pretty good.
  3. cgraham1
    cgraham1
    Nor Cal
    I'm not sure. A buddy offered me some money for it and I took it. I probably should've kept it.
    It was an '87, with a 7.3 IDI and ZF-5 from a '94. With a Banks turbo, and 4.10 gears it would pull most hills in 5th gear, even with 37" tires.
  4. Drvn4wood
    Drvn4wood
    Greencastle, Pa
    Dry dirt under the grass. We loaded the dirt first then tossed the grass on top to take it for fill to my buddies house so I could unload in the reverse order.
    boettg33 and Horkn like this.
  5. tfdchief
    tfdchief
    Tuscola, IL
    Don't have that steering wheel play. I just don't have any complaints about this truck. It just hauls what ever I put on it.
    basod, Horkn, OhioStihl and 1 other person like this.
  6. Kevin in Ohio
    Kevin in Ohio
    Got lucky today and scored some free wood. Got it loaded and made it safely home without the cops pulling me over or it falling out of the bed. Didn't even notice any sag in the springs! ;)
  7. prell 73
    prell 73
    ia
    Nice ride
    DexterDay likes this.
  8. AJtree88
    AJtree88
    Who wants to park their truck under my conveyor? Lol I love when I can split a cord right into my dump truck. image.jpg
  9. prell 73
    prell 73
    ia
    Your set up rocks.
    Deacon likes this.
  10. clemsonfor
    Sure load me up.
    Can I bring my friends dump truck?
    HDRock, Horkn and Deacon like this.
  11. clemsonfor
    IMG_20150331_181004_651.jpg My share of last saturdays load. Truck and trailer was full of rounds. We also filled buddies f250 long bed. I left a small pile at his house from what was left over from splitting what was on me and we called it even. What I got in my short bed and the trailer and what was left off me and his truck was his half.
  12. DexterDay
    DexterDay Administrator
    Northeast Oh
    Me.....
    You are close enough..!
    I will be right out! ;)
  13. clemsonfor
    Here is a picture of a 1980 k10 thats a 4x8 tailer also. The truck definitely sags for whoever said old trucks dont. This is oak from a standing dead tree that just fell over recently. It was probably my dead 2 years. Still wet and solid inside but definitely lost a lot of water weight from green standing. It this was green standing oak you could set my truck 3-6"s lower in the back.
  14. Horkn
    Don't work it too hard now. ;)
    Sadly, you gathered more than I did today.
  15. Kevin in Ohio
    Kevin in Ohio
    With only close to 7 inches of springs on the rear I was afraid I was going to hurt it ;)
    I looked for one of these for 4 years till I came across this one. Didn't want a mega cab or 10ft bed but the price was less than what a 1/2 ton goes for around here. 4 wheel drive as well.
    This one just pulls trailers and such. the mighty 1/2 ton gets the woods hauls.
    greendohn, HDRock, OhioStihl and 8 others like this.
  16. Upstatewoodcutter
    Upstatewoodcutter
    Upstate NY
    Dad's truck loaded up with some old barn wood (white oak) What I don't use to finish the shed I'm cutting up for firewood, wood have been finished today but I ran out of hardware and I need someone to give me a hand with the cross member on top. Looking good so far though.:thumbs:
  17. clemsonfor
    Dang upstate are those pics from today? It was 80F here today!
    Horkn likes this.
  18. Upstatewoodcutter
    Upstatewoodcutter
    Upstate NY
    That's upstate Ny, was in the upper fourties and clear a good day to work outside. Tomorrow I'll be out again supposed to be in the fifties. Started with my jacket and hoody on , ended with nothing but a short sleeve on.:thumbs:
    Horkn likes this.
  19. lknchoppers
    lknchoppers
    I'm towing this home this evening.
    What kind of conveyor is that? Is it a corn conveyor or hay conveyor, I'm working on setting up a similar setup.
    WinonaRail and HDRock like this.
  20. AJtree88
    AJtree88
    That should work pretty good, you just wouldn't be able to go too high, which isn't neccesarily a problem. You make a mound too high and you can have mold issues in the middle. I make a platform out of pallets and split onto that. You get some air flow and drainage underneath, which is nice.
    My conveyor is a 30' hay conveyor. It was made in Ada, OH and has a 2 chain drive system with metal paddles. It's a little rotten and worn out, my chains jumps off the sprockets every time I use it, but I can put them back on in about 5 minutes. It's a little better these days since I put a 5hp Honda engine on it. I can run the speed a lot slower and chain a little tighter. It definitely saves time and some energy. You're not throwing every piece on the pile.
    The belt drive conveyors work pretty good, but the wood will slide back down in cold weather. Most firewood companies use a belt type. I imagine a corn conveyor would work well since it is a single chain and the V channel will guide the pieces.
    WinonaRail, Horkn and DexterDay like this.
