Loaded truck pics.
Discussion in 'Chainsaws and Power Equipment' started by clemsonfor, Oct 7, 2013.
  1. super3
    super3
    Indiana
  2. bigbarf48
    bigbarf48
    Stone Mountain, GA
    Now that's a full load!
    Drvn4wood and clemsonfor like this.
  3. cgraham1
    cgraham1
    Nor Cal
    On the older 4x4 trucks (before '97), the F-250's had leaf springs in front where the F-150's were coils, and they had 8 lug axles that were much bigger/stronger, bigger brakes, and the rear springs would hold a lot more weight. The 150's and 250's were Twin Traction Beam (TTB) front ends while the F-350 had a solid axle Dana 60. There's a ton of little differences and configurations that would take many pages to cover...
    I prefer 1 ton, crew cabs with Diesel engines and manual transmissions. Im kind of picky about my trucks.
    concretegrazer and clemsonfor like this.
  4. OhioStihl
    OhioStihl
    Southern Ohio
    Super3, I like your style!
  5. super3
    super3
    Indiana
    Same here.
    If yer comin home bring a load.
    Yours looks like they carry the load a lot better than my ole 1/2 ton. I'm only driving from the woods to the barn though.
  6. MasterMech
    There were 2 F250's for that series, a F250 LD (or light duty) and the F250 Super Duty. The former is likely to share a lot of parts with your F150 (and looks just like an F150), the latter is closer to an F350. There also was a F150-7700 (GVWR was 7700lb IIRC) which is the same thing as an F250LD just different badges.
    Air bags are a great way to level out a sagging suspension on half-ton pickups. ;)
    I have never seen such a vehicle. Doesn't mean it didn't exist but I've yet to see one and I see lots of trucks. ;)
  7. MasterMech
    Short bed trucks are better at picking up dates than construction materials. ;)
  8. clemsonfor
    I was talking about that f250LD the one that looks just like an f150..its the most likely to have the springs.
    I think tje problem is going to be the setup and the short bed and the frame on that truck. Thats gonna be the issue with off the shelf 250 springs i think. They could be the same size wont know till you tape it. And like i said they make add a leafs that you add into the pack or slip under it they make overload springs and just replacement springs in general to get morecapacity with less sagging.
    But i
  9. mikey517
    mikey517
    Highland Lakes, New Jersey
    This load from this past Tuesday...
    This load of Sandy ash is from April...
  10. Drvn4wood
    Drvn4wood
    Greencastle, Pa
    I don't know what it is about Ford rear suspensions but I'm not impressed. I bought a new 13 f-250 last October and the suspension sag was ridiculous for a truck rated at 10k gvw. I started by adding a leaf which helped but not enough. The added one is third down from the top. Finally added air bags and I'll never be without them. These are the Firestone ride right bags and I can have the trailer maxed out with the truck bed full of wood and it still has a little rake to it. If you're gonna keep the truck a while I'd go with the bags. I had the valve run to the back and inflate them with a 12v compressor from wal-mart - works great. The leaf was a waste for me in my opinion. 1413461676326.jpg 1413461721748.jpg 1413461772513.jpg
  11. Gasifier
    Very nice Drvn4wood! :yes:Except I can't see the whole truck. :binoculars:
  12. Gasifier
    Hmmm. Well, I tried to copy and past a picture of that F150 that I put the F250 springs on from "another" site I had it on and that didn't work right. Looked right when I copied it over. Sorry about that guys.
    Let's try this. She was a good worker!
  13. Kevin in Ohio
    Kevin in Ohio
    Don't try this at home, professional drivers were used on a closed course. ;)
  14. Machria
    Machria
    Long Island, NY
    Wow, didn't know that, and whoever told me that years ago must have had bad intel... Just goes to show ya, looks can be deceiving. Although maybe we were looking at the F250LD talked about below.... ?
    Yea, maybe the LD was what he was talking about..... Was there an F250LD Super Crew model?
    I'll have to look into "air-bags", I know nothing about them.... the only problem I might have is, I live on the water (SALT water), and thing rust VERY quick. My road often floods with salt water from Nor' Easter storms, so I often drive through 2' of salt water to get out or home. So if I install a compressor, it would need to be high and dry somehow...
    I've had a a longtime love/hate relationship with my F150 Screw! On one hand, I blew the tranny at 36k after 3 years. The warranty covered tranny to 35k, ford told me to take a walk! Big money to replace! Then at 65k I started blowing plugs out of the head, 2 or 3 healacoils (sp?) later, I had to replace the entire head, $3,500 big ones. Ford told me, and several hundred thousand other blown heads at low mileage to take a walk again!! But then there is the fact the truck is now 14 years old, and still going strong, and looks great. Most people think she is a fairly new model until they look very closely. She has 135k on it now, so she doesn't get much mileage on it. I stopped "driving" it about 7 years ago, and only use it for hauling... But she runs perfect (knock knock knock on wood!), looks great and works fine for my light duty usage.
  15. bigbarf48
    bigbarf48
    Stone Mountain, GA
    Ya know, they make trucks that arent 1/2 tons right? :rofl: :lol:
    Nice loads though :yes:
  16. Machria
    Machria
    Long Island, NY
    By the way, you guys are KILLING me with these pictures of HUGE loads!! I would have to make three or FOUR trips to match some of these loads!!
  17. Kevin in Ohio
    Kevin in Ohio
    They make them bigger than 3/4 ton as well ;)
    The old 1/2 ton just keeps on plugging along though so it knows it's roll. Just a woods truck now.
  18. Machria
    Machria
    Long Island, NY
    WOW!! Kevin, what is the red one?????
    I WANT it!!! No, no, no I NEED IT!!!! For sale??
    Kevin in Ohio likes this.
  19. bigbarf48
    bigbarf48
    Stone Mountain, GA
    Nice kevin :thumbs:
  20. Gasifier
    Nice trucks everyone.
