Loaded truck pics.
Discussion in 'Chainsaws and Power Equipment' started by clemsonfor, Oct 7, 2013.
  1. bigbarf48
    bigbarf48
    Stone Mountain, GA
    New sideboards. Truck didn't even bat an eye at this load of oak :D
  2. clemsonfor
    My short bed trucks just can't hold the weight. I want 3/4 ton springs.
    wildwest likes this.
  3. Oliver1655
    Oliver1655
    Central Missouri
    Don't play around Clem, go for 1 tome with overloads. Air bags are hand also.
    concretegrazer likes this.
  4. bigbarf48
    bigbarf48
    Stone Mountain, GA
    They're nice to have. After doing all my wood hauling with a bronco (1/2 ton f150 suspension), the difference is night and day. The w250 was barely squatting and that load ended up being almost 3/4 cord
  5. MasterMech
    I don't think the axle in his K10 will handle enough load to make the log wagon ride of the 1 ton spring packs justifiable. :BrianK:
    clemsonfor What are you waiting for? There's a few thousand rusty C/K20's just waiting for you to rob the rear springs off them.
    clemsonfor, Drvn4wood and wildwest like this.
  6. wildwest
    We have (had) 99' F250 , he sold it to his company. 7.3 engine? It's closing in on 400K miles and still running strong even with heavy loads. Replaced too many things over the years but its still reliable and pulls great despite the orig engine. PS, its a standard transmission if that matters. I heard the 7.3 is one of the best ford diesels, dear husband would jump on it if it was in our area, as they don't make them anymore. It has a giant fuel tank for long runs too.
    papadave and concretegrazer like this.
  7. cgraham1
    cgraham1
    Nor Cal
    I kept my K10 a six lug, but I upgraded the rear end to a 14 bolt semi-float out of a '94... I had to move the spring pads and shock mounts, but it's way bigger than a 10 or 12 bolt and I like the extra track width. It matches the front and still drives down the road just fine. I wish I had better pics...
    ... It's the same size rear end as the 80's era 3/4 tons.
  8. Drvn4wood
    Drvn4wood
    Greencastle, Pa
    I installed the firestone ride right bags on my super duty and highly recommend them. Even with the bed full of wood and a thousand pound tongue weight on the hitch it rides level or even a little above level.
    concretegrazer and Oliver1655 like this.
  9. RParrotte
    RParrotte
    Saranac, NY
    97 F-350 powerstroke with a 5 speed manual
    Gasifier, greendohn, basod and 11 others like this.
  10. bigbarf48
    bigbarf48
    Stone Mountain, GA
    That thing is nice! Bet you like the dump bed huh
    RParrotte and Oliver1655 like this.
  11. lknchoppers
    lknchoppers
    Lincolnton, North Carolina
    1986 C20 3/4 Ton Chevy. This thing can handle some heavy loads. I just put these side boards on it so I can haul a cord when I stack it in. 2014-10-08 18.01.53.jpg 2014-10-04 11.13.14.jpg
    ^^^ This is a split cord stacked in there.
  12. bigbarf48
    bigbarf48
    Stone Mountain, GA
    Our trucks might be cousins lknchoppers :rofl: :lol:
  13. clemsonfor
    Way cheaper to rob the 3/4 ton springs out of a junkyard truck as MM recomended.
  14. Machria
    Machria
    Long Island, NY
    How is that load not tilting the back end down?? My azz end would be on the ground with that much wood in it!
    clemsonfor likes this.
  15. Drvn4wood
    Drvn4wood
    Greencastle, Pa
    I added springs too.
  16. Drvn4wood
    Drvn4wood
    Greencastle, Pa
    It started out as a 3/4 ton F-250 but with the springs and air bags I don't know what it is now. Maybe a 1.58 ton. :vulture::vulture: I just really wanted to use this bird..
    concretegrazer and clemsonfor like this.
  17. clemsonfor
    [QUOTE="Drv4wood, post . :vulture::vulture: I just really wanted to use this bird..[/QUOTE]
    Thats ok i like to use these whenever possible.:axe::dancer::dancer::dancer::rootintootin::rootintootin::rootintootin::saw::saw::ups::ups::ups::banana::banana::banana::banana::banana:
    Drvn4wood and bigbarf48 like this.
  18. cgraham1
    cgraham1
    Nor Cal
    Very thick spring packs and overloads. It rides pretty rough when unloaded, but only sags a couple of inches when loaded up heavy like that. More bad pics... image.jpg image.jpg
    Gasifier, basod, clemsonfor and 3 others like this.
  19. Drvn4wood
    Drvn4wood
    Greencastle, Pa
    Now that's a spring pack.
  20. redneckdan
    redneckdan
    Northern Minnesota
    Those lift blocks, my eyes! My eyes! :BrianK:
