Loaded truck pics.
Discussion in 'Chainsaws and Power Equipment' started by clemsonfor, Oct 7, 2013.
  1. Mwalsh9152
    Mwalsh9152
    Pelham NH
    I've been saying I need to make some plywood covers for my side windows so I can fit even more, but its definitely a PITA having to climb in and stack the wood over and over. 20181201_135939.jpg
  2. The Wood Wolverine
    Another one this evening.
  3. The Wood Wolverine
    3 nights in a row. I’m beat!
  4. amateur cutter
    Maybe right now, but some cold winter's night when the house is warm & the heat bill is zero you'll feel pretty good. Nice work!
  5. The Wood Wolverine
    That perked me right up. You nailed it. This stuff is primo!
    Not much left either. That’s a 6’ pry bar.
    I hit a little metal which really took the wind from my sail. I had just freshened up my chain. Didn’t hurt it much tho.
    Stlshrk, GrJfer, T.Jeff Veal and 13 others like this.
  6. amateur cutter
    Yep, that is a big s.o.b. I figure a chain every now & again is just the cost of doing business. Still a bummer though.
  7. The Wood Wolverine
    Last load was a biggin!!
    Stacked it in there pretty good.
    90lbs in the airbags and it was still saggin’.
  8. Ohio
    Not Ohio
    Got me a load of persimmon.
  9. OhioStihl
    OhioStihl
    Southern Ohio
    The truck is loaded with the wrong kind of wood. I’m removing an old deck and taking it to the dump.
    Stlshrk, Thor, amateur cutter and 9 others like this.
  10. eatonpcat
  11. Ward Hoarder
    Ward Hoarder
    West Virginia
    I have never seen a persimmon that big. Usually 3-4" in diameter.
  12. Ohio
    Not Ohio
    I have a persimmon on my property that is probably 14 inches across, if I come to think of it the next time I'm down in the ravine where it is ill take a picture of it.
  13. Ohio
    Not Ohio
    Ok, I couldn't help myself and I went down to the ravine to take a picture of the persimmon tree. Its much larger than I thought.
    Stlshrk, Thor, Boogeyman and 10 others like this.
  14. OhioStihl
    OhioStihl
    Southern Ohio
    You could use a trailer just to haul those saws around. That’s a whole lot of bar and chain.
  15. OhioStihl
    OhioStihl
    Southern Ohio
    I’m loaded and ready for the dump. I could have put more wood on the back but it was a good stopping point. The sides were repurposed and are in rough shape, they might go in the dump with the rest of the load. I want sides that don’t spread out so much.
    WinonaRail, Stlshrk, Thor and 11 others like this.
  16. eatonpcat
    Keep the sides, they look ok!
    What is the dump fee for all that?
  17. The Wood Wolverine
    Was a whole lotta tree!!
    WinonaRail, GrJfer, Dancan and 10 others like this.
  18. OhioStihl
    OhioStihl
    Southern Ohio
  19. OhioStihl
    OhioStihl
    Southern Ohio
    $25 a ton. It’s worth it too.
  20. T.Jeff Veal
    Nice. I know it's a pain to have to stack under the cap...makes my back hurt thinking about it.
