Loaded truck pics.
Discussion in 'Chainsaws and Power Equipment' started by clemsonfor, Oct 7, 2013.
  1. Camber
    Camber
    Montana
    Did you read the part about the extra tolerance? Sheesh! It is a long bed, without a toolbox. It will haul wood in the Rockies. Is your avatar a spoof?:rofl: :lol:
    eatonpcat likes this.
  2. clemsonfor
    And lots of tractors also
  3. clemsonfor
    Yea I read about the tight tolerance. I am a self taught backyard guy. Is seems against my logic. Wouldn't you want a thinner oil for tighter tolerences? Which is why older engines used 10w40 vs newer tighter tolerences engines that run 5w20? I'm really asking more as I am stating something that seems logical to me.
    A 2015 engine has way tighter tolerences than a 1975 motor.
  4. Camber
    Camber
    Montana
    I'm terrible at explaining. Sorry. The clearance between things is bigger.
  5. Camber
    Camber
    Montana
    The engine is sloppy. Years ago, most of our tractors gas. Every few years the engines got broke down. The nice thing about sloppy motors, anything that gets past air filter, the chances of extreme piston destruction are less. Down side is no power. Less effecient ect. But, in that application it becomes minor. I don't care for how he set the motor up, but the truck is perfect for me. I'm not a kid that jacks up his truck, then rods it out. It is a work truck. Does that make more sense anyway?
    clemsonfor likes this.
  6. Boomstick
    Boomstick Banned
    Saratoga county ny
    Gotcha! it's common to use what ya got!
    Flat tappets are fine, they just aren't quite as good for agreesive lobe angles but for the application it's good to go.
    You could *probably* get away with synthetic but not worth the risk.
    It's been 10+ years since I've needed zinc oils changed alot since then.
    I still remember lead gas additive!!!!
    What's funny is most modern engines burn oil(the manual says it's normal!), or piston slap. Almost every one of em. Not the old chevy 350s!!
    p61 western, clemsonfor and Camber like this.
  7. Camber
    Camber
    Montana
    You nailed it. Engine builder with his own shop for years. You know he had cams and about everything in old stock. He told me. Nice guy. Without that zinc, there is not much protection. I'm just glad he was honest enough to let me know. I dropped the break in oil a couple days ago. Ofcourse the stock oil pressure gauge kinda scares you.
  8. clemsonfor
    Oh ok , makes total sense if the tolerences are big.
    I was thinking cause this guy was some race car engine tech or whtever he had this thing miked down super close and had everything really tight.
  9. blacktail
    blacktail
    PNW
    Where have I heard that before? Oh yeah, from nearly every person who owns one of those.
    brenndatomu, clemsonfor and Camber like this.
  10. In the Pines
    In the Pines
    Here is a few from 4 years ago, I'll have some more recent ones soon.
    WinonaRail, Bert, leoht and 15 others like this.
  11. Camber
    Camber
    Montana
    Perfect!:dancer:
    leoht, clemsonfor and eatonpcat like this.
  12. Breechlock1
    Breechlock1
    Forgive the Chevy. As a Ford guy it pains me to say I switched from a rwd 5speed f250 to a Silverado 1500 4*4. But I got a deal ($1650 with new tires brakes, brake lines, I'm 3rd owner with full service history, 5.3 L 140k) . Can't haul as much as the f250 but I can use it more often being 4x4. I can also get all three kids and the wife in it, unlike my danger ranger . This is my second load of white oak.
    ETA I've got new rockers, corners, fender patches, and a helper spring set on the way.
  13. clemsonfor
    That was a smoking deal. I have a ford Chevy and toyota SUVS I am not brand loyal. I like ford and Chevy equal.
  14. Mwalsh9152
    Mwalsh9152
    Pelham NH
    It isn't pretty, but that's a great buy for sure!
  15. 94BULLITT
    94BULLITT
    Frederick County, VA
    I bought an F-250 diesel a month ago. There is a rebate on Mobil Delvac oil. I got 6 gallon jugs because that is all the store had. Then I was there another time and they had four 5 gallon buckets, so I got them all. After rebates the 5 gallon buckets work out to $1.25 or $1.50, I can't remember. That is crazy cheap for diesel oil.
    VR1 is not a true high zinc oil. It still meets API specs. For it to be a high zinc oil it would not. For a high zinc oil you need something like Joe Gibbs oil.
    Camber and brenndatomu like this.
  16. Camber
    Camber
    Montana
    VR1 is not a true high zinc oil. It still meets API specs. For it to be a high zinc oil it would not. For a high zinc oil you need something like Joe Gibbs oil.[/QUOTE]
    Yeah, but Tony Stewart is a jerk, and how do you explain that kyle bush kid also. Not much of a coach.........Just kidding.
    I picked up a zinc additive also. Thanks for the heads up. I'm glad to have looked into this history on oil.
    clemsonfor and 94BULLITT like this.
  17. Mwalsh9152
    Mwalsh9152
    Pelham NH
    1.25 per gallon, or per pail? I'd be buying it up to use as fuel if it was per pail!
  18. 94BULLITT
    94BULLITT
    Per gallon
    Edit: I just looked it was $24.99 for 5 gallons, $.62 a quart. I guess I was getting mixed up with the gallon price.
    Here is the rebate. I am not sure what all stores are participating.
    $60 Off Mobil Delvac™ 1300 Super | Mobil Delvac™
    brenndatomu and clemsonfor like this.
  19. Mwalsh9152
    Mwalsh9152
    Pelham NH
    I have 4 gallons of Delvac in the basement for the Bronco as we speak. Back when I cared, I used to use Valvoline premium blue extreme synthetic. Now I use whatever is cheapest, but not garbage
  20. 94BULLITT
    94BULLITT
    I use Valvoline premium blue in the tractors, got a bunch on sale when it was 9.99 a gallon. I was not sure what I was going to run in this truck, then I saw this deal on the Delvac. The main thing is use a quality oil filter.
