Live from the 2017 MI GTG @ Backwoods Savage's
Discussion in 'Everything Else (off topic)' started by bocefus78, Apr 20, 2017.
  1. raybonz
    raybonz Moderator
    Carver, Mass.
    Think you stepped in $hit better check your boots!
    Thor, Scotty Overkill, Horkn and 10 others like this.
  2. raybonz
    raybonz Moderator
    Carver, Mass.
  3. Redneck
    Redneck
    Burton mi
    It gets better a 4.00 spark plug and its running:dancer:
    Thor, Scotty Overkill, Horkn and 16 others like this.
  4. cwn877
    cwn877
    Central Pa
    My phone says 49°. We have a slight wind and intermittent sun.
  5. Well Seasoned
  6. Eric VW
    BrianK's rocket still cranking....
    Heat waves:
    Thor, Scotty Overkill, Horkn and 18 others like this.
  7. Well Seasoned
    Thor, Scotty Overkill, Horkn and 13 others like this.
  8. My IS heats my home
    My IS heats my home
    Albany, NH
    And it burned fairly Clean from the start
    Thor, Scotty Overkill, Horkn and 12 others like this.
  9. wildwest
    Sit back and relax gentleman and CFG, Mrs VW in charge tonight, yep, cut, split, and now stoking.
  10. BrianK
    BrianK
    West central PA
    It started smoking within the first 5-10 minutes and I thought something was wrong. But it was already hot enough to burn off the paint on the side of the barrel. I had used the angle grinder with a wire wheel to clean the paint off the top to bare metal but not the side, and this riser is next to the side of the barrel, not centered: IMG_0716.JPG
    Thor, Scotty Overkill, Horkn and 21 others like this.
  11. HDRock
    Well, I can see some pics anyway :)
    Is there a splitter or two coming to take up the slack ?
    Thor, Scotty Overkill, Horkn and 11 others like this.
  12. HDRock
    Thor, Scotty Overkill, Horkn and 8 others like this.
  13. Unicorn1
    Unicorn1
    Amarillo, TX
    Have a great time and be safe.:)
  14. Eric VW
  15. yooperdave
    And....firing up!
  16. yooperdave
    All the time!
  17. Locust Post
    Are you into the good oak yet or is that for the wee hours ?
  18. UncleJoe
    UncleJoe
    SC Pa
    Nice fire!! :fire: :MM:
  19. Well Seasoned
    All the time
  20. TurboDiesel
    Oh yeah.
    Thor, Scotty Overkill, Horkn and 9 others like this.
