Handshake to you all. Heavy snow here in SW VA. I’m ready to hook up my insert as soon as the weather breaks. I removed the gas logs and noticed the brickwork on the floor of the hearth is lower than the rock outside. I think it will be uneven when I slide the insert in place. Do any other you know of a source for leveling bolts for a fisher insert. Thanks for your help. Sent from my iPhone using Tapatalk
This is not an answer to your question, but could you throw a couple small pieces of plate steel of the appropriate thickness under it?
I found a solution that works perfectly. I have a 30 year old craftsman table saw. I used two of the feet off of it. Cleaned the rust off of them and ran a die down the threads. Also chased the threads on the 1/2x13 threads on the insert. Looks just like what is pictured in the manual and works very well. Sent from my iPhone using Tapatalk
