Leaner hickory, not for the newbie
Discussion in 'The Wood Pile' started by Woodsnwoods, Apr 3, 2017.
  1. Jon_E
    Jon_E
    Southwestern Vermont
    I wouldn't mind a challenge like that. There's not much holding that stump to the ground though.
  2. Mag Craft
    Mag Craft
    South East Wyoming
    That tree looks to be hung up pretty good. I think the only way it is coming down is to pull it down.
    I would face cut toward the lean and back cut so the bottom is loose and then pull it down. Position yourself up hill and cut it close to the bottom. Then pull it from the bottom.
  3. RCBS
    RCBS
    Over here
    At least you have gravity on your side!
  4. Oldman47
    Oldman47
    Illinois
    The way the stump end is split in almost a barber chair I would not go near that thing with a saw. There is a lot of energy stored in that split.
  5. Casper
    Casper
    Not a tree, but a 1 liter bottle staked 1' in front of a washer. Tannerite is fun, but you don't want stuff coming back at you. We found a side panel 100' in the field to the right. Motor was just behind the backstop.
  6. Boomstick
    Boomstick Banned
    Saratoga county ny
    So many dittos I was literally thinking I'd tannerite that sumabeaoch...I'd put water jugs or a blatter around it to direct the blast!
  7. Mag Craft
    Mag Craft
    South East Wyoming
    I would.
  8. Casper
    Casper
    Looking at his terrain, I'd give Tannerite a serious/probable thought. Maybe even setup a couple targets on the trees that it's hung up in.
    Woodsnwoods, Horkn and Hammy like this.
  9. brenndatomu
    Full auto rifle...cut 'er right down! :whistle: ;) :yes:
  10. Backwoods Savage
    I would probably cut it but won't give advice here for sure except to say that a 2 ton come-a-long would not do the trick for me. Too small; too slow.
  11. bogydave
    I like the "Outside the box " thinking
    shoot the roots :D
    Hellcat, Woodsnwoods, Horkn and 2 others like this.
  12. brenndatomu
    Cut 'er mostly down with the rifle, and then the "final cut" with load of Tannerite...for a grand finale! :rootintootin: :ithappened:
  13. bogydave
    One really good way would be
    Call "Scotty O "
    :yes:
  14. Sequoia
    Sequoia
    Cut the maple so that they both fall in the same direction. The idea is that the maple will pull the hickory.
    Put a back cut on the hickory to allow a stress relief. Either a notch or one cut.
    Woodsnwoods and Hammy like this.
  15. RCBS
    RCBS
    Over here
    Use less reactive target (1lb) and put *inside the washer before shooting. It might take a couple tries shooting "blind" but when you make contact...wow.
    Myself and some friends have done extensive "testing & research" on the matter. :) Stoves with lockable doors are my favorite. We have a device that will put a bowling ball 100+ yards into the air using 1lb.
  16. Casper
    Casper
    Is CampyBob part of this group?
  17. RCBS
    RCBS
    Over here
    Not familiar with CampyBob. Sounds like a good man though if he too likes to dismantle appliances through percussive means!
  18. thistle
    thistle
    Polk/Guthrie Counties,IA
    Whatever you decide on doing - be absolutely safe first & foremost.
    And DON'T be like this guy.....:hair:
  19. mr.finn
    mr.finn
    Mass
    It looks like if it falls(if you do decide to cut it) it will get hung up in the Oak that is behind the crappy maple.
  20. Spencer
    Spencer
    Indiana
    Good luck, let us know how it goes!
