Lawnmower Repair
Discussion in 'The DIY Room' started by KatwillNY, Sep 11, 2014.
  1. KatwillNY
    KatwillNY
    As the summer is coming to a close in the NY area, I decided to perform maintenance on my old Troy Bilt mower today. Over the last month the self propelled feature had all but stopped working and it was idling very rough, sputtering and shutting off on me in mid cut. It was progressively getting harder to start it up, what was a single pull start had become a 5 to 10 pull only to run for about 5 minutes then shut off. So upon further inspection I discovered a host of issues with it.
    1- Both the Blade control cable and the Drive cables were in bad shape. Both replaced.
    2- The carb was full of gunk and build up. Took the entire carb apart and cleaned with with carb cleaner, almost lost the needle since I was doing this outside and needle was on top of a napkin and a gust of wind came. ARRG, finally found it about 5 minutes later
    3-Air filter was dirty. Replaced it
    4- Spark was burn pretty bad, replaced it.
    5- Blade belt was in bad shape, replaced it.
    6- Blade was very dull, but overall in OK shape, sharpened it.
    7- The Governor spring was shot, replaced it.
    8- Gave it a really good cleaning and WD40D (yes that's a verb in our household). The Troy Red looks brand new.
    I got all of the parts from Ereplacement parts and all arrived in 2 days. Less than $80 dollars and the mower is working as well as it did 10 years ago. I almost gave up on it and purchased a new one, but I really like this mower and I try to not subscribe to the buy new, I try to fix it just to say I did. I get satisfaction from making old new again, or at least in working order.
    Im sure to most this is routine but for this desk jockey IT Application Specialist, this was hard work. LOL.
  2. jetjr
    jetjr
    Pa/Md line
    Good job. I hate all the throw away stuff they make these days. Cheaper to buy new junk than replace almost new junk.
  3. Woodwidow
    Good job on the repair.
    campinspecter likes this.
  4. My IS heats my home
    My IS heats my home
    Albany, NH
    Glad to hear the good results on keeping your mower in good working order. What's next?
  5. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    Good work . This thread is a good reminder for seasonal maintenance. I need to re-sharpen my blade for leaf mulching season. I've read somewhere to check the balance of the blade once re-sharpened to reduce blade wobble issues.
  6. Stinny
    Good job Kat. Well worth the effort. Not only does it run better, but prolly cuts a lot better too... :yes:
    It's just so sad tho... the work never happened cause I don't see any pics... :whistle:... :ithappened:... :D
  7. basod
    basod
    Mount Cheaha AL
    Yep just balance it on screwdriver take a little more off the side that drops
    fishingpol, jetjr and Stinny like this.
  8. KatwillNY
    KatwillNY
    Yes, i should have taken pics of the ordeal but I didnt think of it until after. Cleaning out the carburetor would have been a good video for me to take, Ive never done that before and it would have been nice to keep as a keepsake. LOL.
    Stinny and basod like this.
  9. Stinny
    Next time... just duct tape your camera to your forehead... :ithappened::D
    jetjr likes this.
  10. KatwillNY
    KatwillNY
    Ha ha ha, I have a helmet cam that I use when in riding my bicycle. Next time.
    Canadian border VT and Stinny like this.
  11. Stinny
    :yes:
