Lawn/Garden Tractor for hauling?
Discussion in 'The Wood Pile' started by saewoody, Jan 25, 2019.
  1. billb3
    Going in the woods with a mower deck on can be a PITA.
    Some hydro lawn tractors can like to slip backwards on a hill without some power sometimes.
    I used to prefer my old gear mower with the deck removed for going in the woods, but alas the engine started blowing oil bad and I was too busy at the time to get after it. It sits now sadly.
    BigPapi, Chaz, Screwloose and 6 others like this.
  2. ReelFaster
    ReelFaster
    S.Jersey
    Good point!
    BigPapi, Chaz, saewoody and 4 others like this.
  3. Erik B
    Erik B
    Western Wisconsin
    The path in my woods was cut to let my JD garden tractor thru without getting hung up. I run the mower to keep weeds and small bushes from taking over the path. I also have areas where grass grows in the path and it is nice to keep it knocked down.
    BigPapi, Chaz, Horkn and 4 others like this.
  4. bear 1998
    bear 1998
    S.C.Pa
    Keep the one you have to mow....find another to pull your goodies. Keep your eye on CL ,Facebook Marketplace,Etc.
    There are pretty descent deals out there.
    I ended up payin 800.00 for the Kubota thats posted earlier. It came with a mower deck n the blade thats on it now.
    Sold the deck for 350.00...so thats 450.00 for the tractor. Its a 1987 model n its in very good condition....900hrs.
    BigPapi, Chaz, Horkn and 6 others like this.
  5. Horkn
    We would always start haulng in the woods in fall and spring before the grass started growing, and the snowblower attachment wasnt on the front. Tons of clearance with no mower or blower on.
    Towing a bass boat is no issue for a garden tractor.
    That said, a 4 wheeler will do all firewood work and hauling anything easier than a tractor.
    BigPapi, Chaz, saewoody and 5 others like this.
  6. Mitch Newton
    Mitch Newton
    Beavercreek, Ohio
    Yup, I can smell the belt burning.
    BigPapi, T.Jeff Veal, Chaz and 4 others like this.
  7. bear 1998
    bear 1998
    S.C.Pa
    Chaz, saewoody and Screwloose like this.
  8. ReelFaster
    ReelFaster
    S.Jersey
    Sound advice bear 1998 , thanks!!!
    Good to know on towing a bass boat with a garden tractor! I am leaning 4 wheeler, I can do everything I want to do with it plus have a little fun with it as well. I promised I wouldn't buy anything until I have a sheltered home for it.
  9. Horkn
    You can get a nice cover until you get a roof over it.;)
    Screwloose, BigPapi, Chaz and 2 others like this.
  10. ReelFaster
    ReelFaster
    S.Jersey
    CURSE you HORKN for planting that seed in my head :rofl: :lol::rofl: :lol:
    Screwloose, BigPapi, Chaz and 4 others like this.
  11. Buttercup
    Buttercup
    Tennessee
    I’ve got a cub cadet 102 that I use some. If you’re looking for something garden tractor sized a powerking is the way to go. Also as I’m sure people have said is a farmall cub or Allis chalmers b or something like that.
  12. saewoody
    saewoody
    Central CT
    View attachment 196042 View attachment 196046 View attachment 196047
    Got the green one running this afternoon. Was thrilled to hear it turn over. I expected it to die, but it just kept running! I couldn’t get it to even cough when I messed around with it the other day. Today I got a strong battery hooked up to it verified I had spark, but still nothing. Gas smelled ok, but it wasn’t firing, so I opened the carb bowl and a bunch of fuel poured out. I gave it a shot of ether to see if I could get anything and it fired right up and just kept running. Throttle response is good. That’s all I had time for today. And it’s back to winter tomorrow.
    Sent from my iPhone using Tapatalk[/QUOTE]
  13. saewoody
    saewoody
    Central CT
    So I’ve been away from my thread for a while. In the meantime I’ve managed to acquire a third tractor. A friend at work essentially gave it to me. It’s about a 10 year old or less Cub Cadet with the bagger and a plow attachment. I was told it needs some TLC; I think it needs its drive belts replaced and a good cleaning and it should be good to go. It stops when going up a hill, but the moment you lift off the gas and reapply it starts moving again. [​IMG]
    The red tractor needs a little bit of work on the steering box gear and a carb cleaning and that should be good to go. And also a starter solenoid that was good and then just went bad without warning.[​IMG]
    And the green tractor just needs a fuel pump rebuild I think. And then it should be good to go. I think that’s the one I will keep for a pole in the wood car around the yard and I will sell the others.[​IMG]
    Looking forward to getting the extra tractors out of the yard. Not really a lot of room for stuff like this in our suburban lot.
    bear 1998, Screwloose, Horkn and 2 others like this.
  14. Screwloose
    Screwloose
    One of my cases with the front hitch.
  15. Erik B
    Erik B
    Western Wisconsin
    Screwloose Do you have a close up pic of the front mounted ball on your tractor that you could share? Thanks
    saewoody, bear 1998 and Screwloose like this.
  16. Screwloose
    Screwloose
    I had this one on my phone. I just cut a mount out of a chunk of channel and bolted it to the mower deck mount.
    Thor, Boogeyman, bear 1998 and 2 others like this.
  17. saewoody
    saewoody
    Central CT
    That’s a nice looking tractor! Thanks for sharing. Ideally that is more like something I would like to end up with. There is a really nice looking Gilson I’ve had my eye on on Craigslist. [​IMG]
    Screwloose and Boogeyman like this.
  18. Stephiedoll
    Stephiedoll
    Omaha, NE.
    Picked this up in Feb. and been getting snow ever since. 2 blowers and 38" deck. Seems to be running well.
    saewoody, Screwloose and Chvymn99 like this.
  19. Screwloose
    Screwloose
    Gilson used to supply Monkey Ward's ope. Pretty solid stuff imo.
    saewoody and Thor like this.
