Kuuma vapor fire 100
Discussion in 'Modern EPA Stoves and Fireplaces' started by Sluggo, Feb 15, 2021.
  1. Rush Battle
    Rush Battle
    WNC
    I’m in a similar situation, but my plumbing run would not be far at all. I need the HPWH for cooling and dehumidifying in the summer, so it would have to be a combo of HPWH, propane WH as a storage vessel and backup heat with recirc loop using the furnace as primary heat in the heating season, all set to keep them interacting as desired. Probably easiest to keep the HPWH as primary and leave furnace out of the loop?
  2. brenndatomu
    Depends on how much hot water you use...unless you have a house full of teenagers taking long showers, and making way too much laundry (several clothes changes per day! :hair:) I doubt it would pay off...plus as JRHAWK9 found, that water coil steals a little heat from going to the house...which could be an issue if the house is already on the upper end of the VF's capacity to begin with (maybe not so much in sunny WNC? :))
    JRHAWK9 likes this.
  3. zymguy
    zymguy
    Ely MN
    I’ve the 200 hundred and love it. I’m 1200 ish ft and fair to ok insulation it’s kept up with no wind chill 50 below [​IMG]
  4. Rush Battle
    Rush Battle
    WNC
    You need to charge your phone, and that is very impressive performance from the VF200! Also, have you considered moving somewhere it doesn't get to -50?
    Cold Trigger Finger likes this.
  5. brenndatomu
    He's not far from Lamppa MFG...now you know why the Kuuma's work so well...no pansy heaters need apply up there!
  6. zymguy
    zymguy
    Ely MN
    Been to both the old shop and the current one , very nice folks over there .
  7. Rush Battle
    Rush Battle
    WNC
    I saw that, he could walk there if needed!
    woodey and brenndatomu like this.
  8. brenndatomu
    Not without freezing! ;) :rofl: :lol:
    TurboDiesel and Rush Battle like this.
  9. Rush Battle
    Rush Battle
    WNC
    I talked with Daryl for a bit, super nice folks! I was joking about moving, all the folks I know up your way are so nice and helpful. Very reasonable and honest. Seems like a great place to live.
    brenndatomu likes this.
  10. JRHAWK9
    JRHAWK9
    Wisconsin
    We are talking about going up to Ely in June sometime. Plan on stopping by Lamppa if we do. It's only, what, 20 minutes away from Tower?
  11. zymguy
    zymguy
    Ely MN
    Yes about 20 mins . Assuming your coming to ely on 169 you’ll get to tower before ely .
    Joe P likes this.
  12. Joe P
    Joe P
    Wisconsin
    My Dad is originally from Ely. I've still got relatives in town. Spent many summers up there swimming in Shagawau Lake and fishing by the treatment plant. We used to call it Stinky Ditch. Don't know if the locals still do. Grandma lived on Klondike road and we used to jump our bikes at the bottom of Finn Hill. Good days, long gone. Ely sure has changed from when I was a kid. Not quite the sleepy little burg it was back then, especially in the summer.
    Haven't been up there in a number of years, probably about due...
  13. zymguy
    zymguy
    Ely MN
    Getting a long way from the intent of the thread but I can confirm there is a small ice house community currently set up at stinky ditch
  14. woodey
    woodey
    Northern St. lawrence Co. NY.
    If you are looking for a furnace that requires minimal attention the Vapor-Fire 100 is the way to go. Going on year 5 with mine, great furnace. You will love the extended burn times and the even heat supply.
    comanche79p, JRHAWK9 and brenndatomu like this.
  15. Cold Trigger Finger
    Cold Trigger Finger
    Easern Central Alaska
    That furnace would work here in Delta Jct. I haven't seen -50 F ambient yet this winter . But we have had -60 wind chill.
    This winter has been really quite mild for us.
    Eric Wanderweg likes this.
  16. Sluggo
    Sluggo
    Martin, GA
    brenndatomu ? Where do you reside in OH specifically? I grew up in the Eastlake and Mentor area. Came to GA chasing work during construction of the Georgia Dome. I have some friends in OH still. Ever been to Geauga Park? That dates me for sure.
  17. brenndatomu
    About an hour south of Cleveland...you mean Geauga Lake? I was never there personally no.
