Kubotas at play. Er, I mean work!
Discussion in 'Chainsaws and Power Equipment' started by Warner, Jan 20, 2018.
  1. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    I’ve never had that much trouble hooking up my 3PH, the pto shaft can be a problem though.
  2. Maina
    Maina
    Maine
    Well Seasoned I don’t think you wanted the QH10 because it doesn’t have an adjustable upper hook, and that’s a must. I have a Speeco hitch, it’s a lot less expensive and it’s adjustable. I found right off the bat that the distance between the lower and upper lift points is not standard even within manufacturers. I have to move my upper hook to switch from the box blade to the snowblower, both LandPride. It’s still well worth the money imho. Saves all the wrestling and with my back I just can’t do that. Btw changing the hook position is easy, just 2 bolts.
  3. Canadian border VT
    I agree with maina, there
    Maina, Jack Straw, Chaz and 2 others like this.
  4. Well Seasoned
    I'm looking into Pat's now, this might be the best option..... plus cheaper!
    Stlshrk, Maina, Marvin and 2 others like this.
  5. Canadian border VT
    Post a YouTube link that won’t play, thanks Brian
  6. Well Seasoned
    Try it now..... the other video, the publisher didn't allow it on other sites. How dumb!
  7. JCMC
    JCMC
    Just outside of Shushan, NY
    I am happy with the Pat's system and have had no issue with PTO shaft length. I did have had a few issues when I switched them to the L2501 needed to add another spacer then it was ok.
  8. Well Seasoned
  9. Canadian border VT
    That looks really interesting I got to go figure out what size hitch I have, it might make it so I can put on the implement without getting on and off the tractor four times
    Stlshrk, Maina, Jack Straw and 3 others like this.
  10. Chaz
    Chaz
    Southwestern NY
    Whatcha purchase yesterday?
  11. Well Seasoned
    A patriot stick :whistle:
    Maina, Chaz, Jack Straw and 2 others like this.
  12. Well Seasoned
    Yes! Most are tier 1 except the huge tractors right?
    Maina, Chaz, Jack Straw and 1 other person like this.
  13. Canadian border VT
    I measured it’s 1 but I got spacers to take the bigger implement
  14. Well Seasoned
    I know a wedge can either go in the Pat's or be left out that comes with it.
  15. Chaz
    Chaz
    Southwestern NY
    :thumbs::thumbs:
    :startled:
  16. Spencer
    Spencer
    Indiana
    This is spot on. Without a adjustable upper hook, a quick hitch would be worthless for me. I have to move the hook for every implement i have for the most part. I have a JD quick hitch, which comes with bolts to hold the hook and i just switched out the bolts for pins to make it go faster.
  17. JCMC
    JCMC
    Put the chains on the Kubota yesterday (just in time) boy am I glad I got the rear wheel spacers. Spent the day clearing the 12" - 15" of snow from the driveway. I got say the hydrostatic transmission is the bomb for this stuff! Just got sat down to relax and realized I didn't get any pic's. I'm sure we will get more snow I'll get the pic's next time.
  18. Well Seasoned
    I think I'll look into spacers for next year. I love these chains y'all gave me, they are so very aggressive, no worry of sliding or loss of traction when they are on! Very tight tolerances though. They gotta be centered perfect and tight to miss my fenders. I've got just under a half inch of clearance.
    Spacers are probably best done at the dealer I'm guessing. I don't know how on earth I'd maneuver these off and on. Hmmm, unless I had a couple tough brutes at the g2g.....
    :whistle:
    Chaz, Jack Straw, Flamestead and 2 others like this.
  19. PBunyan
    PBunyan
    New England
    Going to toss my rig into the mix!
    Thinning out a patch of oaks adding to the firewood supply last fall..
    WinonaRail, Chaz, Jack Straw and 10 others like this.
  20. Well Seasoned
    Nice! :thumbs:
