Kubotas at play. Er, I mean work!
Discussion in 'Chainsaws and Power Equipment' started by Warner, Jan 20, 2018.
  1. T.Jeff Veal
    I think it will count, most Bobcat's have a Kubota engine...lol
    Chvymn99, Chaz, RabbleRouser and 2 others like this.
  2. Canadian border VT
    Great toy.. I mean tool:yes:
    RabbleRouser, Chvymn99, Chaz and 3 others like this.
  3. Marvin
    Marvin
    Huntingdon, Pa
    I've never seen an all black Bobcat. All of the ones I've seen (including the ones we've had on the farm) are white and orange. Guess I need to get out more :emb:
  4. fuelrod
    fuelrod
    Western Maine
    Must be the "stealth" model. :D
  5. RabbleRouser
    RabbleRouser
    In the woods, New Hampshire
    I'm pretty sure this one was painted specifically to match all the other equipment used by the previous company/owner. I can tell you it wasn't my favorite color working inside the thing in July.
  6. RabbleRouser
    RabbleRouser
    Interesting... That's the one thing I really like about this machine, the engine looks well made & well laid out. Unlike the diesel in my GMC truck, which is a nightmare.
    Chaz, Chazsbetterhalf and T.Jeff Veal like this.
  7. Warner
    Warner
    Ok guys I’m looking for some advice/suggestions. I have a bh77 on the bota, I may have been lifting some stuff that was real heavy and driving around with it pinched in the bucket. :whistle: Now the boom doesn't seem to have the lifting power it used to and it will intermittently dive in the dirt when digging. Some times if I shut the tractor off and restart it seems to get better but will happen again pretty quick. All other functions work properly.
    My thoughts are the spool valve may be messed up or that there might be a pressure relief valve issue. Any thoughts or suggestions are appreciated.
  8. fuelrod
    fuelrod
    Western Maine
    There's a circuit or valving that is part of what's called a "re generate" circuit. It re fills the other side of your loader cylinders with oil while lowering or dumping with a load while not all the way in a dump position with your valve, in other words "drifting" that would leave your cylinders empty or not completely full on the other (lift or curl up) side with an annoying dead spot until they get filled. I don't fully understand how it works. But long story short, our loader valves are not simple 2 spool/function valves like you'd find on a log splitter with a log lift.
    I'll run my loader up/down and the same with the bucket curl up/down (full stroke) repeatedly with the valve completely in the power position when things seem to be a little weird.
    My valve acts weird after a winter of running my (frame mounted) V snow plow. The factory loader valve stays with the tractor when you remove the loader. I use that valve to operate the independent left/right "wings" of the plow. The cylinders on each wing are double acting, and work fine, so does the loader when I put it back on in the spring. I just get a weird situation when I'm simultaneously lowering the loader and returning the bucket to level from dump. All is fine if only using 1 function at a time.
    Wow that's a lot of talk to say try "exercising" your valve with no load, full stroke of the cylinders with the valve fully in the desired direction. :whistle:
    I'd like to find someone to explain this hyd. Circuit to me, I doubt that the dealer knows much more than I do, particularly when I explain my winter use of the valve.
  9. mike bayerl
    mike bayerl
    Took a day off today and started working on moving and spreading this 22 ton pile of stone. Also scored a bucket of dead, dry oak. 20190919_143259.jpg 20190919_141727.jpg
    thewoodlands, Chaz, Marvin and 8 others like this.
  10. T.Jeff Veal
  11. Well Seasoned
    Sweet! Nice working temps today!
  12. Warner
    Warner
    Thanks for taking the time to respond.
  13. DaveGunter
    DaveGunter
    This thread could use a little Green!:D
    Gonna be 80 this weekend...
    thewoodlands, Chaz, Thor and 8 others like this.
  14. Well Seasoned
    Nice! Action pics for sure this winter! Thinking of maybe a sander next? :whistle:
    :tractor:
    Chaz, eatonpcat, T.Jeff Veal and 3 others like this.
  15. DaveGunter
    DaveGunter
    Yeah...and a grapple, and some forks, and a chipper, and a...:faint:, how deep is this rabbit hole? Oh, and a barn, gotta build a barn to park it all in.
  16. Well Seasoned
    Yes, I guess I can show you what to expect. o_O
    How deep is that rabbit hole you ask? Hmmm, the 3pt post hole digger didn't get far enough down the rabbit hole.... I guess we'll try a backhoe? :eek:
    Chaz, DaveGunter, Chvymn99 and 3 others like this.
  17. Well Seasoned
    Oh, a barn? Definitely go bigger than 20x30
  18. Canadian border VT
    Completely depends on the denominations of bills going on it!!
    $100's you can start with a post hole digger:eek:;):(
    Chaz, DaveGunter, Chvymn99 and 4 others like this.
  19. T.Jeff Veal
  20. eatonpcat
    Just for reference, my barn is 28x56 and I really don't have a lot of stuff and it is fairly full!
