Kubotas at play. Er, I mean work!
Discussion in 'Chainsaws and Power Equipment' started by Warner, Jan 20, 2018.
  1. thewoodlands
    thewoodlands
    If it makes the job easier, it's cool. :yes:How have you been Certified106 ?
  2. JCMC
    JCMC
    Just outside of Shushan, NY
    Got a little more done yesterday put my new set of forks on and started lifting from the pile of logs and cutting.
    What a Backsaver!
    Stlshrk, Thor, Chaz and 9 others like this.
  3. Well Seasoned
    What a back saver indeed! :yes:
  4. JCMC
    JCMC
    Oh! and the Saw still has the cabled chain on it. Was cutting great yesterday.
  5. fuelrod
    fuelrod
    Western Maine
    It's easy to find your forks are on more often than the bucket, although they really suck at snow removal :D
    Thor, Chaz, Chazsbetterhalf and 6 others like this.
  6. mike bayerl
    mike bayerl
    WOW! What a difference... One of my original 20 y.o. hood lights burned out recently, so I replaced them today with this 20190914_162436.jpg 20190914_162831.jpg $30 pair of LED. LED Light Pods - 3.5" Round Mini LED Work Lights - 22W - 1,600 Lumens - 2 Pack | Super Bright LEDs These are amazingly bright. In person, the difference between the old fashion headlights and the new LED's on the top is even more dramatic. I wish I would have done this when I first got the tractor 4 years ago. 20190914_162831.jpg
  7. Chaz
    Chaz
    Southwestern NY
    Man, I need my sunglasses.
    :bug:
    :yes:
  8. Canadian border VT
    Thanks for link mike bayerl I think I need to put those on back of my tractor to snow blow!!
  9. Well Seasoned
    Luckily you didn't lose a tooth that day!
    Chazsbetterhalf, Chaz and T.Jeff Veal like this.
  10. Well Seasoned
    Those look nice mike bayerl, time will tell how they last for that price. These LED lights are hit or miss. I may purchase them, tell me, did you need to also purchase the wiring harness down on the website as an accessory or did you use what you already had from your old lights? I know my bota has a slot to add some more lights already, but id need to get the wires to the rear. If these lights came with wires, how long are they? I'd consider mounting them on my fenders for more light up front. I already have a plug in light for the rear. Thanks for the link! :yes:
  11. mike bayerl
    mike bayerl
    For rhe price, i figured it was worth the gamble. I only put on about 50 ish hr / yr and don't really run much at night. My tractor already had lights so I didn't need the wiring harness. The wires on the new lights were plenty long. Very simple swap out.
  12. mike bayerl
    mike bayerl
    Supposed to have a "lifetime warranty "
  13. fuelrod
    fuelrod
    Western Maine
    Although it's not on the light switch, Kubota runs a power wire in with the wires that power your rear fender lights. It's down low by the area where the fender & Rops come together, iirc on the rt. side.
  14. Well Seasoned
    That's great, thanks. That's roughly how many hours I put on the bota as well, although it gets used quite a bit after dark for snow, I'll go ahead and order them.
  15. Well Seasoned
    I've seen that. There's a bullet terminal down there. Just need to find a good place to mount. :yes:
  16. Canadian border VT
    Back of my rear fenders has a spot pre drilled.. Maybe yours are used by canopy?
  17. Well Seasoned
    I've thought of maybe the canopy. The only thing is that it bounces around up there. A light bar would be sweet.
  18. mike bayerl
    mike bayerl
    If you want absolute max lighting, you could think about the next brighter ones.
  19. RabbleRouser
    RabbleRouser
    In the woods, New Hampshire
    Don't know if this counts as it is a Bobcat, not a Kubota but I'm guessing it's the idea not the brand.
    Have had my brother's Bobcat at the house for several weeks now. Mostly done with the five dump loads of fill I bought in but finding plenty of other uses for this thing. Yesterday I had picked up a new tire for my log splitter to replace the one that was more square than round after it leaked/wend flat and the sidewall rotted. It was essentially mired in a pile of bark and other debris so decided the Bobcat would make pulling the wheel a bit easier.
  20. Well Seasoned
    Hmm, there is alot of times I need to keep up with the snow in the dark. I'll check them out.
    mike bayerl, Chvymn99, Chaz and 2 others like this.
