Kubotas at play. Er, I mean work!
Discussion in 'Chainsaws and Power Equipment' started by Warner, Jan 20, 2018.
  1. Chaz
    Chaz
    Southwestern NY
    I checked hyd fluid level, sitting 2/3 up the hash marks.
    Now it's cooled down and sounds normal again.
    Think it was too hot??
    I checked coolant level, it's low, but not empty, although overflow jug is empty.
    Engine oil is right near top, but does need changed.
  2. Chaz
    Chaz
    Southwestern NY
    Transmission was in turtle mode, 4wd engaged.
    Only high and low on the transmission.
    See no evidence of any leaks, broken, or disconnected lines.
  3. Well Seasoned
    Hmmm, strange.... mine has done some weird stuff here and there but all is well. Hopefully a fluke thing!
  4. Flamestead
    Flamestead
    Windsor County, VT
    Ok, it sounded to me like when a remote line is undone (hydraulic bypassing). I only have experience with the gear transmission, so no help there. Heavy pulling might get yours too hot ?? Just speculation.
    I’ve been thinking of moving my stove’s ir thermometer out to the shop for the summer for stuff like this. I don’t know what temp is normal, but heavy PTO work gets it hot (haven’t ever had what I thought was too hot, but again, don’t know where that line is).
    T.Jeff Veal, Chvymn99, Chaz and 2 others like this.
  5. Canadian border VT
    Yeah can't help mine is gear but haven't heard that noise in 875 hours.,
  6. Chaz
    Chaz
    Southwestern NY
    That was something else I considered, my shorts did catch on the PTO selector lever, but PTO engagement lever was still in the up/disengaged position.
    I'll get some water and antifreeze to top off the coolant system, the manual calls for soft water, ours is hard as heck here.
    Aside from stopping by the 'bota dealer, anyone know what antifreeze comes standard?
    Manual didn't specify anything particular.
  7. Chaz
    Chaz
    Southwestern NY
    BTW.. thanks for all the help and information guys.
  8. wildwest
  9. cnice_37
    cnice_37
    Chaz I get that squeal or whatever if the 3pt is at Max height. Something on my machine doesn't like it, so I bump it down a hair and all is well.
  10. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    Power steering, heat, a/c , cruise control, tilt wheel, arm rests, radio, front and rear wipers. Yesterday Kerry Farwood was mowing with the zero turn in the hot sun. I kept waving to her from the a/c cooled cab. :rofl: :lol::rofl: :lol::rofl: :lol::D
  11. Well Seasoned
    :tractor::dennis::salute:
  12. Jack Straw
    Jack Straw
    I’ve been trying to keep the Kubota nice and the hours low but when it’s 90 and humid it’s hard staying out of that cab!
  13. Chaz
    Chaz
    Southwestern NY
    Thx cnice_37 that's reassuring.
    I'm sure the boxblade was all the way up, so I'll keep that in mind if I hear that again.
    Hoping I won't.
  14. Canadian border VT
    To bright to see how well they came out.. Last pic on left is slip n slide
  15. Well Seasoned
    Nice work Lyle! A driveway as long as yours, I'm sure you had plenty of washouts with that torrential rain. That slip & slide was probably a raging torrent!
  16. Chaz
    Chaz
    Southwestern NY
    Well, all of yesterday's work was for naught.
    o_O
    Start on blocks this morning, got to #4 and had to dig way too deep to level things.
    The 4x4 is touching ground above block #4
    Chazsbetterhalf says she never saw me check lengthwise for level, but I'm reasonably certain that I did.
    Of course, I was placing the level on the truest 4x4 that I purchased, and may have been hitting hi/low spots, I don't know.
    So, I hammer in some T-posts and run a string level, have 6" of grade from high to low.
    :faint:
    So, I work in it properly today, and have things level on each end, with slight hi/low spots in the middle.
    Ground is 15.5" at both ends, high spot is 14.5" below, and low spot is 16.5" below.
    Blocks are 3.5" deep, and I'll be adding gravel, so I think that's gonna work.
    Will check sides one day this week, and see where the hi/low spots are there as well.
    Guess we can see why I don't do this for a living.
    I'd be broke, homeless, starving, and without a beer budget.
    :bug:
    :coldone::pete:
    Only one squeal from the tractor, and I lowered the 3pt, did seem to help.
    Thx cnice_37
    :yes:
  17. Canadian border VT
    125 feet but no hay bales and pool at bottom this time...
  18. Canadian border VT
    8 passes with box blade 6 to 8 inch ruts are now smooth!!
  19. fuelrod
    fuelrod
    Western Maine
    Chaz howd you get a pic of my finger in that one shot? :rofl: :lol:
  20. Well Seasoned
    Nice work! Seeing what your doing is making me twitch since I feel like I did that just weeks ago, wait I did! What are you building there?
    Chvymn99, Chaz and fuelrod like this.
