Kubotas at play. Er, I mean work!
Discussion in 'Chainsaws and Power Equipment' started by Warner, Jan 20, 2018.
  1. Well Seasoned
    Here's a video on putting it together. The video doesn't show the fellow greasing key area and he likely over filling the gear oil by not removing the lower bolt. Looks like his 2650 does well with the auger, but he likely has easier soil than us up here.
    thewoodlands, Stlshrk, Chaz and 6 others like this.
  2. mike bayerl
    mike bayerl
    Definitely not the most challenging soil in that video. For putting in footers or poles for a pole barn you want to "dig" a hole. For fence posts, a hydraulic post pounder is by far the better option. We rented one attached to a skid steer when we put in our fence posts and it worked great. Even with as many rocks/boulders we have it worked really well. We put in about 100 posts and only about 3~4 did we have to move a foot or so after hitting a rock we couldn't get through. The only downside, is that in soil like ours with lots of rock, you can't guarantee that all the posts will wind up perfectly plumb. Sometimes, the post will glace of rock and wind up a little cockeyed.
  3. Well Seasoned
    We continued removing small stumps, roots, rocks, boulders, and thistle from the hill today. Very tough work only using the bucket, but it's all I got. Most of the stumps are smaller, a million roots which I dig under, lift up and push over. There were some insane sized boulders I dug out. All were moved elsewhere, many times only one at a time, one was pushed into the pond, it wouldn't fit into the bucket and was to heavy. There is still a little too do with the help of the kubota, so far did a 100ft x 20ft section of hill. The rest will be hand pulled thistle to get the roots out and digging by hand about 5 more saplings. Lastly, it'll get everything graded by bucket and rake by hand and seeded. Once that's done, I need to move a ton of wood, pallets, and equipment to final grade the area for the 3 sided pole barn. Still waiting for the post hole digger to arrive, hopefully by the end of the week.
    Chvymn99, Stlshrk, Maina and 6 others like this.
  4. Canadian border VT
    Well Seasoned a box blade won't do it?? If your Talking about the hill behind the house.. I would try a box blade scarify the whole ground and then rake downhill into the bucket..
    Stlshrk, Maina, bear 1998 and 4 others like this.
  5. Well Seasoned
    I don't have a box blade. I called everything attachments for the 66" with 5 scarifiers, but it was an 8 week wait! So using what I've got is working well just more labor intensive, but not as intensive if I didn't have a tractor. It's in the front of the house behind where we were eating hot dogs that day. When the previous owners graded where the house sits, the excavators dumped the dirt, didn't grade and it wasn't kept up with. I pulled down leftover concrete from the concrete pad that was dumped there, a bit of a mess, but it's turning out nice. The entire area below was nothing but trees, saplings, buried old sheds, e.t.c. 3rd summer getting it back up to snuff!
  6. JWinIndiana
    JWinIndiana
    NorthWest Indiana
    Wonderful job of chaining the tractor down, buttttttttttttttttttttttttttttttttttttttt, belong to anyone here?? (I hope not)
    Jack Straw, Maina, eatonpcat and 6 others like this.
  7. T.Jeff Veal
    :bug::jaw:
    Looks like the safety chains weren't hooked or broke. Hope no one was hurt.
  8. trail twister
    trail twister
    Looks like the ROPS saved the tractor from bad damage.
    Most trailers have to small of saftey chains and the hooks they use are not worth a tinkers dam.
    Also Make sure you pin the traler hitch latch. I use ones like this. I use a lock like this when towing some place where the people may be a bit on the shady side.
    Love ther pindle hitch on my equipment trailer. Not many people have those hitches.
    :D Al
  9. JWinIndiana
    JWinIndiana
    NorthWest Indiana
    Yeah I wondered if it was a case of a 2" ball when a 2 5/16" was called for. Wonder how many side rolls as it looks like the tires are missing from the axles.
  10. JCMC
    JCMC
    Just outside of Shushan, NY
    Update the tractor is at the dealer waiting for the spacers to come and get installed before they load the tires. :hair:
  11. Well Seasoned
    I'm just as impatient as you! :hair:
    I picked up the auger last weekend and finally picked up the Post hole digger today. I'm hoping to get it put together tomorrow. Once the hill is done & seeded, I'll start moving all this wood and equipment to start leveling where the 3 sided pole barn will go. Then holes & posts.
  12. Well Seasoned
    Post hole digger installed, but I'm not quite done yet. Still needs gear oil and I have to dbl check when the shear bolt is out, the set screws keeps the drive line in place. Test tomorrow, I gotta go meet Dawn. :yes:
  13. Well Seasoned
    Ok, managed to dbl check the set screw if the shear bolt busted, worked as it should. This must be an updated model I haven't seen yet. It came with a stand and a bar that the operator can safely reach to straighten up the case on the gear box, but in my mind, it's kinda pointless. Still can't see the angle from the operating station anyway, so I'm not adding it. The chains for the protective sleeve over the drive shaft are missing so I'll contact speeco to send them out since it's a pretty important safety feature imo. Other than that, it works. Next time I'm out, shear bolts, cause I'm gonna likely need a bunch as others suggested. :yes:
  14. Well Seasoned
    2 out of 3 test holes went well. The first I hit a chunk of metal. The auger is wide enough that I got around 53" down, not bad.
    thewoodlands, Maina, Chvymn99 and 3 others like this.
  15. Well Seasoned
    For now the auger is here. I needed to get it off to do a bunch of loader work. Once I get my shelter built, it'll have a custom holder.
    Works for now......
  16. Chaz
    Chaz
    Southwestern NY
    Looks like it works great Well Seasoned
    Still unsure if the BX25D is up to the challenge
    :sherlock:
    But I did contact a rental shop, it'd run about $600 for one day rental and delivery/pickup.
    :doh:
    :makeitrain":makeitrain"
    At that cost, purchasing one starts to look betterer n betterer
    :whistle:
    :BrianK::heidi::heidi:
  17. Well Seasoned
    That's crazy prices for one day! :hair: There is a smaller model for smaller tractors. On tractor supply co website, the main post hole digger from county line (speeco) has a comment section. Ask on there if it will fit, if not, the customer service person will suggest the proper part # for your tractor.
    It should work well, but I know I'll hit larger rocks, it's a given. I ran the test holes this morning in an area I thought should be mostly clear of rocks etc.
    What will you mostly use it for? They offer 6",9",& 12" augers.
    Maina, Stlshrk and Chazsbetterhalf like this.
  18. Chaz
    Chaz
    Southwestern NY
    Well, being fair, the rental costs involved delivery/pickup of a tracked skidsteer with posthole attachment, and 6" & 9" augers.
  19. Well Seasoned
    About $489/week here. Already worth it in a week. There's fellow's that go around for $20-50 bucks a hole for their customers. $500 for 10 holes, damm near paying for itself after a day.
  20. JWinIndiana
    JWinIndiana
    NorthWest Indiana
    Don't think I would recommend leaving that auger in the ground. I hang mine by the bend in the arm off of a tree branch, then went to a pole, finally in a shed off of a rafter. Corrosion will happen quickly and ruin the edge on that auger I would think. Just my opinion.
