Kubotas at play. Er, I mean work!
Discussion in 'Chainsaws and Power Equipment' started by Warner, Jan 20, 2018.
  1. Chaz
    Chaz
    Southwestern NY
    Maina, Stlshrk, Chvymn99 and 3 others like this.
  2. T.Jeff Veal
    Be surprised at what they can do. Ours is a 3130 GST. 30 HP.
    Stlshrk, Chaz, Chvymn99 and 2 others like this.
  3. T.Jeff Veal
    Ours doesn't have quick attach either, made a rig to fasten forks on bucket. That hill looks like the one we are dealing with right now. Wish I was closer, might could help you out.
  4. Slocum
    Slocum
    North Central Indiana
    Do you have tire chains? Liquid in your rear tires or weights? I have similar hills on my property. My tires are filled with fluid foo weight. My tractor doesn’t get up and down the hills very well if the ground is snow covered if I don’t have my tire chains on. Actually I don’t even attempt it anymore without my chains.
    Maina, Stlshrk, Well Seasoned and 3 others like this.
  5. Canadian border VT
    Slocum Chains?? It took me several attempts to convince southern members that even 4wd needed chains in snow!:cool:
    Luckily fuelrod and other know snow!!
  6. Slocum
    Slocum
    They are a necessity if your going to get any work done.
  7. Chaz
    Chaz
    Southwestern NY
    @slocom, no chains yet.
    I also plan on getting 3" spacers to widen the rear stance.
    Not 100% sure, but I think I read that these tires should not be weighted, but I could be wrong.
    Maina, Chvymn99, Stlshrk and 2 others like this.
  8. Slocum
    Slocum
    I widened my rear stance also. That made a difference but the fluid in my tires made all the difference. It handles like a different tractor.
    Maina, Chvymn99, Stlshrk and 3 others like this.
  9. Chaz
    Chaz
    Southwestern NY
    Ok, got out the manual to recheck.
    Pg 55 states that water & calcium chloride can be added to rear tires.
    But it also states that while the backhoe is installed, the liquid ballast should be removed.
    I seldom remove the backhoe, but obviously would if I use it in a log skidding operation.
    How difficult is it to add and remove the liquid ballast?
  10. Canadian border VT
    Chaz wheel weights are your friends..
    Maina, Chvymn99, Stlshrk and 5 others like this.
  11. Chaz
    Chaz
    Southwestern NY
    Ok, so some 'net searching shows unsurprisingly that I'm not alone in this situation.
    One person sent an email to Kubota about liquid ballast and the backhoe.
    Their response noted..
    So it appears they want the rear tires to lose traction in the event that the operator tries to work the front end too hard.
    Seems that as long as I don't get stupid, then there shouldn't an issue.
    :whistle:
    I did search for wheel weights, and found it surprising that I've not come up with a good link yet.
    :loco: :crazy:
  12. Slocum
    Slocum
    I wouldn’t use calcium chloride. Very corrosive. I wouldn’t add liquid to tires if I had to remove it. I filled my tires myself for 160$ with windshield washer fluid. Washer fluid isn’t as heavy at steel ballast or some use beet juice. But if I cut a gash in my tire I’m not out much. I looked into wheel weights but there wasn’t a lot of options. It was expensive for no more weight than they added for my 3301 kubota
  13. Jnb
    Jnb
    New Brunswick
    I am also a believer in chains and loaded tires, I don't have chains on my current tractor yet that is 4wd, and it won't go anywhere that I use to go with my old tractor that was 2wd with chains.
    Dancan, Maina, Chvymn99 and 5 others like this.
  14. Slocum
    Slocum
    This is where I looked at wheel weights
  15. Stlshrk
    Stlshrk
    Central Virginia
    We have started reloading one side of the woodshed for next winter. Today my oldest and I moved and stacked 3 full cords to the shed. I am thankful that he was willing. The rtv we borrowed from the father in law.
    This was the first load of the day.
    After those loads he swapped the trailer to the RTV and put the carryall on the tractor.
    He kept me hopping as I spent most of the day stacking. He would load, drive, swap out the vehicles at the shed... he was often waiting on me. Lol.
    :BrianK:
    papadave, Dancan, eatonpcat and 8 others like this.
  16. Well Seasoned
    Nice work! Good to get our young men involved to show us up!
    Chaz, Maina, Chvymn99 and 3 others like this.
  17. T.Jeff Veal
    Nice job, glad you had help
  18. Spencer
    Spencer
    Indiana
    To skid out logs before i bought my winch, i just welded up some 1/4" angle into a rack and bought a pair of log tongs for 75 bucks. Probably had $125 in the thing.
  19. Chaz
    Chaz
    Southwestern NY
    Don't have a welder, and it's been nearly 20-25 yrs since I've welded anything.
    :doh:
    But, I will find a way.
    :yes:
    I do believe I will weight the tires and might only go with 2" spacers as from what I researched, the 3" can be a bit hard on the rear bearings.
    T.Jeff Veal, Chvymn99, Slocum and 3 others like this.
  20. Spencer
    Spencer
    Indiana
    Ahh, well im not really a welder either lol. Heres a pic, if you have a buddy with a welder im sure he could weld it up for you cheap.
    2" would probably give a pretty noticeable change in stability. I think i had 2" on my 2305 also.
    Marvin, eatonpcat, Thor and 7 others like this.
