Kubotas at play. Er, I mean work!
Discussion in 'Chainsaws and Power Equipment' started by Warner, Jan 20, 2018.
  1. Born2Burn
    Born2Burn
    Youngstown, OH
    Yeah, I've broke a weld in my neighbor's landscape trailer loading a tractor. Learned my lesson there. Plus it's a lot more stable while loading. Kind of a pain to have to dig out the stands everytime and bring them along for the adventure but oh well.
    mat60, Chaz, Slocum and 2 others like this.
  2. T.Jeff Veal
    IMG_20190216_181812.jpg carrying a nice hickory log to the dump trailer.
    eatonpcat, Thor, mat60 and 10 others like this.
  3. mike bayerl
    mike bayerl
    Thank for the details. I was trailer shopping recently, too. I wound up with a 6x12 single axle (3.5K) utility trailer, no brakes, no state inspection. I will not be trailering my tractor on that, obviously. I have an L3710 with LA681 FEL and filled tires. I don't know how much it weighs, but I asked at Messicks and they said "close to 6,000#" and recommended a 10K trailer. Personally, I've only needed to trailer my tractor once and that was just like 10 miles to Messicks for them to do some work on it. They just charged me an hourly rate for pick up/drop off. Also, I have at least two friends who each have 7-10K car haulers they are willing to loan me, and trucks capable of towing that kind of weight.
    mat60, Chaz, Will C and 4 others like this.
  4. Will C
    Will C
    New York
    I'm sure you are pushing 6k. My L3560, loaded tires, and LA805 FEL weighed 5725 the day I picked it up. Just barely legal on my trailer. If I bought a new trailer, it definitely would be a 10k 20' unit.
    Probably won't because I don't have to trailer the tractor very often.
    eatonpcat, T.Jeff Veal, mat60 and 7 others like this.
  5. Spencer
    Spencer
    Indiana
    Yeah thats why i picked up a equipment trailer with the fold down ramps. I transport my tractor every other weekend so it works well. If you are just moving around every now and then, jacks would be fine.
    T.Jeff Veal, mat60, Slocum and 4 others like this.
  6. Spencer
    Spencer
    Indiana
    I picked up a weight distribution hitch for my equipment trailer. It helps a ton too. Different way around the same problem lol.
    Stlshrk, T.Jeff Veal, Slocum and 5 others like this.
  7. Well Seasoned
    I noticed the sleeve on all the hydro lines on the right side of the loader slid all the way down, causing significant rubbing on the hoses down to the braided mesh. I'll need to replace these in the spring. Teaches me to pay better attention and inspecting everything every time or the every 10hrs for greasing.
    Any tips on replacing the lines. Will there be alot of spillage and do the lines needed to get bled to remove any air in the hoses?
  8. Will C
    Will C
    New York
    I replaced a couple of lines on my BX 2200. Flare nuts wrenches are nice if you have them, regular wrenches will work. Not much spillage-have a rag or two handy when you disconnect the hoses to plug the holes. I didn't have to bleed anything. Work your bucket cylinders a few times before turning your tractor off of lessen pressure. I would recommend replacing both hoses on the same circuit, just gives some peace of mind for a few more minutes and a few more dollars.
    Stlshrk, T.Jeff Veal, mat60 and 4 others like this.
  9. Well Seasoned
    Thanks, yea..... I'll need to pick up a set of those. :yes:
  10. Maina
    Maina
    Maine
    I would cycle the control AFTER shutting the tractor off to relieve any pressure before loosening any hydraulic fittings. You shouldn’t lose much more than what’s in the lines.
  11. Spencer
    Spencer
    Indiana
    2x. Have to do it after to equalize pressure with no pump flow.
    Stlshrk, T.Jeff Veal, Maina and 4 others like this.
  12. Well Seasoned
    Thanks, probably lower the 3pt all the way down too?
    Stlshrk, T.Jeff Veal, Chaz and 3 others like this.
  13. Well Seasoned
    I've got a place that makes em perfect not far from work. Just gotta get it on my to do list, along with flare nut wrenches.
  14. Spencer
    Spencer
    Indiana
    Different circuit, so shouldnt matter. I would probably go ahead and disconnect the loader before replacing the lines, just make everything easier to get to (if you have a quick attach loader).
    Stlshrk, Slocum, T.Jeff Veal and 5 others like this.
  15. Maina
    Maina
    Maine
    If you want to cover more of the new hoses with wear sleeves your local NAPA store in Whitefield or Littleton would probably have it in stock. Longer sleeves and a few wire ties might prevent a reoccurrence.
  16. Well Seasoned
    Excellent idea! I'll definitely do that. The sleeve slid down, when I don't know. I've since moved it back in place with some ties but need to replace these hoses. Hopefully it's done before the g2g!o_O
    T.Jeff Veal, Maina, Stlshrk and 3 others like this.
  17. Flamestead
    Flamestead
    Windsor County, VT
    I’ve had to replace two lines on my loader, and one was due to wear at this sleeve. I didn’t notice the wear progressing - the sleeve was slid down one day and one hose was worn down to the wires. The other blown line was due to digging out a big rock while bush hogging, with the tractor up at PTO speed.
    I remove the bad line, cover the fittings on the tractor with rags to keep things clean, and take it to get a new line built at the local auto parts store. Cheaper and closer than the dealer. I didn’t know they make flare wrenches, and have been fine so far without one.
    T.Jeff Veal, Maina, Slocum and 3 others like this.
  18. JCMC
    JCMC
    Just outside of Shushan, NY
    This afternoons hitch of Soft Maple that blew down last summer and was hung up at waist height about 50' out on the swamp. Made two cuts hooked the cable and hauled it home.
    Had some visitors They were enjoying the sunshine as was I.
    Nice day to be out in the woods! Suppose to get some snow tonight into tomorrow morning
    papadave, T.Jeff Veal, Thor and 13 others like this.
  19. Well Seasoned
    Looks like a good day!
  20. fuelrod
    fuelrod
    Western Maine
    Decided to dig out (of the snow) 2 loads of oak to hopefully have them dry/melt off so I can work them up without getting soaked. There's too much snow in my woods to do any cutting in the foreseeable future. I hate working a saw & tractor in snowshoes and won't do it, "the juice is not worth the squeezin", at least to me.
    Today
    There was a good 3' of snow thats been rained & sleeted on along with a few 40* days and lots of sun. I would have had to dig them out without the V plow.
    Found one
    Did all the plowing I could with the tractor and got the SS with the bucket and grapple do dig them out and stack them as best as I could.
    This was some oak from a friend that was cleaning up his landing after logging a neighboring property. I don't cut oak on my place, the last owner did that about 15 years ago. :(
    You might be able to tell that I'm getting a "touch" of cabin fever and anxious to dig out the splitter.
    Got 2 more loads up in my firewood area, but I've totally buried them by pushing this seasons snow on them.
