Kubotas at play. Er, I mean work!
Discussion in 'Chainsaws and Power Equipment' started by Warner, Jan 20, 2018.
  1. Canadian border VT
    FEL lifted it up and tire dealer had tire in stock, broke bead.. With tube $202 in 45 minutes back on.. Good thing 2 feet of snow,, rough morning., lost steering over culvert 6 foot drop in dark:jaw::hair: is it ok to want a drink at 545 am?? I was scared .. Worked out fine
    chipper1, Maina, Chaz and 1 other person like this.
  2. mike bayerl
    mike bayerl
    I wholly support drinking 5:45 a.m., especially if it involves single malt scotch!!!
  3. Canadian border VT
    2 shots of bourbon that morning.. The rear blower caught on culvert to stop roll over into swamp.. Chittin bricks:bug:
    chipper1, mike bayerl, Maina and 2 others like this.
  4. Chaz
    Chaz
    Southwestern NY
    Yeah, now see, that's the type of thing I want to avoid.
    :yes:
    As to..
    :bug:
    I'd have chit a brick looking at the bill, then needed a shot or 2.
    :faint:
  5. 94BULLITT
    94BULLITT
    Frederick County, VA
    The engine dies if the pedal is stepped on and no one is on the seat.
    chipper1, Chaz, Maina and 1 other person like this.
  6. RCBS
    RCBS
    Over here
    I had that happen while bush hogging a month ago. Had to bring in to work and have it remounted on tire machine. Air compressor and ratchet strap method did not work as it had in the past. I think because I had to drive on it a bit to get it to level ground.
    Mine was left side as well. Conspiracy! :BrianK:
  7. mike bayerl
    mike bayerl
    Not if the switch under the seat is disabled, as it frequently is.
    chipper1, cnice_37, Maina and 2 others like this.
  8. mike bayerl
    mike bayerl
    Back in business. Jacked up front end with FEL, took wheel off and down to my local shade tree mechanic's shop. Remounted and inflated on his machine. One Hamilton and back onto the tractor. About 30 minutes. Phew!
  9. Canadian border VT
    My I put a tube in mine, once was enough!!
    chipper1, Maina and Chaz like this.
  10. mike bayerl
    mike bayerl
    That would have been a good idea, but I needed to get it done quickly so I could use the tractor this weekend. Will do if it happens again.
  11. Chaz
    Chaz
    Southwestern NY
    Another day, another stump.
    This is the stump of the pine that fell this spring.
    Right now I wish I had ordered the backhoe thumb.
    :doh:
    chipper1, Stlshrk, basod and 6 others like this.
  12. Will C
    Will C
    New York
    Seen my brother pop the front tire off a backhoe. A little more work to take the tire off a Case 580!
  13. Born2Burn
    Born2Burn
    Youngstown, OH
    What was the diameter of the tree? I have a few pine stumps that need removed but I'm not sure if I can get them..... they are probably 12-15" diameter
  14. Chaz
    Chaz
    Southwestern NY
    If memory serves, around 12-14 inch.
    Not gonna measure it at the moment.
    chipper1, Stlshrk, basod and 5 others like this.
  15. Chaz
    Chaz
    Southwestern NY
    The butt log measures @ 12"
  16. Gasifier
    Dirt work.
    chipper1, Stlshrk, basod and 7 others like this.
  17. Well Seasoned
    That is a purdy tractor Gasifier! Get er' dun!
    chipper1, Chaz, Maina and 2 others like this.
  18. mike bayerl
    mike bayerl
    Moving some river rock to some of the muddy areas in the sheep yard today. 20180818_172311.jpg
  19. Chaz
    Chaz
    Southwestern NY
    Got some more trenching done yesterday for the lower woods crossover, then the rains hit.
    Too muddy up there today, so did some other running around.
    Got the thumb installed on BH, and greased all fittings.
    Tonight took BH off and installed the box scraper and hit the driveway.
    Will have to wait till tomorrow for pics.
    o_O
    :picard:
    chipper1, basod, eatonpcat and 5 others like this.
  20. Born2Burn
    Born2Burn
    Youngstown, OH
    I have 25 hrs. On the new tractor already. I have dug a hole to bury ash, cleaned out a drainage ditch, demolished a job office trailer, cleaned up all the burn pit ashes, box grade/blade/raked the 750ft driveway, regraded and prepared my front yard for seed, and started on fire wood logistics on pallets. Last night I completed a 1hr log skidding job with the forks in about 5 minutes.
