Kubotas at play. Er, I mean work!
Discussion in 'Chainsaws and Power Equipment' started by Warner, Jan 20, 2018.
  1. RCBS
    RCBS
    Over here
  2. Canadian border VT
    That is a calendar worthy pic :yes: RCBS
    metalcuttr, T.Jeff Veal, Chud and 2 others like this.
  3. RCBS
    RCBS
    Over here
    Just rolled 1450 hours. It's been a very good tractor to me.
  4. lukem
  5. lukem
  6. lukem
    Walnut log rescue.
    metalcuttr, RCBS, Chaz and 3 others like this.
  7. Trueg50
    Trueg50
    Essex, VT
    Wrapping up the logs I skidded out over the winter, I saved the biggest red oak and sugar maples for last. Thankfully the Kubota pitched in for those, acting as log lift and table space.
    MikeInMa, metalcuttr, RCBS and 7 others like this.
  8. T.Jeff Veal
    Well done, sir
    metalcuttr, Chaz, Chud and 2 others like this.
  9. T.Jeff Veal
    L4802 unloading our new no-till grain drill. It weighs 1500lbs. All it wanted... Messenger_creation_8990044D-A221-43D8-8CD9-5832FFBED84E.jpeg
  10. T.Jeff Veal
    Put the L4802 to work with the Frontier harrow. Plowed down the foot plots that the hogs had tore up. Didn't have to use the seat belt, but thankful for cruise control and differential lock...
    MikeInMa, Chvymn99, Chaz and 2 others like this.
  11. RCBS
    RCBS
    Over here
    What is listed capacity for the unit? (I consider your description + listed capacity to be good reference)
  12. T.Jeff Veal
    Specs say max lift at pin is 1675 lbs, so I think with the weight way out front was a big load.
    Chaz, MikeInMa, eatonpcat and 2 others like this.
  13. RCBS
    RCBS
    Over here
    Where did you notice most? Rear getting light, or hydraulics working hard to lift? Both?
  14. T.Jeff Veal
    Mostly hydraulics were slow, had to lift front of planter of trailer then curl back to get rear off trailer.
  15. RCBS
    RCBS
    Over here
    Similar experience for when I have a full bucket of wet crick shale on front of the BX. It'll do it, just slowly even when RPMs are up.
    Chaz, T.Jeff Veal and eatonpcat like this.
  16. lukem
    Picking pallets of sawmill firewood is usually about all mine will handle. If I have to lift then curl to get it off the trailer deck most times I'll lift a back tire. I could use a little more ballast than the box blade but like keeping it light(ish) for the yard and the woods.
    Chaz, MikeInMa, T.Jeff Veal and 3 others like this.
  17. RCBS
    RCBS
    Over here
    Been researching some JD compacts with loaders. Consensus seems to be that JD sets the pump pressure low from factory. Many have bought a gauge and 'turned up' their pressures and are still within operating spec get get better lift capability.
  18. lukem
    I put a gauge on mine and it was right at spec. I figured it would be a little low. But now I have a gauge and a some shims if the pressure drops I can measure and fix it.
    RCBS, Chaz, T.Jeff Veal and 2 others like this.
  19. morningwood
    morningwood Administrator
    More lift = more weight you need to hang off of the back. More weight = more stress on the front end too. Believe that's why T.Jeff Veal went with a bigger tractor this time. Mine will barely lift 2k but my a$$ end is barely on the ground with a 6' Wood brush cutter hanging off the back.
  20. T.Jeff Veal
    We did the shim fix on the L3130. Haven't really needed it on the L4802. It will barely pick up a 330gal tote of grren oak with loader, but with hydraulic top link and QA adapter to put forks on rear works great for those. 20260228_101110.jpg
    RCBS, Chud, Chaz and 3 others like this.
