Kubotas at play. Er, I mean work!
Discussion in 'Chainsaws and Power Equipment' started by Warner, Jan 20, 2018.
  1. Chud
    Chud
    NC
    Dang, I wasn’t willing to go back and fact check that bit.
  2. eatonpcat
    Well, at least it's not a Ferd
    T.Jeff Veal, Warner, Chvymn99 and 3 others like this.
  3. yooperdave
    ..............so, that same wind direction is akin to a bag of wind? :whistle:
  4. T.Jeff Veal
    Hey now...why I ought'a...
  5. Trueg50
    Trueg50
    Essex, VT
    Well, she has to play a supporting role to a Yanmar mini-ex today, but she has been invaluable and put in some good work. Once I switch to putting down fresh gravel it will be all tractor work.
  6. Canadian border VT
    Do yourself favor dig down add fabric
    eatonpcat and T.Jeff Veal like this.
  7. Trueg50
    Trueg50
    Essex, VT
    I considered it, but opted not to for a variety of reasons. The base is good already and the driveway will get torn up at some point when the garage gets replaced. There is also a massive boulder that needs to be hammered out, and 50amp electrical (not in conduit) to the barn is only 4-6" underground. I hit a tail off the grounding rod for the building electricians kindly buried 1-2" down. With the other excavator jobs I had and limited rental time I threw up my arms and just moved onto the next job.
    eatonpcat, theburtman and T.Jeff Veal like this.
  8. yooperdave
  9. Skier76
    Skier76
    CT and SoVT
    Bet someone got help after they changed their trousers.
  10. Flamestead
    Flamestead
    Windsor County, VT
  11. Canadian border VT
  12. Flamestead
    Flamestead
    Windsor County, VT
    On the left it is just the front guard. I had been mowing on Golden Rod and the screen was plastered (the radiator was surprisingly not too bad), and I had collected a wild apple somehow.
  13. Canadian border VT
    Ahh the dreaded screen is full of! It’s usually cat tail or dandelions in spring my temp gauge is rising. need a blow off tool to clean my filter &screebd
  14. Trueg50
    Trueg50
    Essex, VT
    Got our first snow today, it didn't stay for long but it was a reminder of what is to come. I got out and put the new winch and little Kubota to use on a medium size ash tree. It had some woodpecker holes but I didn't closely examine them for EAB holes, or peel back the bark to look for the "S" channels. Overall the setup worked beautifully and is a vast improvement on using chains or bucking and carrying to the road. I still need to work on cleaning up my splitting area from last year so I can stack these on sacraficial logs to keep them out of the mud. 20251109_114007.jpg 20251109_114017.jpg 20251109_120958.jpg
    Chaz, WinonaRail, yooperdave and 8 others like this.
  15. T.Jeff Veal
    Nice set-up
    Chud, yooperdave and eatonpcat like this.
  16. Trueg50
    Trueg50
    Essex, VT
    20251115_110119.jpg 20251116_144258.jpg 20251116_144309.jpg I couldn't wait for the ground to freeze so I got some more work done. My little girl came and helped clean up the tops for her woods/fairy forts. Fortunately her going rate is still hot cocoa and a granola bar. The little B2601 is handling the logs and Igland 2501 just fine. I was debating between the 2501 and 3501, but the 2501 is plenty and doesn't weigh too much. All my work has been on flat ground near my processing area, we will see how later winter work goes as I pull logs from further from my processing area (lots more hill work and driving down hills).
  17. Woodtroll
    Woodtroll
    Mtns of SW VA
    Skidding winches are great tools! I bought one a few months ago and it is a real work saver. It also keeps from tearing up the woods as much, since I don't have to get the skidsteer into the tree and then worm the logs individually through the standing timber.
    Enjoy your helper! That time passes so quickly.
  18. Krackle_959
    Krackle_959
    Coastal Maine
    Working on opening up an old woods road on our property. No big wood, lots of small dia maple, ash, and poplar. Biggest one was 10”, but 55’ tall, these are bean pole trees. Most are heading through the chipper, but I’m saving the larger trunks for firewood at the moment.
    Bottom of the hill by the ravine looking up the trail.
    Sometimes you just need to bring out all of the tools… had a leaner poplar hung up in another tree, facing the tractor, so used the Tuf-Tug to get it down without incident. IMG_6513.jpeg
    pile of wood so far, still got 4-5 larger trees to cut at the edge of the ravine. Then I’ll start on the other side hill. IMG_6518.jpeg
    Spent the afternoon yesterday wood chipping the tops and brush. At least the weather has been good the last couple days. IMG_6523.jpeg
    Chvymn99, eatonpcat, Trueg50 and 5 others like this.
  19. Canadian border VT
    We call then “pecker poles” until 8 inches then here call them Goldilocks.. fairy tale to process
  20. T.Jeff Veal
    That's looking great, farwood and chips...:thumbs::thumbs::thumbs:
    Nice work, sir
