Kubotas at play. Er, I mean work!
Discussion in 'Chainsaws and Power Equipment' started by Warner, Jan 20, 2018.
  1. fuelrod
    fuelrod
    Western Maine
    :( that's a bummer.
    It also can be a real event to find heat enough to loosen up the fuel when there just ain't none.
    If the 911 type fuel treatment doesn't work, pull the fuel filter & water separator replace/clean and fill with treated fuel.
    If you have electricity within extension cord range (before you start taking filters off) a hair dryer or heat gun should be enough if you heat them.
  2. fuelrod
    fuelrod
    Western Maine
    I
    I have used that with no complaints. Normally I'll make my selection on the lowest price on the shelf.
    Chaz, Chvymn99, T.Jeff Veal and 2 others like this.
  3. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    That heat gun is a great idea !!
    I appreciate all the advice !
    Chaz, Chvymn99 and T.Jeff Veal like this.
  4. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    I usually don't have any problems with it. I too shop lowest price...usually at my local TSC store. Just one of those things I guess !
  5. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    We did the heat gun trick. Worked good enough to get it to run enough to get it back in the barn safe and sound ! Shook so hard that it loosened a radiator clamp lol. Thanks for the advice ! New filters...and fuel gunk on the way. Gonna try this stuff. Good stars. So we will see. Hope I don't need the tractor in the meantime. Thanks again for the help !!
    fuelrod, Chaz, Chvymn99 and 2 others like this.
  6. Scottiechop
    Scottiechop
    Isn't that some of the best there is, so I've heard
  7. FarmerJ
    FarmerJ
    Minnesota
    Because of the biodiesel content and then the sub 10*F temps, you likely were only dosing 1/4 of what you really needed per the powerservice instructions. Something I learned the hard way 12/13 winter.
    fuelrod, T.Jeff Veal, Chaz and 2 others like this.
  8. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Well I'll never do that again lol !
    Hey..by #1 diesel..do you mean On Road diesel ?
    T.Jeff Veal, Chaz and eatonpcat like this.
  9. FarmerJ
    FarmerJ
    Minnesota
  10. FarmerJ
    FarmerJ
    Minnesota
    Yes.
    it’s almost like kerosene.
    for your tractor, you can use dyed off-road though and save over $0.40+ per gallon depending on your state. Federal take is $0.185 per gallon and state is from a low of $0.09 to a high of $0.74 the last time I did my road tax filing.
  11. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Ok..gotcha. I've been running on road diesel since day one. Unfortunately..around here...some years ago....some company's were delivering off road diesel with some sort of bacteria in it. I changed fuel filters 4 times in one summer on all of our equipment . So after that..I lost trust in that dirty stuff.
    I'll pay the extra at pump gladly...over changing fuel filters everytime I want to get something done !
  12. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    That's a great video. Very wmeye opening ! Sounds like I'm ok getting the 911 to unclog me...and the Howes to maintain me right ?
    I bet your right..my original stuff was probably under dosed.
    T.Jeff Veal and Chaz like this.
  13. FarmerJ
    FarmerJ
    Minnesota
    I only keep 911 around anymore.
    I found I got better mileage, and the money saved, more than paid for me to put better tires on my truck instead of additive in the fuel.
    but like I said, my current truck has tank heaters in the fuel.
    T.Jeff Veal, Chaz and HoneyFuzz like this.
  14. FarmerJ
    FarmerJ
    Minnesota
    Kill’em biocide will take care of that of it shows up.
    Killem EPA Approved Biocide - Products - FPPF Chemical
  15. Trueg50
    Trueg50
    Essex, VT
    I've seen too many issues at a relatives that didn't always treat their fuel and had issues. Maybe a little overkill but I try to use all my summer diesel by october/November so whe I get more it has the winter mix. I then treat with additive just to be safe.
    Back to the kubotas well fueled, merrily playing! I got mine out to deal with a major blowdown blocking trails. Took about 5 hours of work and made it home as it was getting dark.
    First the grapple eyes its victims up.
    Then it pounces!
    Cleared a large Tamarac, a pine, and two medium, two large (16") red maples. Cleared a another big maple and four other trees off the path in other places in a few hours.
  16. T.Jeff Veal
    That will make some nice firewood
    HoneyFuzz, Chaz, Jack Straw and 2 others like this.
  17. Hinerman
    Hinerman
    NE Oklahoma
    Where did you get that grapple? Looks beefier than the typical grapple...
    HoneyFuzz, Chaz and T.Jeff Veal like this.
  18. T.Jeff Veal
  19. Trueg50
    Trueg50
    Essex, VT
    Since only my tractor bucket can store things like chainsaws, and it has a hook for chain, I spent a little time cutting and prepping things for when I have the grapple on. I cut this maple part way in 3, "grapple-sized" pieces and the used a chain to pull it onto the road and then off to the side and finished the cuts. I also cleaned up some more blowdown including cutting a beautiful 12" red oak to chunks (I always feel bad with how pretty the grain is).
    As you can tell by how my tractor is setup for snow removal, I was NOT expecting this january heat wave!
  20. T.Jeff Veal
    Good job, working while you can
    HoneyFuzz and Chaz like this.
