Kubota MX5100HST 4x4
Discussion in 'Chainsaws and Power Equipment' started by Chud, Apr 24, 2023.
  1. Chvymn99
    Screwloose, Chud and brenndatomu like this.
  2. Chud
    Chud
    NC
    That was an interesting thread. The counterweight I’m getting is a homemade block of metal with lift pins. The seller thinks it’s closer to 2,000lbs. If I got the tires filled my current box would be enough.
  3. T.Jeff Veal
    Just pictures...;);)
    Screwloose, brenndatomu and Chvymn99 like this.
  4. Screwloose
    Screwloose
    Remember that fluid in the tires does NOT relieve any weight off of the front axle!
    I got all of my lead from tire shops they all save it. Melted it, scooped out the steel and poured it in.
  5. brenndatomu
    Correct...only weight added behind the fulcrum point (rear axle) will relieve the front axle of any burden
  6. Chud
    Chud
    NC
    Working on the wall between showers
  7. Canadian border VT
    T.Jeff Veal what is your loader number?
    I am hoping the 844kg over 1850 pounds the front axels are heavier in MX models
    Screwloose, eatonpcat and T.Jeff Veal like this.
  8. T.Jeff Veal
    I think it's LA513...IIRC...MX models definitely have heavier axles.
  9. The Wood Wolverine
  10. Chud
    Chud
    NC
    Picking up my new tractor weight. It’s a block of cast iron with 3 point attachment.
    Chvymn99 and Chaz like this.
  11. Chud
    Chud
    NC
  12. Chud
    Chud
    NC
  13. Chvymn99
    :D... nice! how many pounds?
    eatonpcat, Chaz and Chud like this.
  14. Chud
    Chud
    NC
    It’s a mystery. The seller claims 2k
    It made the Tacoma pretty squirrely at 70mph banging the bump stomps on overpasses
    It should keep the Kubotas rear tires pinned to the ground.
  15. Chud
    Chud
    NC
    Mission accomplished
  16. Chud
    Chud
    NC
  17. Chud
    Chud
    NC
  18. Chud
    Chud
    NC
    I was curious about what the weight was originally used on and I think I found it.
    Ron T, eatonpcat, Skier76 and 2 others like this.
  19. Chud
    Chud
    NC
