Kubota MX5100HST 4x4
Discussion in 'Chainsaws and Power Equipment' started by Chud, Apr 24, 2023.
  1. brenndatomu
    Pallet forks on a front end loader are a pain, some more than others, but the worst ones are the add-on forks for backhoe/loader buckets...you can't see the forks at all when going into a load! :hair:
    You pretty much have to use a spotter.
  2. T.Jeff Veal
    Sometimes it's hard to see, I usually tilt the forks way down, to see where they are, slowly curl back and boom down as the tips are going into the pallet.
  3. Chud
    Chud
    NC
    Depending on the machine forking a pallet without tearing up the pallet can be difficult. Slow and easy has always been my motto. It’s harder to do big damage in turtle mode.
    Screwloose, Chvymn99, JD Guy and 4 others like this.
  4. Chud
    Chud
    NC
  5. Chud
    Chud
    NC
  6. T.Jeff Veal
    That's a nice chunk.
    Screwloose, eatonpcat and Chud like this.
  7. Chud
    Chud
    NC
    I was hoping to noodle the chunks before it gets hot today, but my oldest son proposed to his gf yesterday, so I’m doing brunch instead.
  8. T.Jeff Veal
    A day of rest does the body good.
  9. Chvymn99
    Congrats! :handshake:
  10. eatonpcat
    X2
  11. Chud
    Chud
    NC
    The boy got lucky. His fiancée will soon be an MD.
  12. FarmerJ
    FarmerJ
    Minnesota
    Even on a skid steer where they sit smack in front of you, the top cross bar, sight line and tip of the 48” forks, block the forks from your view.
  13. brenndatomu
    Score! :dancer:
    I worked with a guy whos wife is MD...he never worked too hard, and then retired early.
  14. Chud
    Chud
    NC
    The China weight box doesn’t hold enough weight for this log. With the bag of sakrete on top it holds 640lbs. That’s with the tool tubes filled. It’s rated for up to 800, so I guess it would have to be filled with something heavier than sakrete.
  15. FarmerJ
    FarmerJ
    Minnesota
    Fluid in the tires?
    would it do better with the forks curled more and the log more against the rack?
    surprised it struggled with it myself. Or is it longer than I realize?
  16. Chvymn99
    Screwloose … filled his with lead I believe…:cool:
  17. Chud
    Chud
    NC
    It’s a big log, but I’m going to get a weight box that’s over 1,000lbs. The china boxes were intended for bx and jd lawn tractors. A grapple that holds it closer to the rack would also make a difference.
  18. T.Jeff Veal
    That would definitely help.
    The counterweight we built weighs over 800#, tractor will still get loose in the rear, done a few 3 wheelers pulling stuff out.
    Screwloose, Chud, Chvymn99 and 2 others like this.
  19. brenndatomu
    Have you done any YouTube vids on replacing those front wheel bearings? Looks like some others might could benefit from it soon...:whistle: ;) :rofl: :lol:
  20. FarmerJ
    FarmerJ
    Minnesota
    Guess I’d load it with beet juice before changing the rear weight too soon.
