Kubota MX5100HST 4x4
Discussion in 'Chainsaws and Power Equipment' started by Chud, Apr 24, 2023.
  1. Chud
    Chud
    NC
    Grapple demo day
    Feels and operates heavy
  2. Chud
    Chud
    NC
    Gonna try it again with some Kentucky Coffeetree ballast
  3. Canadian border VT
    Waiting on your owner review :popcorn:
  4. Chud
    Chud
    NC
    It can do more with some weight hanging off the back.
  5. Chud
    Chud
    NC
    it’s a keeper
    T.Jeff Veal, eatonpcat, RCBS and 6 others like this.
  6. FarmerJ
    FarmerJ
    Minnesota
    Have you put fluid in the rear tires yet?
  7. Chud
    Chud
    NC
    Not yet. I’m going to see if weight box is enough first and I have to buy a grapple. Toys before beat juice.
    T.Jeff Veal, Chaz, eatonpcat and 3 others like this.
  8. FarmerJ
    FarmerJ
    Minnesota
    Yeah, grapples are important that’s for sure. Makes tree clean up a breeze.
    single handed I was able to clean up 4 out of 6 trees this day.
    Stacking that mess got really easy doing this all alone.
    T.Jeff Veal, Chaz, eatonpcat and 6 others like this.
  9. Screwloose
    Screwloose
    When I got my grapple it was definitely a "why did I wait so long" experience.
    T.Jeff Veal, Chaz, eatonpcat and 4 others like this.
  10. buzz-saw
    buzz-saw
    Ct.
    Exactly!
    I did find that even with my rear tires loaded it was still light in the back end lifting larger stuff. Added a ballast box and instead of filling it with cement I put lead plates in the bottom this left the rest of the box for chains and tools ; this made a huge difference on how it behaves with a load on the front.
  11. Screwloose
    Screwloose
    Lead, I did the same thing!
    I set the weight box in a kiddie pool of water and melted/ poured over 800lbs of lead in the bottom.
  12. buzz-saw
    buzz-saw
    Ct.
    I had lead bricks ( or plates ) I think they were 6x9x1 inch if I remember correctly , Plywood on bottom , Bricks and then another layer of plywood on top so lead is completely covered. If I ever did want to change anything I still have that option. I also have another few hundred pounds if I need it.
    If not, it might become bullets?
    T.Jeff Veal, Chaz, Screwloose and 3 others like this.
  13. Chud
    Chud
    NC
    Going to demo this fork grapple next
    Also going to drive to Everything Attachments in Conover, so I can see a wicked grapple and other tractor toys.
  14. buzz-saw
    buzz-saw
    Ct.
    I have seen this setup but wondered how well it would work for logs compared to a standard grapple.
    Try it , what have you got to loose?
    Are you aware of the consequences if you drive to a place like that.:makeitrain":tractor:
    T.Jeff Veal, Chaz, Chvymn99 and 3 others like this.
  15. Chud
    Chud
    NC
    If I drive my daughters HHR the risk is lowered, but maybe the grapple is light enough to haul on the roof.
    T.Jeff Veal, Chaz, Chvymn99 and 4 others like this.
  16. buzz-saw
    buzz-saw
    Ct.
    If you take her car then it sounds like 2 trips.
    If not , your self control is way better than mine.
  17. Screwloose
    Screwloose
    I can't warm up to that grapple fork design. Probably a cool "C" clamp but how cool is a c clamp for picking things up? Maybe a bypass design would be better? I have a fork attachment and have wondered if it would be worth it to modify it with a clamping arm arrangement. Having the sliding forks would give me options but I'm still not sure.
    T.Jeff Veal, Chaz, Chvymn99 and 2 others like this.
  18. Chud
    Chud
    NC
    A Frostbite grapple is in strong contention for a finalist. I like something that scissors down on material.
  19. Chud
    Chud
    NC
    Got the grapple forks on. Definitely feels lighter and the grapple has smoother action.
  20. Chud
    Chud
    NC
    I missed seeing my yankee gtg bros eatonpcat The Wood Wolverine brenndatomu walt et al this weekend but I’m tractor poor/rich atm. Maybe next year I can afford to cross mason dixon again. :thumbs:
    Living the dream
    T.Jeff Veal, Ron T, eatonpcat and 5 others like this.
