Kubota MX5100HST 4x4
Discussion in 'Chainsaws and Power Equipment' started by Chud, Apr 24, 2023.
  1. brenndatomu
    He should be servicing that machine on a "severe duty" schedule using it like that.
  2. Eggshooterist
    Eggshooterist
    Erff
    He moved away now but yes he should have. Same thing happens with short trip driving a vehicle. Excessive water and fuel can accumulate in the engine oil. Water in the transmission and axles.
  3. huskihl
    huskihl
    They’ll dry out in the summer if you can get through the winter without the filters freezing up
  4. Screwloose
    Screwloose
    Remember to check the breathers on the cases. A golf tee in the hose, tape over a vent hole ect. Can prevent a lot of "breathing" that occurs with temperature changes. Let it breathe in use to vent moisture plug it when done.
  5. Canadian border VT
    Mine was milky when I got it; but it was not under cover then. It mostly is now and no problems since
  6. corncob
    corncob
    Somewhere in Lower Michigan
    So long as you get the gearcase up to a reasonable temperature, the entrained water will evaporate. I never have that issue because I run mine pretty hard.
    metalcuttr and T.Jeff Veal like this.
  7. Chud
    Chud
    NC
    Going tomorrow to :binoculars:
    Skier76, T.Jeff Veal, huskihl and 7 others like this.
  8. Chud
    Chud
    NC
    I’m guaranteeing that it will sell before I get there
  9. eatonpcat
    She's a Beaut Chud!!
  10. FarmerJ
    FarmerJ
    Minnesota
    Almost 2500 lb lift, I’d buy it.
  11. brenndatomu
    That's how it'd go for me!
  12. Screwloose
    Screwloose
    She's sure purdy!
    T.Jeff Veal, Chud and Chvymn99 like this.
  13. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    no wait.....its orange
  14. Chud
    Chud
    NC
    Looks like the loader arm is scuffed too, so they better knock 10k off.
  15. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    that be nice
  16. Eggshooterist
    Eggshooterist
    Erff
    That number on the loader... double it. Thats pretty close to its loader capacity.
  17. huskihl
    huskihl
    Double.2 actually :D
    And it’s very conservative. Probably will lift the max on the end of pallet forks.
    Mine is rated 1150, so 2530 lbs and I know I’ve lifted 3.5K on the inside of the pallet forks
  18. Eggshooterist
    Eggshooterist
    Erff
    It also depends on how high you are lifting, how close to the pivot pins ect. You already know. Lol The drealer had told be the double the number gets you close. On Kubota tractors anyway. Who knows about the other brands numbers.
    I need to put a guage on mine. I have the shims from Kubota that Jeff gave me. They are often on the lower end of the psi range from the dealership. A couple hundred psi adds up if you are under the max.
  19. Eggshooterist
    Eggshooterist
    Erff
    Here is the confusing part for buyers. This is my L3800 loader specs. One of those numbers is close to double my model number, one under quite a bit and some quite higher than double. Screenshot_20230427-220335~2.png
  20. huskihl
    huskihl
    The number on the loader is in kg. And about 2.2 lb/kg. I reckon that’s just kinda the average roundabout middle of the road approximate amount the loader will pick up
