Kubota B2650
Discussion in 'Chainsaws and Power Equipment' started by Well Seasoned, Dec 23, 2017.
  1. Well Seasoned
    That's a good thread. Tractor will get a good workout today. Its dumping heavy outside at the moment with the potential for over 14". My grizzly does great for pushing snow, but with 14" coming, ill have to push it multiple tones throughout the day. Now where they plow comes through and leaves the deep piles is where i need something that can move this chit a bit easier.
  2. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    If you are stuck and one wheel is spinning you apply the brake pedal for that wheel to allow the other wheel to spin and help you get out. They were also handy pre-power steering to help steer the tractor aka a skid steer. I have a hard time using my separate pedals because they are next to the hydrostatic pedal and I can’t seem to use both at the same time.
  3. Well Seasoned
    Hmmm, makes sense. I think the brakes are on the left and the hydro pedal is on the right. Even the hydro pedal will take some getting used to.
  4. Jack Straw
    Jack Straw
    I use the differential lock when I get stuck, I bet your tractor has one of those. In this cold weather the grease for the hydrostatic pedal gets stiff and the pedal tends to stick. This can be scary!
  5. Well Seasoned
    This does have diff lock. I have read that the plunger on the hydro petal can fail/ get stuck after awhile, but this would cause the tractor not to start.
  6. Well Seasoned
    This was my other choice if the one i got was a little to big......
    Kubota 2090Z
  7. Flamestead
    Flamestead
    Windsor County, VT
    Yes, and even with power steering a 2wd tractor that is light in the front will try to plow straight ahead in greasy conditions. I use them less with the 4wd, but do still. Usually when up in the woods, on a hill, in the snow, in tight turning conditions. You can spin the tractor right around on the braked pivot wheel in a 3ft or so radius.
    Some of the older Kubotas had both front and rear differential locks. Mine has just the rear lock - pretty handy when needed.
  8. fuelrod
    fuelrod
    Western Maine
    Whooie! Congrats Brian. Burnin wood in the mtns of NH, a good pickup truck, 4 wheeler and now a tractor, what else would a guy want?:yes:
    We (you) should start a tractor & snow removal post for a good winter thread. (come on January right?)
  9. Well Seasoned
    Thanks, should i purposely not push back the piles when i plow? Just leave it pile up until the wife yells at me..... when i can say "the tractor will be here soon babe!"
    Maybe a YouTube channel? Who doesn't like to just watch other people move material around? :D
    :tractor:
  10. Backwoods Savage
    Brian, I notice you want a block heater. Do you really need one on a Kubota?
    Well Seasoned likes this.
  11. Canadian border VT
    Backwoods Savage, They say that a significant amount of wear to the diesel motor occurs on initial start up in cold weather. Mine was $125 installed, I know motor was close to 12 thousand so it seemed like cheap insurance to me. MasterMech recommended it in a thread somewhere, so I had it added.
    Maina, Woodslave, Stephiedoll and 7 others like this.
  12. fuelrod
    fuelrod
    Western Maine
    Keep in mind that those block heaters can gobble up some wattage. Usually a couple of hours is all it takes if you're not a daily user. I got a plug in timer that would handle iirc 2000 watts, not your normal lamp timer. Plug the timer in the wall then the tractor into the timer.
  13. Will C
    Will C
    New York
    Those Kubotas start easy, but the diesel mechanics I know insist on block heaters. As posted before, much less wear on the engine. My tractor is in a shed without electricity-I just plug into my Honda generator for a hour or two. Starts easier and warms up faster.
  14. Flamestead
    Flamestead
    Windsor County, VT
    We use the block heater when around freezing or colder. Seems cheap enough, and it makes a big difference in how the tractor sounds as it first starts up (I wince the few times I start it cold). That said, the Kubota is the best starting diesel I’ve owned.
    My wife does the morning cattle chores during the week, and has to go up to the shop to plug it in an hour or so ahead of using it. We don’t feed every day, so a timer doesn’t make sense. I’ve been looking into the WiFi controlled outlets as an alternative, so she can turn it on with her phone while still in her slippers.
    brenndatomu, cnice_37, Hammy and 2 others like this.
  15. 94BULLITT
    94BULLITT
    Frederick County, VA
    Most of the wear on an engine is from startup to 160 degrees (coolant temp).
  16. Well Seasoned
    It's something they are throwing in for free, along with welded hooks on the bucket. But yea, it gets a little cold up here seems like a gooder idea. I know thewoodlands had a little trouble with the -40 and the battery- so using the trickle charger worked. I'll need to look into a timer worthy of the watts
  17. Beetle-Kill
    Beetle-Kill
    Near the Divide, Colorado
    Can't wait for reports when it shows up. I'm already planning for next year...... 'ya know. :yes:
    Hammy and Well Seasoned like this.
  18. Screwloose
    Screwloose
    Block heater really cuts down on cylinder wash.
  19. savemoney
    A barn! He is going to need one. Hope he gets one with an upstairs. Brian, Congratulation on getting that tractor. You are going to love it. I hope you do get the chains. There are times you can just sit and spin even on the level without chains. Where you are, it isn't a bad thing to have them in the truck "just in case".
    Hammy, fuelrod and Well Seasoned like this.
  20. Well Seasoned
    I'm waiting for the call or email when its expected to be delivered.
