Kubota 3301 block heater
Discussion in 'Chainsaws and Power Equipment' started by Slocum, Dec 24, 2020.
  1. JCMC
    JCMC
    Just outside of Shushan, NY
    On my L2501 it is on the left side of the block towards the rear by starter.
  2. Slocum
    Slocum
    North Central Indiana
    The EGR cooler takes up that spot. From what I’ve seen I’ll have to knock out a freeze plug then install a threaded insert. I’m going to call dealer Monday with serial number and go that route.
  3. Rope
    Rope
    Alaska
    I have a L3301 with the package from ESI the Kubota dealer out of Fairbanks. It use's a pig tail with 3 connections, I will get some pics for you in the next few days, next time I get it outside. Not much light in the garage in a box.
    Edit: I am not sure of the location of the block heater, also has a pad heater on the pan and a trickle on the battery. The coldest I started is -26* and with HST I am guessing something is on the hydraulics, starts way to well, the FEL works way to well for cold fluid. I will see if I can trace cords and figure it out.
  4. JCMC
    JCMC
    My heater was suppose to be installed by dealer when I purchased the tractor they forgot to install I called and they sent a service tech to do the install (no charge} I was not at home when he came but apparently it did not take long to install.
  5. Slocum
    Slocum
    I appreciate it. From what I’ve figured out it’s behind a side panel on left side
    Screwloose and Spencer like this.
  6. Born2Burn
    Born2Burn
    Youngstown, OH
    What about just a magnetic oil pan heater?
    I have the 3901 and have thought about 2 magnetic heaters: 1. On the oil pan, and 2. on the Hydraulic sump
    Screwloose, Spencer and Slocum like this.
  7. Slocum
    Slocum
    I’ve thought about that but I like the idea of heating water more so than oil.
  8. JCMC
    JCMC
  9. Slocum
    Slocum
    I’ve looked on both some. Lots of videos and information there. But I didn’t find my model with the tier 4 emissions. I ordered a service manual. I got busy at work and forgot to call dealer to order heater but planning on it tomorrow.
  10. Rope
    Rope
    Alaska
    Here you go, you can see where this plugs into a port it doesn’t look like a freeze plug. Plus I have a oil pan pad and a trickle charger. You can see a 2 foot pig tail was used to plug in, it’s nice and out of the way. F8C175D8-3A65-4128-A662-31D6EA379D68.jpeg 28DBEF6D-4A52-4D75-B76E-A007806A045F.jpeg 5D175347-966B-4226-942D-AB6AFF254D89.jpeg 63D3E228-DC27-4CB2-8286-70904D98D8A5.jpeg 6297B4B4-BF7E-448F-8658-057DD6CF7181.jpeg
    brenndatomu, Spencer and Screwloose like this.
  11. Slocum
    Slocum
    Spencer, Screwloose and Rope like this.
  12. Rope
    Rope
    Alaska
    I will look closer, if it is it’s a very tight, neat connection all other freeze plug units were way bigger. The ones I have seen as a port are more like this one very close and neat, in the block vs water.
    Spencer, Screwloose and Slocum like this.
  13. Slocum
    Slocum
    Picked up block heater from dealer, planning on install next weekend.
  14. Rope
    Rope
    Alaska
    Is it a freeze plug or dry port?
  15. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    Messicks.com has lots of Kubota parts and parts diagrams.
  16. Slocum
    Slocum
    It’s a freeze plug. It goes in the same place as yours.
  17. Rope
    Rope
    Alaska
    Good to know. I read above that the plug last about 1,000 hours. I am going to get a spare, you know how that works.
  18. Slocum
    Slocum
    Once you do the initial install it will be a easy fix. The actual block heater threads in. I don’t think I would even drain the anti freeze for that. Just a quick switch of parts.
  19. Rope
    Rope
    Alaska
    Already have it, was talking about having a spare.
  20. Slocum
    Slocum
    08B77C11-50CE-4801-A0C3-0CF13491FCCC.jpeg The yellow X is on the freeze plug I had to remove. I drained the antifreeze and Just installed block heater and fired it up and brought up to temp. No leaks so far :D
    Stlshrk, brenndatomu, Spencer and 2 others like this.
