Kohler engines ?
Discussion in 'Chainsaws and Power Equipment' started by Pallet Pete, Feb 5, 2015.
  1. Eric VW
    My Champion 22T did that Saturday, but not on Sunday.... Hmmmmm.....
  2. HDRock
    Horkn likes this.
  3. Moparmyway
    Moparmyway
    New York
    Surging under no load at throttle is so typical of ethanol fuel.
    You can either try to adjust it out by richening the fuel (if it has adjustments, if not-just a touch of choke will work)
    Or run a can of True Fuel and watch it clean up.
    How do you like that splitter otherwise ?
  4. clemsonfor
    The surging can be from a whacked out carb...due to gelled or crystallized fuel that screwed the carb up. Often tea you can't fix it with a rebuild. Just have to buy a carb.
    Maybe a pitted seat from water in fuel corroding it and needle can't seal it off.
    Horkn likes this.
  5. Babaganoosh
    Babaganoosh
    Jersey Shore
    There shouldn't be any old fuel in it. Only got it in January. Used it a few times and then put away until July. Had stabil in it. I only run premium fuel as well. No e free gas stations around here. I can get 5 gallons of canned e free for 60 bucks locally though. I am also a few minutes from a local small airport. They might hook me up with some aviation fuel.
  6. Moparmyway
    Moparmyway
    New York
    Easiest way to tell is to warm up the motor and allow it to surge at no load, then start slowly closing off the choke (ever so slowly) and you will see how she cleans up.
    Most newer motors wont allow you to adjust the mixture
    You might find that regular instead of premium allows it to run smoother
    I have a generator at work that would surge at load as well as no load (no carb adjustments)
    My boss thought I was cracked when I told him that it is the ethanol in the fuel, and wanted to return it again (this being the 2nd generator, exact same thing happened with the first one).
    I brought in some of my VP SEF, and right in front of him drained the pump gas and poured in the VP
    It took about 10 seconds to run clean, and it runs clean all the time, under a load and at no load.
    We now keep 5 gallon drums of VP in the fuel storage for the generator and jetter
    Horkn and clemsonfor like this.
  7. clemsonfor
    Premium is nothing but higher octane E gas??? Better off with 87 cause its fresher. And that is a long time for fuel to sit now. I have had gas go bad...stink like bad gas in as little as 8-10 weeks
  8. ironpony
    ironpony
    Mid Ohio
    I have also found an out of spec governor spring or linkage will causes this. sometimes a bump will bend the sheet metal the spring is attached to and throw it all out of whack
    Horkn likes this.
  9. super3
    super3
    Indiana
    I have a 69' Lickity Splitter with the original K series Kohler 8hp. Compression getting a bit low now but,it starts so well I hate to tear it down. P1020302 (Small).JPG
  10. clemsonfor
    I wouldnt touch it then
    Horkn likes this.
  11. super3
    super3
    Indiana
    Not going to till it just won't go no more.
    I bent the wore out top plate and had to rebuild it. Gave a quick Earl Sheive while apart.
    Motor and pump still original.
    Horkn likes this.
  12. TurboDiesel
    oh my, I haven't heard that name in years, :rofl: :lol:
    Horkn likes this.
  13. Horkn
    Running premium had in motors designed for lower octane makes then run worse, wastes $, and make less power.
    I've got a feeling you carb is gunked up...
    clemsonfor likes this.
  14. Guido Salvage
    Guido Salvage
    The heart of the Bluegrass
    I run Kohler toilets in my house...
  15. TurboDiesel
    you should try the american standard champion 4
    virtually uncloggable
    like Al Bundy's Ferguson
    :Yar:
    sorry
    cnice_37 likes this.
