kinda stymied by this issue
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Lousyweather, Aug 30, 2019.
  1. imacman
    imacman
    Denver, NC
    That WAS after cleaning....... :rofl: :lol:
    Chaz, badbob, subsailor and 6 others like this.
  2. slvrblkk
    slvrblkk
    Northampton, PA
    Chaz, imacman, bogieb and 1 other person like this.
  3. PelletHound
    PelletHound
    SE Ma.
    A couple of pounds of C4 would do the trick.:rootintootin:
    SmokeyTheBear, Chaz, badbob and 3 others like this.
  4. Lousyweather
    Lousyweather
    Correct....I find that the pellet ash seems to be kinda hydrophilic.....if its humid, as many basements are, upon cleaning a stove that has sat dirty for a time with no dessicant to take up the moisture.....they can actually be quite wet
    Chaz, badbob, imacman and 4 others like this.
  5. subsailor
    subsailor
    Winthrop, Maine
    I think it needs a little more than a cleaning.
    Chaz, imacman, PelletHound and 2 others like this.
  6. dotman17
    dotman17
    Snohomish, Washington
    Dental floss?
    Chaz, bogieb, imacman and 1 other person like this.
  7. don2222
    don2222
    Salem NH
    If the combustion fan blade is frozen or the auger is frozen, then the stove will not run.
    A good Sandblasting and painting will fix the stove right up.
    Tell the customer to get a good electric or propane heater and dehumidifier to keep the stove warm and dry or move the stove to a location that is not damp!
    Chaz and wildwest like this.
  8. don2222
    don2222
    Salem NH
    Actually and most likely, it is all clogged up under the burn pot. If you remove the cover and clean it out, then it should work fine. :)
    Chaz, bogieb and wildwest like this.
  9. IHATEPROPANE
    IHATEPROPANE
    At first I thought it didn't run because it looks like it was pulled from the Titanic. But I reread the thread and it is clearly because it is a piece of chit Harman:p
  10. imacman
    imacman
    Denver, NC
  11. Chaz
    Chaz
    Southwestern NY
    I'm certainly not a pellet guy, but something tells me they shouldn't look like that.
    :binoculars:
    :faint:
  12. unbidden
    unbidden
    RI
    maybe this guy will buy it as a back-up
  13. Russell
    Russell
    South Coast , Massachusetts
    Definitely damp basement and I'm sure outside vent is left uncovered in the Summer so all that humidity can roll right in .
  14. ChandlerR
    ChandlerR
    Seacoast NH
    Holy crap! Judging from the scale, it almost looks like it's been submerged. I have a dirt floor basement that has two sump pumps that run most of the year. To say the humidity is high in there would be an understatement. I have never seen any rust or corrosion anywhere close to that. I'll be interested in what all it took to get it running again.
  15. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    The sand blaster is in the next room about 24hrs worth will help a bit.
  16. Lousyweather
    Lousyweather
    I thought Titanic when I first saw it
  17. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    Much sandblasting and holes will appear through the rust :picard:
  18. Lousyweather
    Lousyweather
    yea, and who carries a sandblaster around in their service van?! Honestly, this stove cannot be properly serviced in-home. If the steel looks like that, imagine the condition everything else is in.....whats the auger look like? mechanicals? Would you charge a standard cleaning fee for this much neglect?
    And if you sandblast this baby, and holes DO appear, whose fault is that?
    IHATEPROPANE, Russell, bogieb and 2 others like this.
  19. Lousyweather
    Lousyweather
    I kept waiting for some kinda calamity to happen like fire, explosion, public unrest, etc
  20. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Why, it is your fault that your stoves are gummy.
    Bear runs off to his cave.
