Kawi FX850V Trouble
Discussion in 'Chainsaws and Power Equipment' started by lukem, Aug 2, 2016.
  1. Boomstick
    Boomstick Banned
    Saratoga county ny
    Vacuum or overflow tube? Usually when that happens the needle sticks wide open from the crap in it and floods the motor or pees out the overflow.
    Either way glad you figured it out!
  2. lukem
    Well...I thought I had this fixed.. but I was wrong. It ran like dog chit the last time I mowed and I decided to take another crack at it today.
    Background info that makes sense later....There has always been some oil leaking on the right hand side of the motor...I thought it was either from the crappy ez drain thing or the oil temp/level sending unit and it hasn't been a priority to fix.
    Today I decided to bench test the coils per the manual to rule out a spark issue. After I pulled the shroud I noticed the left bank was completely caked in dirt and oil. The oil cooler was packed on the back side. The whole thing looked like a crime scene once I got the covers off. The right coil was also completely caked in junk...even the surface facing the magnet on the flywheel.
    I have a failed oil cooler hose that has quietly been leaking oil and it built up just enough to interfere when the engine got hot. All the oil and grit on the coil probably made it hold extra heat too.
    That's my theory anyway. Couldn't test it because I broke a nipple off my fuel pump...doh. Going to pick up some hose and a new fuel pump tomorrow and see if that works.
    FYI.....I think they have gorillas at the factory assigned to torqing down the little Allen screws that hold the flywheel screen on. They were at least 463 ft lb. Took me the better part of 30 minutes to get one of them out.
    dgeesaman and SKEETER McCLUSKEY like this.
  3. Bret Hart
    Bret Hart
    Central NY
  4. Horkn
    That's a lot of torque on those torx. Uggg
  5. bocefus78
    bocefus78
    Indiana
    If you got em out you did good.
    Otoh.....Allen head bolts should be illegal.
    SKEETER McCLUSKEY and cnice_37 like this.
  6. lukem
    It involved making a T25 and T27 fit via BFH to get them out. Used vice grips as muh cheater bar.
    SKEETER McCLUSKEY and Boomstick like this.
  7. AJtree88
    AJtree88
    I'd check your valve clearance while you have it ripped down a bit. The exhaust side gets out of wack since these engines are run on WOT a lot.
  8. lukem
    Got everything put back together last night but it was too dark to test. Mowing tonight. Hope this fixed it.
  9. lukem
    Just mowed. Started off normal. After 10 minutes it started sputtering and backfiring constantly...but not severely. I decided to keep going and the last 20 minutes it ran like a champ.
    :confused:
  10. lukem
    Same thing again this week. Runs good, runs real bad, run good. Runs bad = down on power, sputtering, backfiring, can't hold RPMs for a few seconds then runs normal for a few, repeat.
    Any ideas anyone?
    TurboDiesel likes this.
  11. TurboDiesel
    sounds more electrical than fuel related.
  12. Bret Hart
    Bret Hart
    Central NY
    What does the back of the key switch look like? Rust, corrosion, loose or movable terminals, or burnt looking? I'm assuming this engine has a fuel shutoff solenoid in the carb? Could be loosing power/voltage when it warms up and allowing it to stop or slow fuel delivery.
    SKEETER McCLUSKEY likes this.
  13. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    check the main ground......this happens on scags with kawi engine...usually were it bolts to the block
  14. lukem
    Back of the key looks completely normal.
  15. lukem
    Main ground on the block appear tight and didn't have any corrosion. It did have some oil on it. I cleaned it up real good and put it back together. the wire for the oil sensor also had a lot of oil at the spade connection so I cleaned it up too.
  16. brenndatomu
    Goin bad? Maybe try to bypass it the next time it runs bad, see if that fixes it...
  17. lukem
    It could be getting flakey. Anyone know if they are normally closed or normally open?
  18. brenndatomu
    NO I would guess
  19. Bret Hart
    Bret Hart
    Central NY
    lukem likes this.
  20. lukem
    Update:
    Mowed last Sunday and it ran awful. Bench tested the coils and they both checked out OK cold and borderline warm. Decided to just replace them both. Ran it for a while tonight and it should have ran poorly but didn't.
    Think I got it whipped.
    cnice_37, MasterMech and Horkn like this.
