Kawasaki FC540V
Discussion in 'Chainsaws and Power Equipment' started by Pallet Pete, Apr 30, 2018.
  1. Pallet Pete
    Pallet Pete Moderator
    Ovid
    I didn’t get far enough to really dig in after the carb had to go to another side job.
    I took the carb completely apart and cleaned it then adjusted it according to the manual. It’s clean as in clean.
    I won’t do much more till the new valves show up and then go from there.
    Maina, Horkn, Chaz and 1 other person like this.
  2. Pallet Pete
    Ovid
    I don’t know if it was messed with before or not I’ve found multiple wire nuts and a taped wires the last few days. Whoever worked on it really shouldn’t have...
    RCBS, Maina, Horkn and 4 others like this.
  3. MasterMech
    Your no crank issue/bad key switch is a fairly well known issue with these. Deere put out a “relay kit” that fixes the problem. But I’m sure an enterprising individual such as yourself could easily duplicate the end result.
    Tractor Forum
    Hammy, Maina, Pallet Pete and 5 others like this.
  4. MasterMech
    And those were a pretty dang good model. If it’s got issues, it’s likely cause a human got involved.... :D
    Hammy, Carbine, Maina and 6 others like this.
  5. brenndatomu
    Ah yes, good thinking, that's a cure for persnickety starters everywhere...cars, trucks, ag, heavy equipment, etc, etc, etc! :yes:
    Hammy, Maina, Pallet Pete and 4 others like this.
  6. MasterMech
    I like a 7/16” flat head screwdriver myself. One hand on the screwdriver, the other on the fuel shutoff lever.....
    Hammy, Pallet Pete, Horkn and 3 others like this.
  7. Horkn
    Good to hear you got it to run. While you're waiting for the valve, check the oil. It may be loaded with gasoline. I'd dump the oil and put new oil in it for cheap insurance.
  8. Pallet Pete
    Ovid
    If I understand the idea right it’s creatung a bridge because the solenoid and factory start relay get weaker as it’s older?
    It doesn’t do the click click click thing like a low battery but rather clunk once then nothing. When I took the starter off non of the teeth where bad and it worked fine.
    Sounds like the starter assist creates a bridge to bypass the safety’s on the mower. My guess is that it goes wire to ground, wire to constant, wire to Solonoid from switch and then I’m guessing wire from solenoid post to relay and remove a wire from the key?
    That sound right. I could probably do that with a 12 volt relay from Carquest. What amp would that require on the 185?
    Horkn, Hammy and Chaz like this.
  9. Carbine
    Carbine
    Those are good mowers and good motors Pete. I really think it's had one too many people "working" on it. Starter relay (just because), sparkplug, valve adjustment, and an ultrasonic cleaning of the carb and I bet you'd be in business. I would be looking into that igniton also, I know some of those kawis had issues.
    I had a 165 Hydro, never had an issue out of it. I'd prime it in the spring, and had no issues with easy starts throughout the year.
  10. brenndatomu
    Could be a weaker solenoid...but more than likely its low system voltage to the solenoid.
    You can still maintain the safetys...just wire the new relay in after them.
    Yes...whatever generic aftermarket 12v relay they have in stock should work...I can't imagine that solenoid pulls more than an amp or two...
    Maina, Horkn, Hammy and 2 others like this.
  11. MasterMech
    As the safety circuit components age, dirty contacts make for more voltage drop across each connection and switch. Run the ignition switch, PTO switch, seat switch, brake switch, trans neutral switch all in series and you get a significant drop that gets worse when you add the load from the starter motor to the mix. The relay doesn’t -functionally- bypass anything. But it severely reduces the number of connections/devices in the start switch circuit down to just one, the relay itself. It takes a lot less current to hold the relay in, so less load on the safety circuit, less voltage drop while cranking. That relay won’t see more than 5 amps. Standard relay will work just fine.
  12. MasterMech
    Worth mentioning that the Deere relay kit is available on Amazon and is a plug and play install. Sure a generic relay is cheap but they give you a relay base and all the schmancy connectors to make ‘er chooch. Just sayin’.
    T.Jeff Veal, Hammy, Maina and 3 others like this.
  13. Stephiedoll
    Stephiedoll
    Omaha, NE.
    Hey Pete, just seeing how your JD is treating you these days? I've got two now, one with snow blower and just picked up a second beater for pulling the wagon moving wood and possible parts machine.
  14. Pallet Pete
    Ovid
    O it is gone now. I honestly don’t remember what I did with it. I bought a nice craftsman GT3500 but I sold that because I found out what it was worth and I haven’t had time to look for another mower. :whistle:
    I’m really looking for a quad now but I don’t need one it’s more of a toy… I’m just eyeballing things right now
  15. T.Jeff Veal
  16. Pallet Pete
    Ovid
    Shoot that's way to nice for me... :rofl: :lol: I haven't even talked myself into a 4*4 truck yet I keep driving the old rusty 2001 Silverado :rofl: :lol:
  17. Pallet Pete
    Ovid
    This is more like what id end up with. :rofl: :lol:
  18. brenndatomu
    Hey, I think we just had a pallet Pete sighting!
    How you been man?!
  19. Pallet Pete
    Ovid
    Things have been rocky this last year or so and I have really taken a huge break from technology in general but I am doing good now! :thumbs: Making a big crock pot of pot roast and trying some apples in to this morning.
    How ya doing?
  20. brenndatomu
    Good to hear!
    Pretty good...but way, way, and I mean WAY too busy! :hair:
