Jotul Oslo air control lever??
Discussion in 'Modern EPA Stoves and Fireplaces' started by My IS heats my home, Feb 17, 2014.
  1. Well Seasoned
    Have you checked elsewhere for air leaks? These stoves can be very tricky looking for a leak. Have you thought about adding a damper after checking everything else? I forget how much chimney length you have.
  2. My IS heats my home
    My IS heats my home
    Albany, NH
    Great suggestions and yes, been through all of them to include replacing fairly new gaskets just for peace of mind. Chimney length is around 26' and yup again, I put in an inline damper on the flue.
    If anything I have learned to burn better over the years but for some reason this stove doesn't want to work with me.
    If Jotul comes up with a solution, I'll give them a shot and see how it does. BUT, if it should be a string me along session, I'm still going with the IS.
  3. cptoneleg
    cptoneleg
    No I have no problems with my stove bought new in 2008, did great the first year and even better, as my wood got better and I realized how much this Mean Green Heating Machine loved Dry wood. But I know you know that .
  4. Well Seasoned
    Best of luck. Thats alot of chimney, and when its cold or windy, I can see you making good use of that damper. Keep us posted.
  5. cptoneleg
    cptoneleg
    My dealings were good with Jotul, A completely different situation than yours but the did replace my stove. (it was a paint issue)
  6. My IS heats my home
    My IS heats my home
    Albany, NH
    How long are your burns typically? and how about your overnights??
  7. cptoneleg
    cptoneleg
    We burn 7-24s and haven't used the furnace except for a few occasions. You know the definition of burn time. No one else is. But a good hot fire above 300'
    stove top 8 hrs. When it is real cold one of us gets up in the middle of the night and fills the box. Good hot coals 12 14 hrs or longer.
  8. My IS heats my home
    My IS heats my home
    Albany, NH
    Got a call from my stove shop this morn. Jotul sent them a air intake rebuild kit. I'm gonna grab it this morning when I walk the dogs and ask them what jotul is thinking. Will post later
  9. My IS heats my home
    My IS heats my home
    Albany, NH
    Doesn't look good, they tried to passify me by giving me a air control kit only. They gave me a lever, and new slide plate and a couple clips. Problem is, theres noting wrong with the one I have now.
    Looks like it's time to write a letter to the Jotul rep directly and speak my peace. Leaning hard towards the WS IS now. Might as well just keep the Oslo off the hearth and move it to the garage.
  10. cptoneleg
    cptoneleg
    My Oslo Heats My Garage ?
  11. My IS heats my home
    My IS heats my home
    Albany, NH
    Gonna try one more thing, since it's still in the house. Stove shop guy suggested playing around with the air inlet hole at the rear bottom of the Oslo. Closing the air inlet space slightly may help, won't hurt. :headbang:
  12. RockyMtnHigh
    RockyMtnHigh
    Bailey, Colorado
    I would check all the joints that are bound together with furnace cement, and short of giving up I may just take the thing apart myself and re-cement it. I've had to re-furbish a few of these, but not unless they were a decade old or more and had seen HARD use or were burned with the ash door open, which usually only cracks the lower burn plate and doesn't actually have any play on air flow itself. Most of that stove is held together with furnace cement.....
  13. Pallet Pete
    Pallet Pete Moderator
    Ovid
    When we bought our stove F50 it was a display and had MAJOR burn problems. We changed every single gasket twice and went through almighty hell trying to figure it out. Really long story short it turned out to be the gasket cement from the factory and the cement they sent us was the same. I went out and bought rutford cement for a third gasket change and bam no problems... The factory rep told us that it had been a known issue and that they would gladly replace all the gaskets and cement cost which they did. They even offered to come out and fix the stove free but we didn't have the time to wait so I did it. I am not sure if that is the same issue but I can say it's very likely!
    As for the air control it's great and should be the same as it's a jotul patent. The only thing I did was pull the crappy gasket out that was in it from being a display model and install a thicker one. It did make a difference and after looking inside the housing I can say it really wouldn't be hard to get stuff in there if your not careful. It's really just a slide that can be blocked easily.
  14. My IS heats my home
    My IS heats my home
    Albany, NH
    Thanks fellas. Just went back for the first time to the "other" forum to get my read on over there. Some simular issues , most of the fixes are close to your suggestions.
    Will take a closer look over the weekend. Thanks again!
    papadave likes this.
  15. reckless
    reckless
    Was thinking of going to this stove from a VC2550 but sounds like very similar issues with air leaks...... uggggh!! I would go with an IS also but it is too big for my fireplace opening ( would leave me with a 1/2" clearance to top) good luck luckily you have all summer to ponder :)
  16. My IS heats my home
    My IS heats my home
    Albany, NH
    Actually I don't. I have a deposit in on the IS, but not sure I want to take it if I can't find the problem with the Oslo. One way or the other I have to get the Oslo back on it's feet again if for me or a potential buyer.
    reckless likes this.
  17. My IS heats my home
    My IS heats my home
    Albany, NH
    How well does that NorthStar splitter do for you?
  18. reckless
    reckless
    Love it!! Never leaves its vertical position and starts first pull just about every time!
  19. Bart Wolfe
    Bart Wolfe
    Marion Ohio
    I need some help. I purchased an Oslo this past November but because of the mild winter I have only used it the past week or 10 days. I am burning dry ash with some red oak mixed in once in awhile . I cannot keep a fire more than 2-3 hours in this stove. I have filled it as full as I could get it twice and the stove temp on the back left top was over 700 degrees. That scared me. I feel like you can't control the air. Any suggestions ? I used to have a Vermont Castings encore that was 10 years old wish I had it back.
  20. Well Seasoned
    Is the oslo brand new?
    There could be a few things happening.
    When do you start closing down the stove?
    Have you checked the gaskets using a dollar bill? Place dollar bill in all areas of all the doors, close- you should not be able to pull it out.
    Window glass, is it centered without any noticeable gaps around the gasket?
