Its now March! How does the woodpile look?
Discussion in 'The Wood Pile' started by Backwoods Savage, Mar 1, 2024.
  1. Biddleman
    Biddleman
    River Hills of Pennsylvania
    I hear she's a Michigan fan. :banana::D
  2. Locust Post
    Just took some measurements, just under 2 1/2 cords. Less than I thought.
  3. The Wood Wolverine
    FIFY
  4. JRHAWK9
    JRHAWK9
    Wisconsin
    This is what I managed to add to my stash....mostly all between the middle of December and middle of January this winter. My nephew helped between xmas and new years. We then added to the pile a couple weeks later, as we got the pile out to the stump at the bottom left of the photo.....which was his goal.
    I started splitting in early Feb. I'm almost 10 cord into it and I have lots more to go.
    Even after selling 15 cord last winter, I'll be back up to well over 70 cords once I'm done splitting/stacking that pile. :doh:
    As far as what I've burned this winter........9,700lbs to date. Convert to the volume of species of your choice. Comes out to be ~2.7 cords of red oak.
    This year so far compared to past years:
    ole, Marvin, Biddleman and 6 others like this.
  5. Wes Hightower
    Wes Hightower
    North Carolina
    Relatively mild winter here in NC, no snow either. Burned up all my jenk wood to make room for some better stuff. Got the processing area cleaned up including all my stubbies. Need about four good size pickup truck loads and I'll be all done for this year. Trying to get it all done before the oppressive NC heat and humidity arrives. 20240226_073818.jpg 20240304_155641.jpg 20240226_073825.jpg
    JDU, EODDiver, Hickory45 and 10 others like this.
  6. Horkn
    I concur. I've burnt a lot of fir, pine and box elder. There's a good amount of ash that I burnt as well, but outside of a few days, it was only lower BTU wood.
  7. Horkn
    Right? We've got plenty to go around.
    Chaz, Biddleman, brenndatomu and 2 others like this.
  8. Elm-er Fudd
    Elm-er Fudd
    Kansas
    It was a good winter to clean up around the wood yard. Burned 2 ibc totes of chunklies, about a 1/2 cord of pretty punky stuff, all of my lumber scraps, and about a cord of good splits. Normally burn between 4 and 5 cords. My 3 year plan turned into a six year plan if these types of winters become normal. Will still process as much as possible this spring and fall. :makeitrain":makeitrain"Money in the bank!
    JDU, Stephiedoll, Horkn and 7 others like this.
  9. BuckeyeFootball
    BuckeyeFootball
    Burned about 2.5 cords this winter but it was 95% cherry and elm. Took an inventory today and I have 9 cords currently css. I probably have another 7-9 on the ground in logs waiting to be processed
    JDU, Horkn, Biddleman and 5 others like this.
  10. BuckeyeFootball
    BuckeyeFootball
    Thats what I always say. Im close to being far enough ahead where Im considering cutting a cord or two to standard 16" pieces and throwing it on facebook marketplace
  11. jrider
    jrider
    Way too much junk wood leftover this year. Not going to have any bins to store what I make this year.
  12. Farmchuck
    Farmchuck
    Nepa
    What kind of bins do you use? I’m thinking about coming up with some kind of bin/ rack system to reduce handling firewood multiple times for our OWB.
  13. MAF143
    MAF143
    North Central OH
    Normal winter we burn 6 cords with the highest with the new stove at 7. This year is looking like we'll end up at 5 ish.
    The old airtight would go through 15 cord a year.
  14. Backwoods Savage
    You must have had a full time job stuffing that old stove.
  15. Canadian border VT
    I did 13 cord 1 year; slept in living / stove room on couch got cold .. fill stove
  16. MAF143
    MAF143
    North Central OH
    Actually the old stove was easy loading. It ran for 8 hours holding the pipe temp at 500. It had a HUGE firebox and could stuff it full. But it was a stinky, chimney clogging, smoke dragon of a stove. Cutting wood for it was a CHORE... I was always behind...
    The new stove kicks out more heat when on high burn and heats the house as well on less than half the wood, but the trade-off is that I have to visit the stove more often to keep it in the high burn stage as opposed to lower temp coals. I work from home so I'm able to manage it pretty well and keep the whole house toasty for the wife without the furnace kicking on very much. The wood stove probably does 80% or better of the heating. The furnace blower that's on low all the time moves the heat around the house pretty well.
  17. jrider
    jrider
    I take the bladder out of the IBC totes and put them on a pallet. As I make firewood to sell, all the uglies, crotches, partial rot, super short cutoff cookies get tossed in the bin. Once full, I use the tractor to move them under cover in a triple length carport where they stay until I use the wood.
  18. brenndatomu
    If I had a loader that could handle it (like I suspect you do) I would do this >Idea for Ibc Totes< except for I think I'd pull the bladder/liner up higher in the cage, (for more overall height/capacity) and I'd leave the top on it, so it's kind of its own mini woodshed.
  19. Noth
    Noth
    We normally burn around 4 to 5 cord. Worst year we ran through 7. I put about five cord into the second bay, haven’t measured what’s left. Here’s a before and after. IMG_1775.jpeg IMG_1857.jpeg
  20. jrider
    jrider
    I use the cages for short or hard to get species I don't get much of. All of that is for sale.
