Its Getting Closer.....
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by SKEETER McCLUSKEY, Aug 27, 2015.
  1. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    20151010_180956.jpg she talks to angels and the stars start to spin....she thinks of troubles shes gotten in...
    imacman, IHATEPROPANE, Chaz and 6 others like this.
  2. slvrblkk
    slvrblkk
    Northampton, PA
    Already???
    IHATEPROPANE, Chaz, jtakeman and 6 others like this.
  3. jtakeman
    My days work! Put the sn*w blower on the new to us tractor. Freak getting the driveway plowed. Gonna do it myself.
  4. Chaz
    Chaz
    Southwestern NY
    Ackkk
    :hair:
    No fires yet..
    Bad enough around here..
    :wacky:
    Yesterday, she starts the furnace in the morning.. I turn on the AC at night.
    :picard:
    IHATEPROPANE, Russell, bogieb and 2 others like this.
  5. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    calm down....thats an old pic...but i dont think Chaz is kiddin about the furnace thing.
    we dont have any other source of heat except wood and pellets so the warden cant mess with the furnace HA!!
  6. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
  7. Chaz
    Chaz
    Southwestern NY
    Nope.. Not joking on that one.
    :picard:
    Wish that I were though.
    Chazsbetterhalf and I have a 16 yr age gap.. she gets cold, I'm generally hot.
    :doh:
  8. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
  9. jtakeman
    Nope, The road way and the driveway. Did it last season with a smaller riding lawn tractor(14hp). This should be just big enough. I got chains, weights and weight box to go on it yet. Ran outta gas today. :BrianK:
    24 hp Kohler with hydrastat drive. :tractor:
  10. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    you should get a tri-axle load of sawdust dump it in yer yard and wet it down til its like mud....then try it out to make sure everything works!
  11. jtakeman
    Uh uhhh. Worse case we got the 4x4 to unstuck it if need be.............
    Never got my self propelled simplicity walk behind stuck and have done the roadway many times. I'm a gonna try ridin this go round.
  12. imacman
    imacman
    Denver, NC
    Glad you got a garden tractor instead of a lawn tractor. That blower takes some power to get going & push through the sn*w.
  13. imacman
    imacman
    Denver, NC
    Single or twin cyl. ?
  14. jtakeman
    Twin. Runs sweat, But needs tinkering. Starting with a tune up/oil change. Then all new belts. :makeitrain"
    The blower is 46" and it nearly stalls it. I got to lube and check all the bearings. Must be something getting tight?
  15. imacman
    imacman
    Denver, NC
    Might have to pull the auger out of the housing, check end bearings, and maybe check the gearcase.
  16. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    The war's over junk it and get a horse.
  17. jtakeman
    I've got chains for this season. Next seasons list has AG tires at all 4 corners and rears will get modded v link chains. Not sure filling the tires with washer fluid would help in the muck, But it should help traction otherwise. Likely do all 4 corners as well.
  18. jtakeman
    Not sure about the war being over, Seems its a battle every day lately. All I know for sure is I'm gonna limit my walking behind a sn*wbeast and enjoy the sittin until we move from this spot.
    Next spot might not get sn*w, Or so much we will just not worry and act like a bear! Can't decide between the south or NH, VT or southern Maine........... Not sure I can take the heat of the southern summers! But if I have no need to go out in foul weather that works too. :D
  19. jtakeman
    Squirted some lube on the main carrier bearing and it spins much easier. So a full bearing change is going to happen. I gotta pull the whole darn thing apart anyway to change that main................
    :headbang:
    Gonna ditch the manual lift and go with a linear actuator. Right shoulder no likey the manual chit!!
    :makeitrain"
    Next season is a hydraulic conversion for the blower. Freak these belt drives!! Kind of feel like Snowy Rivers now! :D
    :cheers:
  20. imacman
    imacman
    Denver, NC
    Believe me, the fact there is not much in the way of any sn*w here, and "winter" is really only from about the beginning of Dec. - End of Feb. more than makes up for the hot summers. My back has said "thank you" to me all of the past 1 1/2 "winters".
    All I brought down when I moved was 1 sn*w shovel, and a couple containers of ice melt.......none of which I have used yet. :coffee:
