It was a jungle out there
Discussion in 'Chainsaws and Power Equipment' started by T.Jeff Veal, May 31, 2026 at 3:20 AM.
  1. T.Jeff Veal
    Friends called us to see if we could clean up two areas of their yard, after we did some work for her sister. We said we'll give it a shot...
    Went to work with the Kubota L4802, Landpride RCR1872 brush cutter and Catawba grapple. Mowed what we could, used the grapple to pull up small elm and sweet gum trees. Also dug up this clump of invasive trees. Anyone ever seen these before. 20260528_124341.jpg
    We had 3 loads on the dump trailer to go to their burn pile... 20260529_090456.jpg 20260529_094053.jpg 20260529_102956.jpg Messenger_creation_587E22B5-06E5-435E-806F-B4C61C452A4B.jpeg
    Bonus leaning hickory they wanted taken down in that area...it went home with us...Helene had partly uprooted it Messenger_creation_4E7E37CB-B664-4E39-B3AF-B9CF55D3C71F.jpeg
    Got it cut loose from stump, pulled it down... Messenger_creation_AA8A06AA-87BF-44BC-8B06-E772C4A3D042.jpeg
    The other area was part of their pond dam, didn't get before pictures, but just could see the top of the rootball on this white oak...the area at the top is what it all looked like. 20260529_123322.jpg
    Will C, JimBear, Ron T and 12 others like this.
  2. Duane(Pa)
    Duane(Pa)
    Centre Co.
    Good job. That’s a lot of work!
  3. buZZsaw BRAD
    Looks like Tarzan and Ms. Jane didn't monkey around. :D Some great wood there!
    That invasive tree bark looks like tree of heaven, but not the leaves.
  4. T.Jeff Veal
    Thank you, sir. About 5 hr on Thursday and a couple on Friday to clean up piles
  5. T.Jeff Veal
    Yes sir, the clock was ticking. Had to get some scrap iron out of the weeds/brush too...missed a plow point :( but mower found it:picard: about half was left, it knocked a dent in the side...:headbang:...
    Look up Chinese Parasol Tree...
  6. Canadian border VT
    Great work as always T.Jeff Veal Your work ethic and equipment are real assets. Keep up the threads
  7. T.Jeff Veal
    Thank you, sir :handshake:
  8. The Wood Wolverine
    Lotta work done there TJV. Kudos :cheers: .
  9. T.Jeff Veal
    Thanks, brother :cheers:
