  1. Devin86
    Devin86
    Shinnston, WV
    Put 4-6-1 in after I cleaned will run it tonight and try it out appreciate all the help here guys!
  2. imacman
    imacman
    Denver, NC
    Keep us informed how it burns at that setting.
  3. DexterDay
    DexterDay Administrator
    Northeast Oh
    Because the air and fuel were both dropped 1 (5-7 to 4-6), the results won't be much different? In my opinion. By reducing both, nothing changed. You would need to lower just the feed by 1, or raise the air by 1?
    5-8 or 4-7 would allow more air and/or less fuel and eject more ash.
  4. mike holton
    mike holton
    Old Dominion
    if the OP is running at 9-9 the bottom settings will matter none at all. bottom feed stoves the trim settings only affect heat ranges 1 and 2
    take a very close look at the hopper seals, when air is pulled down the feed system it tends to push the flame at the glass. now after a couple bags or so you will start to soot the glass a bit. also tends to make a white ash coating so what you see it not far from normal.
    hardwood pellets do tend to clinker more than softwood but it helps in keeping as much fly ash out of the heat exchangers. note running on high will load the areas behind the baffle much quicker so keep that clean back there
  5. slvrblkk
    slvrblkk
    Northampton, PA
    I think his 5-7 might have been a typo.....?????
  6. Devin86
    Devin86
    Shinnston, WV
    yes I am now running 4-7 but i guess it makes no difference as I have been running at 9-9 on the top
  7. slvrblkk
    slvrblkk
    Northampton, PA
    Mike, I thought this used to depend on what year the stove was built? Memory is not so good....lol
  8. mike holton
    mike holton
    Old Dominion
    actually it has to do with the stove type, if its a "2 auger" stove its only the low end, if its a "1auger top feed stove" it controls the whole table
    imacman and DexterDay like this.
